On Sun, 18 Dec 2016 12:52:59 -0600, Tim Wescott <tim@seemywebsite.com> wrote:>On Sun, 18 Dec 2016 18:39:26 +0000, eric.jacobsen wrote: > >> On Tue, 13 Dec 2016 19:16:15 -0600, Tim Wescott >> <seemywebsite@myfooter.really> wrote: >> >>>On Wed, 14 Dec 2016 00:32:08 +0000, eric.jacobsen wrote: >>> >>>> On Tue, 13 Dec 2016 16:48:29 -0600, Tim Wescott >>>> <seemywebsite@myfooter.really> wrote: >>>> >>>>>On Tue, 13 Dec 2016 19:48:04 +0000, Steve Pope wrote: >>>>> >>>>>> Tim Wescott <tim@seemywebsite.really> wrote: >>>>>> >>>>>>>I've got a severe constraint on the amount of delay that I can add, >>>>>>>so I'm not working in the realm of codes that come closest to the >>>>>>>channel capacity -- rather, I'm working in the realm of codes that >>>>>>>come closest to the sphere-packing limit for the amount of delay >>>>>>>that I'm allowing myself. >>>>>> >>>>>>>It doesn't seem to be an area where a lot of work has been done. >>>>>> >>>>>> For the general constraint of code performance vs. clock length >>>>>> based on the sphere-packing limit, there is a paper by Fabrizio >>>>>> Pollara that I have linked to here before, one result of which is >>>>>> that for codeword lengths in the range of several dozen bits, >>>>>> conventional BCC's are the best available. >>>>>> >>>>>> I think this latency constraint makes it even less likely that >>>>>> you'll want to use a code over GF(16). Codes over GF(2) outperform >>>>>> codes over GF(N), N > 2, for the same codeword length -- so there'll >>>>>> have to be something very serindipitous about how the transmitted >>>>>> symbols map into code symbols. It would have to outperform feeding >>>>>> the MAP values into the binary decoder and there isn't a lot of room >>>>>> to improve on that. >>>>> >>>>>Here is my confusion: >>>>> >>>>>I am under the impression that the available decoder algorithms take >>>>>MAP values on a per-bit basis, but the structure of my symbols is such >>>>>that I cannot map my set of symbols to a collection of four bits such >>>>>that a "short distance" symbol error reliably results in fewer bit >>>>>errors. >>>>> >>>>>I already gave this example, but for the mapping that I'm currently >>>>>using, symbol #3 and symbol #4 are a short distance apart, so it would >>>>>be entirely natural for a decoder at the symbol level to come up with >>>>>an output that says that these two symbols are equally likely to have >>>>>been transmitted, and any other symbol values are highly unlikely to >>>>>have been transmitted. >>>>> >>>>>If I were to take that and turn it into binary with likelihoods, it >>>>>would say that bits 0, 1 and 2 are equally likely to be 0 or 1, and >>>>>that bit 3 is definitely a 0. >>>>> >>>>>So either I'm confused about why going from a 2-in-16 decode to an 8- >>>>>in-16 decode is a good thing, or I'm confused about how this binary >>>>>MAP decoding stuff really works, and there is, indeed, a way to do >>>>>conditional probabilities between bits. >>>> >>>> Are you familiar with how soft decision is mapped for bits in a >>>> high-order constellation, e.g., 16-QAM? >>> >>>No, although I have this fuzzy notion that where possible it's mapped >>>out in some sort of gray-code order, so that adjacent dots on the >>>constellation are only one bit off. I don't think I can do that here, >>>although I haven't tried to solve that particular puzzle. >>> >>>> Even though particular symbols may be the same distance apart, the bit >>>> reliabilities for two adjacent symbols depend on the decision regions >>>> for the particular bits, >>>> not the symbols. The bit reliabilities are determined by the slicing >>>> patterns for those bits, not necessarily how far away the next closest >>>> symbol may be. >>>> >>>> It is the same when distances between symbols aren't equal, e.g., >>>> 16-APSK, or other oddball, crazy-shaped constellations. The >>>> individual bit soft-decisions are determined by the slicing pattern. >>>> >>>> In something like TCM the patterns are dynamic, i.e., depend on a >>>> previously decoded symbol in order to increase the distance between >>>> possible adjacent candidate symbols. If you don't use such a scheme >>>> you can just slice consistently and still do very well >>>> performance-wise (this is basically the idea behind BICM). >>> >>> >>>It's the end of the day and my brain wants me to lie down and watch >>>"Futerama" for a while. Can you point to a paper or tutorial for me to >>>read? I'd ask for words of one syllable, or that it only use the ten- >>>hundred* most common words in English, but I guess I can't hope for >>>that. >>> >>>* "Thousand" is not one of the thousand most common words in English. >> >> Sorry, I must have stepped away from usenet for a few days...that >> usually happens during a topic I'm actually participating in for some >> reason. >> >> Which parts are causing the most difficulty? The mapping or the soft >> decision generation? Both? Neither are very difficult in >> implementation, usually. For the soft-decision generation simple >> approximations often perform only negligibly different than optimal, >> complex. ones. >> >> Several of the decent, early papers on BICM cover both in that context, >> but the general ideas apply to non-BICM systems as well. >> >> In this paper Fig. 2.1 shows simple, practical soft-decision "curves" >> for 16-QAM: >> >> http://shannon.cm.nctu.edu.tw/html/thesis/chia-wei.pdf >> >> Basically, figure out which input bits make a slope between the decision >> regions and you're most of the way there. >> >> These papers discuss various mapping tricks for high-order modulations >> in the context of BICM and BICM-ID (Iterative Decoding), but the ideas >> apply generally to any high-order mapping system. I've found the first >> reference very useful. >> >> Design, Analysis, and Performance Evaluation for BICM-ID with Square >> QAM Constellations in Rayleigh Fading Channels, Chindapol and Ritcey, >> IEEE Journal on Selected Areas in Communications, Vol 19 No 5, >> May, 2001 >> >> Optimized Symbol Mappings for Bit-Interleaved Coded Modulation with >> Iterative Decoding, Schrekenback, Gortz, Hagenauer, Bauch, Proceedings >> Globecomm 2003. >> >> The seminal paper on BICM. See Fig 9 for an example of set-partitioning >> an 8-PSK constellation: >> >> 8PSK Trellis Codes for a Rayleigh Channel, Ephraim Zehavi, IEEE Trans. >> Comm, Vol 40 No 5, May 1992 >> >> A useful follow-up is Caire's paper, which I think I cited earlier >> somewhere: >> >> Bit-Interleave Coded Modulation, Caire, Taricco, Biglieri, IEEE Trans. >> Info Theory, Vol 44 No 3, May 1998. >> >> If any of those references make your head hurt, cherry pick the sections >> that don't or just move on to the next. The complicated parts are >> really mostly of academic interest. The important parts are really >> pretty simple. If we could meet for beer (I wish!) we could hammer the >> basic ideas out easily before a pint was drained, but since that's not >> practical at the moment the citations above will have to do. >> >> High-order mapping and soft-decision generation are the sort of thing >> that once you get it, for many systems it can be easily shown completely >> in a diagram or two. I was looking for examples on the intartubes but >> didn't see anything suitable. I have some that are, sadly, proprietary >> else I'd share. If I can find something sharable I will. > >I have no problem with the soft decision making -- it's the question of >whether and how I can map my set of symbols to a set of multi-digit >binary numbers such that a short-distance ambiguity in the original >symbol results in fewer ambiguous (or wrong) bits than would happen if a >symbol were seriously off.I'm still guessing what your signal space looks like, but for things like PSK/QAM, some of the papers I cited talk about the set partitioning or mapping for good performance in the interleaved case. This can be done for arbitrary constellations, assuming you actually have a constellation of some kind.>If a symbol is completely trashed and I'm doing soft-decision making then >the answer's easy: I just have a block of erasures.This is one of the things that bit interleaving helps with; a symbol or a few adjacent symbols that are heavily damaged have a reduced impact on the ability to properly decode the message.
