On 09/01/2016 04:51 AM, Tim Wescott wrote:> I don't get to choose x(k). I've got a huge collection of raw signal > recordings from a customer, from which I'm trying to reconstruct channel > models. I suppose I should just do it by brute force and be happy...Earlier you said the x(k) were "presumed", what does this mean? Are they known or unknown? Seem to me you need to know at least their second-order statistics to be able to decouple h from the characteristics already present in x(k). Steve
Decorrelation
Started by ●August 31, 2016
Reply by ●September 1, 20162016-09-01
On Thu, 01 Sep 2016 12:50:07 +0000, Steve Pope wrote:> On 09/01/2016 04:51 AM, Tim Wescott wrote: > >> I don't get to choose x(k). I've got a huge collection of raw signal >> recordings from a customer, from which I'm trying to reconstruct >> channel models. I suppose I should just do it by brute force and be >> happy... > > Earlier you said the x(k) were "presumed", what does this mean? Are they > known or unknown?Deduced by demodulating a data stream, then reconstructing the transmitted pulse stream.> Seem to me you need to know at least their second-order statistics to be > able to decouple h from the characteristics already present in x(k).To the extent that I correctly decode the data and get the bit timing right, I can reconstruct x(k). It's that damned "to the extent" that means that I can't entirely trust x(k). -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
On Wed, 31 Aug 2016 22:52:05 -0700, SG wrote:> Am Mittwoch, 31. August 2016 19:39:07 UTC+2 schrieb Tim Wescott: >> >> The way I'm doing it gives good results, but it seems exceedingly >> wasteful of computing resources. It not only seems that this should be >> something that could be done handily using the FFT, but that I should >> know how to do it. So far, I've failed. It ought to be some variation >> of Wiener filtering -- but, as I've said, so far all I get when trying >> to apply FFTs to the problem is absolute crap coming back. > > Did you try Pwelch's method for estimating the transfer function? (See > Matlab's tfestimate. It's FFT-based). It's fast and robust. But I > suppose you might need more than 4096 samples if you expect the impulse > response to span about 512 samples. You might need much more to let the > method work on large blocks and have enough blocks for the averaging.I will look that up. I was lacking a name to start searching on. The x(k) and r(k) are built up as averages around a number of detected pulses, so there's been some noise averaging done from the get-go.> > Another approach would be to window and zero-pad x and b so that the > columns of X contain the same non-zero coefficients only shifted. Then > you could try to solve the normal equation system instead: > > A r = X^T b with A = X^T X > > Due to the structure of X, A will be a symmetric Toeplitz matrix (and > hopefully a positive definite one). For these kinds of matrices there > are special O(n^2) solvers. Computing A can be done using an FFT since > it contains the scaled auto-correlation of x. And X^T b is a cross- > correlation between x and b which can also be computed using the FFT. > > Though, numerically, this approach is worse as it basically involves > squaring X. So, if the condition number of X is already bad, this is > probably a bad idea. But it'll be faster. The condition number of A is > basically close to the ratio of the highest to the lowest power spectral > density of x. If your signal x is white or whitish then the condition > number of A should be fine and you shouldn't have any numerical > problems. Solving similar Toeplitz systems is what many speech coding > people do for estimating the all-pole filter that turns a buzzing sound > or noise into speech. >You have r and b backwards. I'm using b = X \ r in Scilab, which, when you hand it an over-determined system, finds the least-squares solution. I _think_ it's using singular value decomposition under the hood, but I'm not sure. Whether it's SVD or something else, I'm pretty sure it's not using the matrix-squared method. -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
Reply by ●September 6, 20162016-09-06
