Labview vs. C++
Started by Tim Wescott ●July 20, 2016
OK.  Neither of the groups to which I'm cross-posting this are
appropriate.
But, y'all are smart, and I know who to listen to.
Problem: I'm working on a proposal for a customer, for an app that's
going to require heavy computation and is more or less real time*.  The
guy I'll be working with the closest is pretty much a 100% LabView
programmer -- he just doesn't _do_ C, or C++, or Fortran.
The customer wants me to deliver them an algorithm, to which they'll
write code.  They're pretty firm (for good reason) on wanting to do the
code in-house, or with local talent.  I'm trying to decide how hard I
need to push, early on, for the computationally intensive bits to be done
in C++.
I just Googled, and didn't find any good references on the relative
speeds of doing things in some compiled language vs. Labview.  If the
ratio is similar to what you get in Scilab or Matlab, then they need to
go with C++.
So -- anyone know?  Any comments?
Thanks.
* It's not 100% hard real time, with an "exceed and you die" sort of
deadline, but after the nominal deadline the slope of the user-crankiness
vs. delay curve is pretty steep.  Moreover, while _occasional_ delays
could be tolerated, if the computer just can't keep up then the delays
will grow ever longer -- and the user ever crankier -- with time.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
I'm looking for work -- see my website!
Tim Wescott  <seemywebsite@myfooter.really> wrote:
> Problem: I'm working on a proposal for a customer, for an app that's > going to require heavy computation and is more or less real time*. The > guy I'll be working with the closest is pretty much a 100% LabView > programmer -- he just doesn't _do_ C, or C++, or Fortran.
> The customer wants me to deliver them an algorithm, to which they'll > write code. They're pretty firm (for good reason) on wanting to do the > code in-house, or with local talent.
Sounds good
> I'm trying to decide how hard I need to push, early on, for the > computationally intensive bits to be done in C++.
I would say, not at all, unless you think your failure to steer them on the issue might cause the project to collapse and negatively impact your future revenues; but even in this scenario you do not want to directly challenge their internal technical approach. I would recommend proposing to include a C++ program among your deliverables to them, so that they have a reference implementation. You may also want to propose a certain number of your hours as post-delivery support. Steve
On 21.07.16 01.57, Tim Wescott wrote:
> I just Googled, and didn't find any good references on the relative > speeds of doing things in some compiled language vs. Labview. If the > ratio is similar to what you get in Scilab or Matlab, then they need to > go with C++.
There is no general factor. It depends. If you do an FFT in LabView it is probably almost as fast as your C++ code on the same hardware, since the kernel functions of LabView is C++ too and uses appropriate libraries. But simple code with loops in the LabView code can be quite slow if it requires many iterations. In this case I would expect up to 2 orders of magnitude. LabView is AFAIR more or less a functional language which easily can be executed on many CPU cores if some of the execution paths are independent. In contrast you need to do this job by yourself in C++. At the end it depends on the absolute required CPU power. As long as it fits below the desk paying for new hardware is almost always cheaper than paying for people to write smarter code. So only if recent hardware is not capable of the task in LabView there is a real need to switch to C++. A few days ago I ported a small code from Java to C++ (computing 4E9 numbers with a certain PRNG algorithm). The computation time reduced from several years to several days. (In fact the task was solvable with "Brain" in several minutes - but that's a whole different story.) Marcel
On 7/21/2016 12:37 AM, Marcel Mueller wrote:
> A few days ago I ported a small code from Java to C++ (computing 4E9 > numbers with a certain PRNG algorithm). The computation time reduced > from several years to several days.
This only says that the Java code was not well written at all. Current indications all point to Java being as fast (and sometimes even faster) than C and C++ these days. Just google it. One random link (July 18, 2016) http://blog.optionscity.com/java-vs.-c-performance-face-off-part-ii "In summary, it is clear that the raw performance of modern Java is equal to, if not superior to C++ systems, and that the quality of the code is the most important factor in the performance of the system." There are many more studies that indicate the same. Sure, there are area where C or C++ is still faster, but it will be few percentage points faster in those cases if any, not multiple of magnitudes faster. The days when Java was slow are long behind us. Choice between C/C++ and Java these days can no longer be about speed, but for other reasons specific to the project.