Really good book on coding
Started by ●December 12, 2016
Reply by ●December 18, 20162016-12-18
On 18.12.2016 22:03, eric.jacobsen@ieee.org wrote:> On Fri, 16 Dec 2016 19:37:09 +0300, Evgeny Filatov > <filatov.ev@mipt.ru> wrote: > >> On 14.12.2016 0:54, Evgeny Filatov wrote: >>> On 13.12.2016 22:03, eric.jacobsen@ieee.org wrote: >>>> On Tue, 13 Dec 2016 13:56:01 +0300, Evgeny Filatov >>>> <filatov.ev@mipt.ru> wrote: >>> >>>> >>>> That's him! He's a good dude, too. I liked him a lot. >>>> >>>> And thanks for the corrections on the texts. He had given me a >>>> signed copy of a Russian-language text that has a lot of familiar >>>> graphs and diagrams and such in it, so I had made the erroneous >>>> assumption that the text I cited was a translation, I think the >>>> Russian text I have may be on information theory, at least the last >>>> word in the title appears to be "information". I'm not very competent >>>> at Russian other than being able to read words that happen to be >>>> fairly cognitive to English, order beer, etc. >>>> >>>> >>> >>> Actually I don't know anything about the man or his works, so I couldn't >>> correct you. You may be correct and it's a translation, just I couldn't >>> find the original book. Or perhaps he has given you a manuscript. ;-) >>> >>> Gene >>> >> >> I didn't know about Prof. Krouk because I'm not that much of an EE guy. >> My academic background is mainly in (cond-mat) physics. However I've >> checked with some acquaintances of mine in the EE community and they >> know Prof. Krouk. >> >> A bit of offtopic. If you'd like to improve your command of Russian, I >> would suggest having a look at "The Last trial" -- some fantasy music >> loosely based on the "Dragonlance Legends": >> >> https://www.youtube.com/playlist?list=PLyhtJsrq6Kznc28Ksshkoq_zdsfUO4kcU >> >> It's nice entertainment stuff, and I occasionally put it on my playlist. >> >> Perhaps it would help you to understand Prof. Krouk's text. ;-) >> >> Gene >> > > Your assistance is very kind. ;) > > I had a long-time live-in g/f who was Ukrainian, and between that and > frequent travel to Russia with a former employer, I think I absorbed > about as much of the language as I could hope to. I did get good > enough at reading Cyrillic to pick out the English-cognitive words, > which worked far better than I would have ever expected. I do miss > going over there as I always found the trips interesting and > adventurous. >In a way, a good telecom/information theory text in Russian is a valuable learning resource by itself. What's important is the systematic review of a field, which is way better than using a dictionary. For example, the best English/Russian dictionary is multitran.ru. Sometimes it makes sense, e.g. if you'd like to know how to say "spectral leakage" in Russian: http://www.multitran.ru/c/m.exe?CL=1&s=spectral+leakage&l1=1 But try some other terms, e.g. "low-density parity check", and the result is unintelligible. Nobody uses that particular wording (save for the author of the dictionary entry). Contrary to that, reading a good text would educate you about the correct use of technical terms. Gene
Reply by ●December 19, 20162016-12-19
On Sun, 18 Dec 2016 19:09:41 +0000, Steve Pope wrote:> Tim Wescott <tim@seemywebsite.com> wrote: > >>I have no problem with the soft decision making -- it's the question of >>whether and how I can map my set of symbols to a set of multi-digit >>binary numbers such that a short-distance ambiguity in the original >>symbol results in fewer ambiguous (or wrong) bits than would happen if a >>symbol were seriously off. >> >>If a symbol is completely trashed and I'm doing soft-decision making >>then the answer's easy: I just have a block of erasures. > > Why would a symbol be "completely trashed"? Is it a burst-error channel? > > On an AWGN channel, the I and Q noise components are independent, > therefore if the I component is "trashed" there is no reason to predict > the Q component is trashed. > > And also, with AWGN, large-amplitude noise is exponentially less likely > than small-amplitude noise. In short, with AWGN you do not