Agree with everything you said, but this is not what you said in your previous post "averaging may not be enough bandwidth reduction to avoid aliasing." where you implied that averaging is related to avoiding aliasing, which it is not.
Kalman filter with accelerometer
Started by ●May 30, 2005
Reply by ●June 1, 20052005-06-01
Ok, disregard the above post, I read Jon's clarification of your response and now understand what you were talking about, you were refering to aliasing after decimation, I misunderstood
steve wrote:> Agree with everything you said, but this is not what you said in your > previous post > "averaging may not be enough bandwidth reduction to avoid aliasing." > where you implied that averaging is related to avoiding aliasing, which > it is not.Whatever you thought I wrote, and however badly I worded it, it's now clear that you LPF well enough for 64x sampling but not much slower. In that case, averaging can reduce the sampled noise. How much the noise is reduced compared to a simple LPF at the 1x rate depends on the noise spectrum. After all, with uniform noise density, the 64x filter lets through 64 times as much noise. There's no need to suffer aliasing if you LPF the digital signal before or while you decimate it. As to correlation of the noise in the samples, the 64x filter introduces very little. If the noise is broadband, averaging should reduce it to on the order of what (but maybe a little better than) a LPF might do. If the noise is inherently narrow band, then it is correlated at the high end before it's filtered. There are good ways and poor ways, but there's no free lunch. Analog LPF at Nx, admitting N times as much noise. Excess noise to be eliminated later. Average, reducing noise at all frequencies. Use a boxcar or other averager that gives as many samples out as in. LPF the averaged signal, probably as part of decimation. Eliminate all high-frequency noise that a 1x filter pass, and aliases. I think that's about as good as can be had. N=16 may reach diminishing return. As always, LPF cutoff is less than half the sample rate. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●June 2, 20052005-06-02
"blackmangoes" <blackmangoes@excite.com> wrote in message news:ePKdnW8F5u_ibQHfRVn-vQ@giganews.com...> Okay > Somehow I thought wk is the noise with mean equal to 0 > > Are we comparing the the old estimated acceleration and the measured > acceleation from accelerometer? If so, the state will just be acceleration > then. > > Is B in my Kalman Gain equation? where B is > > x_{k+1} = A x_{k} + B u_{k} + w_{k} > > then the next estimation is > \hat x_{k+1} = A \hat x_{k} +B \hat u_{k} + K (y - C \hat x_{k}) > > So if u_{k} is the noise, what do I put there? > If w_{k} is the noise, what is u_{k} and B? > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comYou only need U if you have a control problem.If it is purely random signal + noise then U is zero.(so is B) Rimmer
Reply by ●August 7, 20052005-08-07
>I only have an 2d accelerometer availabe but it is noisy, so I want to do >better than just doing low pass filtering. I am wondering if it is >possible to do kalman filtering with just an accelerometer. Let's say Iam>just concerning in position and velocitly in 1d space for now. > >I am a little confused what ithe input u in x(t+1) = Ax(t) + Bu(t) + w >equation and what the output y in y(x) = Cx(t) + n should be. > >People said y is supposed to be the measurement, so is it the >accelerometer reading? If my x(t) is [pos vel], then what is u(t)? > >Would be nice if someone can tell me what is A, B, C, x and y be >Your reply is greatly appreciated > > > > > > > > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.com >Hi, can anyone tell me where should the raw data input? This message was sent using the Comp.DSP web interface on www.DSPRelated.com
"ester" <estelle_ang@pacific.net.sg> writes:> > Hi, can anyone tell me where should the raw data input? >At the input? You really need to tell us much more about what data you're collecting, and what signal model you're using before we can answer the question sensibly. Ciao, Peter K.
Reply by ●August 8, 20052005-08-08
