On Saturday, July 2, 2016 at 4:44:25 AM UTC-4, herrman...@gmail.com wrote:> On Friday, July 1, 2016 at 9:48:03 PM UTC-7, robert bristow-johnson wrote: > > (snip, I wrote) > > > > I now have a schematic for an analog four band parametric equalizer, and it is > > > somewhat simpler than I was expecting. > > > the peak/cut parametric EQ is a BPF in parallel with a wire. > > If I didn't see it in the circuit, I wouldn't have known what "in parallel with a wire" > looks like, but it seems to be a filter with one wire for both input and output. > > > the shelving EQ is an LPF or HPF in parallel with a wire. > > The Low Shelf (high-pass) and High Shelf (low pass) seem to be ordinary op-amp > based filters. They use dual potentiometers to keep the level constant in the > pass band as the filter changes. One before, and one after, the parametric filters. > > > the old analog graphic EQ had BPFs in parallel with each other and lowShelf > > and hiShelf as bookends. but there was some nasty phase cancellation in > > between the bands. > > Seems that some of that is a side effect of the equalization itself. >well, yes and no. it's an effect of a *particular* way to do equalization. this parallel BPF way to do it. but if the graphic EQ is done as follows:> > doing a graphic EQ digitally might be a bunch of parametric EQs in > > series with a very wide word for the signal to mitigate the buildup of > > quantization noise.... then when all of the faders are set to zero dB, it's just a wire. you shouldn't be able to tell if it gets kicked in or out.> > > There is a Motorola 56001application note on how to build one. > > http://pdf1.alldatasheet.com/datasheet-pdf/view/107880/FREESCALE/DSP56001.html >yeah, but that's still the dumb parallel BPFs. r b-j
How are variable filters implemented?
Started by ●June 24, 2016
Reply by ●July 3, 20162016-07-03
>I believe you can pick any filter design and it doesn't specify how >tomake a "variable" version of it. Rather, it only gives the >equations for designing a static filter or static filters.> >So the question then is, how to make it variable like in a typical, >practical parametric equalizer.AFAIK, this isn't always as simple task as one would think. Are you talking about HW or SW implementation (both mentioned in this discussion)? case 'sw'{ If you look that r-b-j's Audio EQ cookbook paper, you notice how those common parameters (Q/bw, gain, cf/c/mf) are been used in case of "DF1-BLT-2nd order biquad" implementations. Maybe you should study some theory behind digital filters. Jos's site has been mentioned as a good resource https://ccrma.stanford.edu/~jos/filters/ } --------------------------------------- Posted through http://www.DSPRelated.com
On Sunday, July 3, 2016 at 9:17:31 AM UTC+3, jtp_1960 wrote:> >I believe you can pick any filter design and it doesn't specify how >to > make a "variable" version of it. Rather, it only gives the >equations for > designing a static filter or static filters. > > > >So the question then is, how to make it variable like in a typical, > >practical parametric equalizer. > > Are you talking about HW or SW implementation (both mentioned in this > discussion)? > > case 'sw'{ > If you look that r-b-j's Audio EQ cookbook paper, you notice how those > common parameters (Q/bw, gain, cf/c/mf) are been used in case of > "DF1-BLT-2nd order biquad" implementations.Software. And well, we can take RBJ's filters as an example. Since the cookbook gives parameters for Q, gain and cutoff, then how are these actually varied in a real-time implementation? Does one construct a table of the values and vary between them?