On 31.08.16 19.39, Tim Wescott wrote:> r(k) = h(x(k) + n1(k)) + n2(k) > > where r(k) is a known received signal, x(k) is a presumed input signal, > and n1(k) and n2(k) are unknown noise. I'm taking a repeated signal for > both x and r and averaging the snot out of them over the cycle, so the > actual noise is presumed to be low. However, the system isn't exactly > linear, so n2(k) has some "noise" that's actually nonlinear effects.There is no exact solution for nonlinear parts.> I want to put on my "easy math" blinders and assume that h is linear and > time invariant (it is, sorta), and that the noise signals are white and > Gaussian. Then I want to find the impulse response of h.n1 and n2 are equivalent since you will be able to find an n2' that includes the noise of n1 transformed by h. So you will not be able to distinguish them. In fact this reduces your equation reduces to r(k) = h(x(k)) + n Assuming that n is not correlated with x you may simply repeat the measurement to separate h from n. In fact it is quite easy. Use a signal with the following properties for x(k): amplitude(f) = 1 to the power of kappa for f in [fmin, fmax], 0 otherwise phase(f) = 2 pi random() IFFT of the above returns a finite length x(k) Choose kappa appropriate for your h, e.g. 0 for white noise and -1/2 for pink noise. Now repeat x(k) for a long time, in fact x(t), and *synchronously* sample r(t). Add every kmax sample together and divide by the number of repetitions (in fact an average operation) so that you finally get r(k). Now h(f) = FFT(r(k)) / FFT(x(k)) The above division is a complex, per component vector division. To get the impulse response of h just calculate h(k) = IFFT(h(f)) The noise cancels in the averaging operation. Note that you do not need to make any assumptions about n here. Note also, that you do not need a window function and you even should not use it. The theory behind that is that the cyclic x(t) basically makes its spectrum discrete, exactly matching the FFT bins of the following analysis. Assuming that n is uncorrelated means that the energy density in an infinitesimal small frequency interval is zero. So you need only to measure long enough and n will almost vanish from your h result. The average operation on every kmax-th r(t) sample is mathematically equivalent to taking an FFT of the entire measurement r(t) and dropping every result that does not exactly fit to a frequency in x(t) with non-zero energy. Only the required computation power is significantly smaller. In fact a Raspberry Pi would manage real time analysis at 200 kHz sample rate and 64k FFT size easily. Keep in mind that the information is kept in the /time axis/ (the time is an invariant). In fact the coherence need to last for the entire measurement. So it is absolutely required that the *crystal oscillator* of the DAC for x(t) is *exactly the same* than the one for the ADC for r(t). As long as both are in the same component this is likely. On the other hand it is not required for the oscillator to be very stable. Even cheap PC sound cards meet the needs. I already did high precision loudspeaker measurements in the garden while trucks are passing. There is not even any visible effect in the measurement response when a truck passes. In fact the above procedure theoretically works for any x(k) as long as it is repeated. The only drawback is that you only get reasonable results for frequencies that have reasonable energy in x(f). So your measured impulse response might be incorrect if x(f) is not well distributed. Regarding non-linearities: Non linear transformation will mix up frequencies (inter modulation). In fact terms with frequencies that are sums or differences of used frequencies in x(f) occur. For second order they have /two/ terms, for 3rd order three and so on. There is is quite simple way to get rid of the second order terms: simply set all amplitudes in x(f) for /even/ base frequencies to 0. When all used frequencies in x(f) are odd then any sum or difference of them is /even/ and does no longer contribute to the result. - Unfortunately there is no comparable solution for the 3rd order IM. Remember to double the FFT size (kmax) to compensate for the dropped frequencies.> I'm currently doing this by absolute brute force. I'm making a matrix of > delayed versions of x and making the matrix > > [x1 0 0 ...] > [x2 x1 0 ...] > X = [x3 x2 x1 ...] > [ ... ]?> Then I'm calculating the least-mean-squared error solution to > > r = X * b > > Then I'm taking the vector b as the impulse response of h.Although possible, you should not do this in the time domain.> The way I'm doing it gives good results, but it seems exceedingly > wasteful of computing resources.Exactly.> Is there a NAME for the FFT magic I'm trying to do, and is there a white > paper (or a book chapter) on it that I can go read?Maybe you can follow the method I mentioned above. Marcel
Reply by ●September 8, 20162016-09-08
On Wednesday, August 31, 2016 at 8:24:33 PM UTC-7, Les Cargill wrote: (snip)> > r(k) = h(x(k) + n1(k)) + n2(k)(snip)> Is there a method involving deconvolution lurking under all that?I hadn't thought of that at first, but now I think it might. In any case: https://www.amazon.com/Deconvolution-Images-Spectra-Second-Engineering/dp/0486453251/ is a good reference on non-linear deconvolution. It is now in a Dover paperback, and so very reasonably priced. (Or buy used copies of the hardback.) I bought the hardback second edition soon after it came out, after previously having the first edition from the library.
