"John Hadstate" <jh113355@hotmail.com> wrote in message news:1117654632.785625.143310@f14g2000cwb.googlegroups.com...> > > tanmay.zargar@gmail.com wrote: >> >> I doubt if there is an algorithm that will efficiently do >> what I need >> and more so be portable across the processor I am using. >> I say this >> because most optimized DSP algorithms make use of >> processor specific >> intrinsic functions which ultimately make use of the >> hardware units >> specific to the processor. If however, there is such an >> algorithm, >> please do let me know. >> >Here is an efficient, hardware-independent algorithm that will exactly compute 10**x where x is a 16-bit scaled number in at most 16 iterations. It works because: 10**(1 + 1/2 + 1/4 + ...) = (10**1)*(10**(1/2))*(10**(1/4)*... First, define the scaling. If 1.15, I'm assuming you mean 1 whole number bit and 15 fractional bits and the maximum value of x = 1 + 1/2 + 1/4 + ... + 1/32768. Then, define a table of 16 numbers according to the following algorithm: #define XBITS 16 double tenTable[XBITS]; tenTable[0] = 10.; for (i = 1; i < XBITS; i++) { tenTable[i] = sqrt(tenTable[i - 1]); } This computation needs be done once only, and ever after, tenTable can live in ROM or RAM. Now, using said table, the compute 10**x as follows: double Antilog10(unsigned int x) { int i; double y; i = XBITS; y = 1.; while (x != 0) { i = i - 1; if ((x & 1) != 0) y = y * tenTable[i]; x = (x >> 1); } return y; } By adjusting tenTable, this algorithm is easily adaptable to any scaling of x such as 1.31, 2.14, 8.8, etc.
Antilog - base 10
Started by ●June 1, 2005
Reply by ●June 5, 20052005-06-05
Reply by ●June 6, 20052005-06-06
John E. Hadstate wrote:> "John Hadstate" <jh113355@hotmail.com> wrote in message > news:1117654632.785625.143310@f14g2000cwb.googlegroups.com... > > > > > > tanmay.zargar@gmail.com wrote: > >> > >> I doubt if there is an algorithm that will efficiently do > >> what I need > >> and more so be portable across the processor I am using. > >> I say this > >> because most optimized DSP algorithms make use of > >> processor specific > >> intrinsic functions which ultimately make use of the > >> hardware units > >> specific to the processor. If however, there is such an > >> algorithm, > >> please do let me know. > >> > > > > Here is an efficient, hardware-independent algorithm that > will exactly compute 10**x where x is a 16-bit scaled number > in at most 16 iterations. It works because: > > 10**(1 + 1/2 + 1/4 + ...) = > (10**1)*(10**(1/2))*(10**(1/4)*... > > First, define the scaling. If 1.15, I'm assuming you mean 1 > whole number bit and 15 fractional bits and the maximum > value of x = 1 + 1/2 + 1/4 + ... + 1/32768. > > Then, define a table of 16 numbers according to the > following algorithm: > > #define XBITS 16 > > double tenTable[XBITS]; > > tenTable[0] = 10.; > > for (i = 1; i < XBITS; i++) > { > tenTable[i] = sqrt(tenTable[i - 1]); > } > > This computation needs be done once only, and ever after, > tenTable can live in ROM or RAM. > > Now, using said table, the compute 10**x as follows: > > double Antilog10(unsigned int x) > { > int i; > double y; > > i = XBITS; > y = 1.; > > while (x != 0) > { > i = i - 1; > > if ((x & 1) != 0) y = y * tenTable[i]; > > x = (x >> 1); > } > > return y; > } > > > By adjusting tenTable, this algorithm is easily adaptable to > any scaling of x such as 1.31, 2.14, 8.8, etc.Your algorithm suggests a modification. Use successive approximation to resolve the fractional part of the argument as the sum from m =1 to M of Am 2**-m where the coefficients Am are either plus one or minus one. For example if x = .34375 then x = .5 - .25 + .125 -.0625 + .03125 At each step of the resolution the mth table entry containing 10**(2**-m) multiples a product register when am is one or divides the register for am equal minus one. Hence 10**.34375 = 1 * (10**(1/2)) / (10**(1/4)) * (10**(1/8)) . . . Herbert
<a1eah71@aol.com> wrote in message news:1118041775.949460.8790@z14g2000cwz.googlegroups.com...> > > > Your algorithm suggests a modification. > > Use successive approximation to resolve the fractional > part of the > argument as the sum from m =1 to M of Am 2**-m where the > coefficients > Am are either plus one or minus one. > > For example if x = .34375 then x = .5 - .25 + .125 -.0625 > + .03125 > > At each step of the resolution the mth table entry > containing > 10**(2**-m) multiples a product register when am is one or > divides the > register for am equal minus one. > > Hence 10**.34375 = 1 * (10**(1/2)) / (10**(1/4)) * > (10**(1/8)) . . . >I can see what you say is true, but I don't quite see what it buys me (maybe half the table size?). Also, isn't division universally more time consuming than multiplication?