>Software. And well, we can take RBJ's filters as an example. > >Since the cookbook gives parameters for Q, gain and cutoff, then >how arethese actually varied in a real-time implementation? Does >one construct a table of the values and vary between them? None of my real-time (GEQ/PEQ) implementations uses lookup tables but calculates new filter coefficients in real-time for the filter which parameter was changed. This is smooth operation even when you make fast changes for parameters. (I'm talking 'bout 2nd order system but in my implementations there's also file writing and graphics plot done right after coefficient calculation). I've seen lookup table based fixed Q/bw graphical EQ implementations (cf's and Q/bw are constant, only gain changes) but, AFAIK, parametric EQ would be much more complicated to implement through lookup tables because of all parameters are changeable. --------------------------------------- Posted through http://www.DSPRelated.com
On Sat, 2 Jul 2016 08:05:15 -0700 (PDT), Matti Viljamaa <viljamaadsp@gmail.com> wrote:>On Saturday, July 2, 2016 at 5:37:06 PM UTC+3, jtp_1960 wrote: >> >I want to understand general ways of transforming filters that are >> >specified "statically" (i.e. that the coefficients are supposed to stay >> static) >> >into dynamically variable filters. Many filter books seem to describe >> filters >> >mainly only statically as if they would be "designed and then left so", >> >eventhough most digital audio applications call for parameters that the >> user >> >can vary in real-time. >> >> Maybe some example case could help here? >> --------------------------------------- >> Posted through http://www.DSPRelated.com > >I believe you can pick any filter design and it doesn't specify how to make a "variable" version of it. Rather, it only gives the equations for designing a static filter or static filters. > >So the question then is, how to make it variable like in a typical, practical parametric equalizer.Certainly with analog filters the "variable" conversion is straightforward: The standard approach to analog filter design is to break it into 2-pole stages (plus a single-pole stage if the total is odd). Pick a topology where the frequency of each 2-pole stage is controlled by a pair of matched resistors (usually different for each stage) and replace (conceptually) with a ganged potentiometer. In reality you'd use OTAs... cumbersome, but fairly standard in analog synths. A nifty method I first saw mentioned by Don Lancaster in the "CMOS Cookbook" is to use real Rs but put a CMOS analog switch in series with each. (Make sure the switch "on" resistance is small compared to the tuning resistance.) Then apply high-frequency PWM to all the switches, well above the audio range. The effective resistance is increased as the duty cycle decreases, and all the stages track together, even though they have different tuning Rs. This works great, but is practically limited to a 10:1 range or so, in my experience. Best regards, Bob Masta DAQARTA v9.20 Data AcQuisition And Real-Time Analysis www.daqarta.com Scope, Spectrum, Spectrogram, Sound Level Meter Frequency Counter, Pitch Track, Pitch-to-MIDI FREE 8-channel Signal Generator, DaqMusiq generator Science with your sound card!
Reply by ●July 4, 20162016-07-04
On Sunday, July 3, 2016 at 3:24:56 AM UTC-4, jtp_1960 wrote:> >Software. And well, we can take RBJ's filters as an example. > > > >Since the cookbook gives parameters for Q, gain and cutoff, then > >how are these actually varied in a real-time implementation? Does > >one construct a table of the values and vary between them? >there might be a lotta dimensions to the table. doing more than 2-dimensional table lookup (and maybe interpolation) is a real pain in the ass and not particularly computationally cheap.> None of my real-time (GEQ/PEQ) implementations uses lookup tables but > calculates new filter coefficients in real-time for the filter which > parameter was changed. This is smooth operation even when you make fast > changes for parameters. (I'm talking 'bout 2nd order system but in my > implementations there's also file writing and graphics plot done right > after coefficient calculation). > > I've seen lookup table based fixed Q/bw graphical EQ implementations (cf's > and Q/bw are constant, only gain changes) but, AFAIK, parametric EQ would > be much more complicated to implement through lookup tables because of all > parameters are changeable.maybe if the numerator coefficients were done arithmetically with the boost/cut gain, the denominator coefficients can be done with a two-dimensional table lookup. one dimension might be the base 2 log of of the resonant frequency and