worry about > the "completely trashed" case as it is so unlikely -- most raw errors > are because the noise is just enough to push you over to the next > constellation point. > > But, if it's not an AWGN channel, and you can characterize the channel, > then your problem has gotten easier, as AWGN is the worst case. > > If it's not AWGN, and you cannot characterize it, then you are probably > "Sync Outta Lock" as far as designing towards it.No Q. Sorry, this isn't Star Trek. Or radio. Or even telephony. AWGN, baseband, symbols can be anything you want as long as they're either a fixed magnitude or zero, with a minimum switching time and with a constant average DC value. I'm currently using a fixed interval (for sanity), with a 4b6b encoding from the input data stream to the "symbols", which chooses 16 of the 20 available combinations of six bits that consist of three 1's an three 0's. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
On Sun, 18 Dec 2016 21:18:21 +0000, eric.jacobsen wrote:> On Sun, 18 Dec 2016 12:52:59 -0600, Tim Wescott <tim@seemywebsite.com> > wrote: > >>On Sun, 18 Dec 2016 18:39:26 +0000, eric.jacobsen wrote: >> >>> On Tue, 13 Dec 2016 19:16:15 -0600, Tim Wescott >>> <seemywebsite@myfooter.really> wrote: >>> >>>>On Wed, 14 Dec 2016 00:32:08 +0000, eric.jacobsen wrote: >>>> >>>>> On Tue, 13 Dec 2016 16:48:29 -0600, Tim Wescott >>>>> <seemywebsite@myfooter.really> wrote: >>>>> >>>>>>On Tue, 13 Dec 2016 19:48:04 +0000, Steve Pope wrote: >>>>>> >>>>>>> Tim Wescott <tim@seemywebsite.really> wrote: >>>>>>> >>>>>>>>I've got a severe constraint on the amount of delay that I can >>>>>>>>add, >>>>>>>>so I'm not working in the realm of codes that come closest to the >>>>>>>>channel capacity -- rather, I'm working in the realm of codes that >>>>>>>>come closest to the sphere-packing limit for the amount of delay >>>>>>>>that I'm allowing myself. >>>>>>> >>>>>>>>It doesn't seem to be an area where a lot of work has been done. >>>>>>> >>>>>>> For the general constraint of code performance vs. clock length >>>>>>> based on the sphere-packing limit, there is a paper by Fabrizio >>>>>>> Pollara that I have linked to here before, one result of which is >>>>>>> that for codeword lengths in the range of several dozen bits, >>>>>>> conventional BCC's are the best available. >>>>>>> >>>>>>> I think this latency constraint makes it even less likely that >>>>>>> you'll want to use a code over GF(16). Codes over GF(2) >>>>>>> outperform codes over GF(N), N > 2, for the same codeword length >>>>>>> -- so there'll have to be something very serindipitous about how >>>>>>> the transmitted symbols map into code symbols. It would have to >>>>>>> outperform feeding the MAP values into the binary decoder and >>>>>>> there isn't a lot of room to improve on that. >>>>>> >>>>>>Here is my confusion: >>>>>> >>>>>>I am under the impression that the available decoder algorithms take >>>>>>MAP values on a per-bit basis, but the structure of my symbols is >>>>>>such that I cannot map my set of symbols to a collection of four >>>>>>bits such that a "short distance" symbol error reliably results in >>>>>>fewer bit errors. >>>>>> >>>>>>I already gave this example, but for the mapping that I'm currently >>>>>>using, symbol #3 and symbol #4 are a short distance apart, so it >>>>>>would be entirely natural for a decoder at the symbol level to come >>>>>>up with an output that says that these two symbols are equally >>>>>>likely to have been transmitted, and any other symbol values are >>>>>>highly unlikely to have been transmitted. >>>>>> >>>>>>If I were to take that and turn it into binary with likelihoods, it >>>>>>would say that bits 0, 1 and 2 are equally likely to be 0 or 1, and >>>>>>that bit 3 is definitely a 0. >>>>>> >>>>>>So either I'm confused about why going from a 2-in-16 decode to an >>>>>>8- in-16 decode is a good thing, or I'm confused about how this >>>>>>binary MAP decoding stuff really works, and there is, indeed, a way >>>>>>to do conditional probabilities between bits. >>>>> >>>>> Are you familiar with how soft decision is mapped for bits in a >>>>> high-order constellation, e.g., 16-QAM? >>>> >>>>No, although I have this fuzzy notion that where possible it's mapped >>>>out in some sort of gray-code order, so that adjacent dots on the >>>>constellation are only one bit off. I don't think I can do that here, >>>>although I haven't tried to solve that particular puzzle. >>>> >>>>> Even though particular symbols may be the same distance apart, the >>>>> bit reliabilities for two adjacent symbols depend on the decision >>>>> regions for the particular bits, >>>>> not the symbols. The bit reliabilities are determined by the >>>>> slicing patterns for those bits, not necessarily how far away the >>>>> next closest symbol may be. >>>>> >>>>> It is the same when distances between symbols aren't equal, e.g., >>>>> 16-APSK, or other oddball, crazy-shaped constellations. The >>>>> individual bit soft-decisions are determined by the slicing pattern. >>>>> >>>>> In something like TCM the patterns are dynamic, i.e., depend on a >>>>> previously decoded symbol in order to increase the distance between >>>>> possible adjacent candidate symbols. If you don't use such a >>>>> scheme you can just slice consistently and still do very well >>>>> performance-wise (this is basically the idea behind BICM). >>>> >>>> >>>>It's the end of the day and my brain wants me to lie down and watch >>>>"Futerama" for a while. Can you point to a paper or tutorial for me >>>>to read? I'd ask for words of one syllable, or that it only use the >>>>ten- hundred* most common words in English, but I guess I can't hope >>>>for that. >>>> >>>>* "Thousand" is not one of the thousand most common words in English. >>> >>> Sorry, I must have stepped away from usenet for a few days...that >>> usually happens during a topic I'm actually participating in for some >>> reason. >>> >>> Which parts are causing the most difficulty? The mapping or the soft >>> decision generation? Both? Neither are very difficult in >>> implementation, usually. For the soft-decision generation simple >>> approximations often perform only negligibly different than optimal, >>> complex. ones. >>> >>> Several of the decent, early papers on BICM cover both in that >>> context, but the general ideas apply to non-BICM systems as well. >>> >>> In this paper Fig. 2.1 shows simple, practical soft-decision "curves" >>> for 16-QAM: >>> >>> http://shannon.cm.nctu.edu.tw/html/thesis/chia-wei.pdf >>> >>> Basically, figure out which input bits make a slope between the >>> decision regions and you're most of the way there. >>> >>> These papers discuss various mapping tricks for high-order modulations >>> in the context of BICM and BICM-ID (Iterative Decoding), but the ideas >>> apply generally to any high-order mapping system. I've found the >>> first reference very useful. >>> >>> Design, Analysis, and Performance Evaluation for BICM-ID with Square >>> QAM Constellations in Rayleigh Fading Channels, Chindapol and >>> Ritcey, IEEE Journal on Selected Areas in Communications, Vol 19 No 5, >>> May, 2001 >>> >>> Optimized Symbol Mappings for Bit-Interleaved Coded Modulation with >>> Iterative Decoding, Schrekenback, Gortz, Hagenauer, Bauch, >>> Proceedings Globecomm 2003. >>> >>> The seminal paper on BICM. See Fig 9 for an example of >>> set-partitioning an 8-PSK constellation: >>> >>> 8PSK Trellis Codes for a Rayleigh Channel, Ephraim Zehavi, IEEE >>> Trans. Comm, Vol 40 No 5, May 1992 >>> >>> A useful follow-up is Caire's paper, which I think I cited earlier >>> somewhere: >>> >>> Bit-Interleave Coded Modulation, Caire, Taricco, Biglieri, IEEE Trans. >>> Info Theory, Vol 44 No 3, May 1998. >>> >>> If any of those references make your head hurt, cherry pick the >>> sections that don't or just move on to the next. The complicated >>> parts are really mostly of academic interest. The important parts are >>> really pretty simple. If we could meet for beer (I wish!) we could >>> hammer the basic ideas out easily before a pint was drained, but since >>> that's not practical at the moment the citations above will have to >>> do. >>> >>> High-order mapping and soft-decision generation are