> (In fact the task was solvable with "Brain" in several minutes - but > that's a whole different story.) > > > Marcel >
On Wednesday, July 20, 2016 at 10:39:11 PM UTC-7, Marcel Mueller wrote:
(snip)
> A few days ago I ported a small code from Java to C++ (computing 4E9 > numbers with a certain PRNG algorithm). The computation time reduced > from several years to several days. > (In fact the task was solvable with "Brain" in several minutes - but > that's a whole different story.)
Either very badly written, or JIT was turned off. For both C++ and Java, you have to be careful not to do allocation and deallocation inside inner loops. Otherwise, with Java and JIT loops run about as fast as C++.
> On 21.07.16 01.57, Tim Wescott wrote: > > I just Googled, and didn't find any good references on the relative > > speeds of doing things in some compiled language vs. Labview.
(snip)
Yes.
> If you do an FFT in LabView it is probably almost as fast as your C++ > code on the same hardware, since the kernel functions of LabView is C++ > too and uses appropriate libraries.
For any of the compute intensive functions, matrix solvers, differential equation solvers, and such, it should be pretty close. But if you write complicated calculations using low level operators, it can be pretty slow. This is pretty much true of any of the interpreted mathematical processors, such as R, Mathematica, Matlab, and Octave.
> But simple code with loops in the LabView code can be quite slow if it > requires many iterations. In this case I would expect up to 2 orders of > magnitude.
Some years ago, I had to speed up a program in R. First I did some timing to find where the slow parts were, using an assembly language routine using RDTSC. (The time stamp counter on IA32 processors.) Then put in calls to simple C routines at the appropriate places. And yes, with not so much work you can get two orders of magnitude speedup in many cases.
> LabView is AFAIR more or less a functional language which easily can be > executed on many CPU cores if some of the execution paths are > independent. In contrast you need to do this job by yourself in C++.
(snip) -- glen
can Labview support a "call" or "subroutine" to a module in C?
You write the critical C part and provide documentation and they do the overall Labview.
Seems that R, Mathematica, Matlab and LabView all allow for calling external C routines, usually through a DLL. Supplying a DLL and sample code calling it would seem to be a good way to do it.
On Thu, 21 Jul 2016 00:17:30 +0000, Steve Pope wrote:
> Tim Wescott <seemywebsite@myfooter.really> wrote: > >> Problem: I'm working on a proposal for a customer, for an app that's >> going to require heavy computation and is more or less real time*. The >> guy I'll be working with the closest is pretty much a 100% LabView >> programmer -- he just doesn't _do_ C, or C++, or Fortran. > >> The customer wants me to deliver them an algorithm, to which they'll >> write code. They're pretty firm (for good reason) on wanting to do the >> code in-house, or with local talent. > > Sounds good > >> I'm trying to decide how hard I need to push, early on, for the >> computationally intensive bits to be done in C++. > > I would say, not at all, unless you think your failure to steer them on > the issue might cause the project to collapse and negatively impact your > future revenues; but even in this scenario you do not want to directly > challenge their internal technical approach.
My job is to point them in the direction of success. If that means that using the computing language they're comfortable with won't lead to success, then I need to point that out to them -- even if they don't like it. I won't beat them with a stick, but they need to understand.
> I would recommend proposing to include a C++ program among your > deliverables to them, so that they have a reference implementation. You > may also want to propose a certain number of your hours as post-delivery > support.
They specifically don't want to pay for that -- there will be a Scilab program, but that has run-times roughly comparable to Labview. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
Yes, that's what they're doing now with the current revision.
> You write the critical C part and provide documentation and they do the > overall Labview.
Yes, but this time _they_ want to write all of it (for tax reasons -- it doesn't have to make sense if it's for tax reasons). -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