the other dimension would be either log of Q or BW in octaves. but it's not hard to just crunch out the numbers. this does not have to be done for each and every sample unless you want **really** good (i.e. smooth) modulation performance. you might be able to recalculate coefficients periodically (every 8 or 16 or 32 samples) and then, on a sample-by-sample basis, slew the coefficients from their previous value to the new values as computed from the user parameters (Q and w0). but it depends on how wildly you might be expecting to modulate the parameters. you might not even want to use the Direct Form 1 for it. you can still use Cookbook formulae for the coefficients in the biquad transfer function and then map those to coefficients in the Lattice Form. check out http://web.eecs.utk.edu/~roberts/ECE506/PresentationSlides/LatticeLadder.pdf you will find out that one of the Lattice coefficients, k1, fully defines the resonant frequency, w0. you can really crank on that k1 coefficient and maybe not get a filter that blows up on you. r b-j
On 06/29/2016 06:33 AM, Matti Viljamaa wrote:> On Tuesday, June 28, 2016 at 11:46:59 PM UTC+3, herrman...@gmail.com wrote: >> On Monday, June 27, 2016 at 9:13:48 PM UTC-7, robert bristow-johnson wrote: >>> if you have infinite computational power, you can slew the user >>> parameter each and every sample and recalculate all of the coefficients >>> each sample. >> >> Having not actually tried it, if you have a ROM look-up table with filters of >> various center frequencies and Qs, does that help? >> >> Changing the center frequency is like changing the sampling rate. >> >> With the size of ROMs today, you could put a really large table of >> precomputed coefficients in, and just look one up when needed. >> >> Maybe 1024 center frequencies, equally distributed in log frequency >> space, and 1024 Qs. Choose the closest one. > > Does this kind of "quantization" of the frequencies lead to the stepping being heard when the parameters are changed? I.e. that the auditory response sounds "stepped"? Or is there a way, e.g. dense enough table, so that the response still sounds smooth? >I believe the way it's done in some commercial implementations is to reduce zipper noise, the filter coefficients are recomputed when the control "voltages" are being swept at low speed, and it switches over to linear interpolation between stored coefficients at high rates, where any artifacts due to the coefficients not being specifically computed for that center frequency will hopefully be masked by the sweep.
Reply by ●July 14, 20162016-07-14
On 06/24/2016 02:44 PM, Matti Viljamaa wrote:> How are filters that have their cutoff and e.g. Q variable (such as in a typical parametric equalizer) done?One possible solution is to use filter structures where coefficients are more directly related to the desired filter characteristics to be adapted than simple biquads / direct structures. E.g. lattice structures / wave digital filters, ie. filters based on all-pass structures. This can lead to filters where e.g. cutoff-frequency of a lowpass-highpass pair nearly linerly depends on some coefficients in a certain frequency range and your "filter design" comes down to a simple interpolation.> Does this mean that the filter coefficients are recalculated (i.e. the filter is redesigned) every time the parameters are changed? > > What kind of other design considerations are involved (such as computational efficiency)? What about "smooth parameter changes", is it interpolation (and how is this adapted to recalculating the filter coefficients?)? >
Reply by ●July 15, 20162016-07-15
Judging by this C++ library, https://github.com/vinniefalco/DSPFilters it shouldn't depend on the filters themselves, whether they can be made sweepable or even have "smooth parameter changes". So I guess there's some general technique?
On 15.7.16 10:45, Matti Viljamaa wrote:> Judging by this C++ library, > > https://github.com/vinniefalco/DSPFilters > > it shouldn't depend on the filters themselves, whether they can be made sweepable or even have "smooth parameter changes". > > So I guess there's some general technique?The library does IIR filters, which are DSP implementations of classical continuous-time analog filters. It seems that the library uses the analog filter design equations and transforms them to the sampled-data domain using the bilinear transform. This is fine as long as you keep far enough away from the Nyquist frequency. Please note that the filters are not just for arbitrary passband or stopband, but only the classical lowpass, highpass, bandpass and bandstop. For the classical filter design methods, get a filter design textbook. -- -TV