the sort of thing >>> that once you get it, for many systems it can be easily shown >>> completely in a diagram or two. I was looking for examples on the >>> intartubes but didn't see anything suitable. I have some that are, >>> sadly, proprietary else I'd share. If I can find something sharable >>> I will. >> >>I have no problem with the soft decision making -- it's the question of >>whether and how I can map my set of symbols to a set of multi-digit >>binary numbers such that a short-distance ambiguity in the original >>symbol results in fewer ambiguous (or wrong) bits than would happen if a >>symbol were seriously off. > > I'm still guessing what your signal space looks like, but for things > like PSK/QAM, some of the papers I cited talk about the set partitioning > or mapping for good performance in the interleaved case. This can be > done for arbitrary constellations, assuming you actually have a > constellation of some kind. > >>If a symbol is completely trashed and I'm doing soft-decision making >>then the answer's easy: I just have a block of erasures. > > This is one of the things that bit interleaving helps with; a symbol or > a few adjacent symbols that are heavily damaged have a reduced impact on > the ability to properly decode the message.I'm being jumped on to keep delay to a minimum, so a scheme that can identify and cope with burst errors without adding delay is a plus. In the end the customer may well accept a higher block error rate easier than they'll accept the significantly higher delay that it'd take to avoid it by interleaving. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
Tim Wescott <seemywebsite@myfooter.really> wrote:>I'm being jumped on to keep delay to a minimum, so a scheme that can >identify and cope with burst errors without adding delay is a plus. In >the end the customer may well accept a higher block error rate easier >than they'll accept the significantly higher delay that it'd take to >avoid it by interleaving.Is it the worst case delay that needs to be kept to a minimum, or the average delay? And, is there a backchannel? Steve
On Mon, 19 Dec 2016 00:12:59 -0600, Tim Wescott <seemywebsite@myfooter.really> wrote:>On Sun, 18 Dec 2016 19:09:41 +0000, Steve Pope wrote: > >> Tim Wescott <tim@seemywebsite.com> wrote: >> >>>I have no problem with the soft decision making -- it's the question of >>>whether and how I can map my set of symbols to a set of multi-digit >>>binary numbers such that a short-distance ambiguity in the original >>>symbol results in fewer ambiguous (or wrong) bits than would happen if a >>>symbol were seriously off. >>> >>>If a symbol is completely trashed and I'm doing soft-decision making >>>then the answer's easy: I just have a block of erasures. >> >> Why would a symbol be "completely trashed"? Is it a burst-error channel? >> >> On an AWGN channel, the I and Q noise components are independent, >> therefore if the I component is "trashed" there is no reason to predict >> the Q component is trashed. >> >> And also, with AWGN, large-amplitude noise is exponentially less likely >> than small-amplitude noise. In short, with AWGN you do not worry about >> the "completely trashed" case as it is so unlikely -- most raw errors >> are because the noise is just enough to push you over to the next >> constellation point. >> >> But, if it's not an AWGN channel, and you can characterize the channel, >> then your problem has gotten easier, as AWGN is the worst case. >> >> If it's not AWGN, and you cannot characterize it, then you are probably >> "Sync Outta Lock" as far as designing towards it. > >No Q. Sorry, this isn't Star Trek. Or radio. Or even telephony. > >AWGN, baseband, symbols can be anything you want as long as they're >either a fixed magnitude or zero, with a minimum switching time and with >a constant average DC value.Sounds like PSK? Or is it real-valued only so OOK?>I'm currently using a fixed interval (for sanity), with a 4b6b encoding >from the input data stream to the "symbols", which chooses 16 of the 20 >available combinations of six bits that consist of three 1's an three 0's.