Reply by ●June 7, 20052005-06-07
John E. Hadstate wrote:> <a1eah71@aol.com> wrote in message > news:1118041775.949460.8790@z14g2000cwz.googlegroups.com... > > > > > > > > Your algorithm suggests a modification. > > > > Use successive approximation to resolve the fractional > > part of the > > argument as the sum from m =1 to M of Am 2**-m where the > > coefficients > > Am are either plus one or minus one. > > > > For example if x = .34375 then x = .5 - .25 + .125 -.0625 > > + .03125 > > > > At each step of the resolution the mth table entry > > containing > > 10**(2**-m) multiples a product register when am is one or > > divides the > > register for am equal minus one. > > > > Hence 10**.34375 = 1 * (10**(1/2)) / (10**(1/4)) * > > (10**(1/8)) . . . > > > > I can see what you say is true, but I don't quite see what > it buys me (maybe half the table size?). Also, isn't > division universally more time consuming than > multiplication?Generally division is more time consuming than multiplication. However, these differences are negligible compared with the cost of ignoring the benefits of binary arithmetic. By using resolving the argument as a sum from m=1 to M of Am log base two ( 1 + 2**-m ), calculation of 2**x requires only shifts and additions. Perhaps I am old fashioned but my position is anyone who does decimal arithmetic deserves to wait for what they get. Herbert
<a1eah71@aol.com> wrote in message news:1118120058.906145.30700@g49g2000cwa.googlegroups.com...> > > John E. Hadstate wrote: >> <a1eah71@aol.com> wrote in message >> news:1118041775.949460.8790@z14g2000cwz.googlegroups.com... >> > >> > >> > >> > Your algorithm suggests a modification. >> > >> > Use successive approximation to resolve the fractional >> > part of the >> > argument as the sum from m =1 to M of Am 2**-m where >> > the >> > coefficients >> > Am are either plus one or minus one. >> > >> > For example if x = .34375 then x = .5 - .25 + >> > .125 -.0625 >> > + .03125 >> > >> > At each step of the resolution the mth table entry >> > containing >> > 10**(2**-m) multiples a product register when am is one >> > or >> > divides the >> > register for am equal minus one. >> > >> > Hence 10**.34375 = 1 * (10**(1/2)) / (10**(1/4)) * >> > (10**(1/8)) . . . >> > >> >> I can see what you say is true, but I don't quite see >> what >> it buys me (maybe half the table size?). Also, isn't >> division universally more time consuming than >> multiplication? > > Generally division is more time consuming than > multiplication. However, > these differences are negligible compared with the cost of > ignoring the > benefits of binary arithmetic. By using resolving the > argument as a sum > from m=1 to M of Am log base two ( 1 + 2**-m ), > calculation of 2**x > requires only shifts and additions. > > Perhaps I am old fashioned but my position is anyone who > does decimal > arithmetic deserves to wait for what they get. >I'm trying to understand where the improvement is. The light hasn't switched on yet.