On Mon, 19 Dec 2016 13:10:32 -0600, Tim Wescott <seemywebsite@myfooter.really> wrote:>On Sun, 18 Dec 2016 21:18:21 +0000, eric.jacobsen wrote: > >> On Sun, 18 Dec 2016 12:52:59 -0600, Tim Wescott <tim@seemywebsite.com> >> wrote: >> >>>On Sun, 18 Dec 2016 18:39:26 +0000, eric.jacobsen wrote: >>> >>>> On Tue, 13 Dec 2016 19:16:15 -0600, Tim Wescott >>>> <seemywebsite@myfooter.really> wrote: >>>> >>>>>On Wed, 14 Dec 2016 00:32:08 +0000, eric.jacobsen wrote: >>>>> >>>>>> On Tue, 13 Dec 2016 16:48:29 -0600, Tim Wescott >>>>>> <seemywebsite@myfooter.really> wrote: >>>>>> >>>>>>>On Tue, 13 Dec 2016 19:48:04 +0000, Steve Pope wrote: >>>>>>> >>>>>>>> Tim Wescott <tim@seemywebsite.really> wrote: >>>>>>>> >>>>>>>>>I've got a severe constraint on the amount of delay that I can >>>>>>>>>add, >>>>>>>>>so I'm not working in the realm of codes that come closest to the >>>>>>>>>channel capacity -- rather, I'm working in the realm of codes that >>>>>>>>>come closest to the sphere-packing limit for the amount of delay >>>>>>>>>that I'm allowing myself. >>>>>>>> >>>>>>>>>It doesn't seem to be an area where a lot of work has been done. >>>>>>>> >>>>>>>> For the general constraint of code performance vs. clock length >>>>>>>> based on the sphere-packing limit, there is a paper by Fabrizio >>>>>>>> Pollara that I have linked to here before, one result of which is >>>>>>>> that for codeword lengths in the range of several dozen bits, >>>>>>>> conventional BCC's are the best available. >>>>>>>> >>>>>>>> I think this latency constraint makes it even less likely that >>>>>>>> you'll want to use a code over GF(16). Codes over GF(2) >>>>>>>> outperform codes over GF(N), N > 2, for the same codeword length >>>>>>>> -- so there'll have to be something very serindipitous about how >>>>>>>> the transmitted symbols map into code symbols. It would have to >>>>>>>> outperform feeding the MAP values into the binary decoder and >>>>>>>> there isn't a lot of room to improve on that. >>>>>>> >>>>>>>Here is my confusion: >>>>>>> >>>>>>>I am under the impression that the available decoder algorithms take >>>>>>>MAP values on a per-bit basis, but the structure of my symbols is >>>>>>>such that I cannot map my set of symbols to a collection of four >>>>>>>bits such that a "short distance" symbol error reliably results in >>>>>>>fewer bit errors. >>>>>>> >>>>>>>I already gave this example, but for the mapping that I'm currently >>>>>>>using, symbol #3 and symbol #4 are a short distance apart, so it >>>>>>>would be entirely natural for a decoder at the symbol level to come >>>>>>>up with an output that says that these two symbols are equally >>>>>>>likely to have been transmitted, and any other symbol values are >>>>>>>highly unlikely to have been transmitted. >>>>>>> >>>>>>>If I were to take that and turn it into binary with likelihoods, it >>>>>>>would say that bits 0, 1 and 2 are equally likely to be 0 or 1, and >>>>>>>that bit 3 is definitely a 0. >>>>>>> >>>>>>>So either I'm confused about why going from a 2-in-16 decode to an >>>>>>>8- in-16 decode is a good thing, or I'm confused about how this >>>>>>>binary MAP decoding stuff really works, and there is, indeed, a way >>>>>>>to do conditional probabilities between bits. >>>>>> >>>>>> Are you familiar with how soft decision is mapped for bits in a >>>>>> high-order constellation, e.g., 16-QAM? >>>>> >>>>>No, although I have this fuzzy notion that where possible it's mapped >>>>>out in some sort of gray-code order, so that adjacent dots on the >>>>>constellation are only one bit off. I don't think I can do that here, >>>>>although I haven't tried to solve that particular puzzle. >>>>> >>>>>> Even though particular symbols may be the same distance apart, the >>>>>> bit reliabilities for two adjacent symbols depend on the decision >>>>>> regions for the particular bits, >>>>>> not the symbols. The bit reliabilities are determined by the >>>>>> slicing patterns for those bits, not necessarily how far away the >>>>>> next closest symbol may be. >>>>>> >>>>>> It is the same when distances between symbols aren't equal, e.g., >>>>>> 16-APSK, or other oddball, crazy-shaped constellations. The >>>>>> individual bit soft-decisions are determined by the slicing pattern. >>>>>> >>>>>> In something like TCM the patterns are dynamic, i.e., depend on a >>>>>> previously decoded symbol in order to increase the distance between >>>>>> possible adjacent candidate symbols. If you don't use such a >>>>>> scheme you can just slice consistently and still do very well >>>>>> performance-wise (this is basically the idea behind BICM). >>>>> >>>>> >>>>>It's the end of the day and my brain wants me to lie down and watch >>>>>"Futerama" for a while. Can you point to a paper or tutorial for me >>>>>to read? I'd ask for words of one syllable, or that it only use the >>>>>ten- hundred* most common words in English, but I guess I can't hope >>>>>for that. >>>>> >>>>>* "Thousand" is not one of the thousand most common words in English. >>>> >>>> Sorry, I must have stepped away from usenet for a few days...that >>>> usually happens during a topic I'm actually participating in for some >>>> reason. >>>> >>>> Which parts are causing the most difficulty? The mapping or the soft >>>> decision generation? Both? Neither are very difficult in >>>> implementation, usually. For the soft-decision generation simple >>>> approximations often perform only negligibly different than optimal, >>>> complex. ones. >>>> >>>> Several of the decent, early papers on BICM cover both in that >>>> context, but the general ideas apply to non-BICM systems as well. >>>> >>>> In this paper Fig. 2.1 shows simple, practical soft-decision "curves" >>>> for 16-QAM: >>>> >>>> http://shannon.cm.nctu.edu.tw/html/thesis/chia-wei.pdf >>>> >>>> Basically, figure out which input bits make a slope between the >>>> decision regions and you're most of the way there. >>>> >>>> These papers discuss various mapping tricks for high-order modulations >>>> in the context of BICM and BICM-ID (Iterative Decoding), but the ideas >>>> apply generally to any high-order mapping system. I've found the >>>> first reference very useful. >>>> >>>> Design, Analysis, and Performance Evaluation for BICM-ID with Square >>>> QAM Constellations in Rayleigh Fading Channels, Chindapol and >>>> Ritcey, IEEE Journal on Selected Areas in Communications, Vol 19 No 5, >>>> May, 2001 >>>> >>>> Optimized Symbol Mappings for Bit-Interleaved Coded Modulation with >>>> Iterative Decoding, Schrekenback, Gortz, Hagenauer, Bauch, >>>> Proceedings Globecomm 2003. >>>> >>>> The seminal paper on BICM. See Fig 9 for an example of >>>> set-partitioning an 8-PSK constellation: >>>> >>>> 8PSK Trellis Codes for a Rayleigh Channel, Ephraim Zehavi, IEEE >>>> Trans. Comm, Vol 40 No 5, May 1992 >>>> >>>> A useful follow-up is Caire's paper, which I think I cited earlier >>>> somewhere: >>>> >>>> Bit-Interleave Coded Modulation, Caire, Taricco, Biglieri, IEEE Trans. >>>> Info Theory, Vol 44 No 3, May 1998. >>>> >>>> If any of those references make your head hurt, cherry pick the >>>> sections that don't or just move on to the next. The complicated >>>> parts are really mostly of academic interest. The important parts are >>>> really pretty simple. If we could meet for beer (I wish!) we could >>>> hammer the basic ideas out easily before a pint was drained, but since >>>> that's not practical at the moment the citations above will have to >>>> do. >>>> >>>> High-order mapping and soft-decision generation are the sort of thing >>>> that once you get it, for many systems it can be easily shown >>>> completely in a diagram or two. I was looking for examples on the >>>> intartubes but didn't see anything suitable. I have some that are, >>>> sadly, proprietary else I'd share. If I can find something sharable >>>> I will. >>> >>>I have no problem with the soft decision making -- it's the question of >>>whether and how I can map my set of symbols to a set of multi-digit >>>binary numbers such that a short-distance ambiguity in the original >>>symbol results in fewer ambiguous (or wrong) bits than would happen if a >>>symbol were seriously off. >> >> I'm still guessing what your signal space looks like, but for things >> like PSK/QAM, some of the papers I cited talk about the set partitioning >> or mapping for good performance in the interleaved case. This can be >> done for arbitrary constellations, assuming you actually have a >> constellation of some kind. >> >>>If a symbol is completely trashed and I'm doing soft-decision making >>>then the answer's easy: I just have a block of erasures. >> >> This is one of the things that bit interleaving helps with; a symbol or >> a few adjacent symbols that are heavily damaged have a reduced impact on >> the ability to properly decode the message. > >I'm being jumped on to keep delay to a minimum, so a scheme that can >identify and cope with burst errors without adding delay is a plus. In >the end the customer may well accept a higher block error rate easier >than they'll accept the significantly higher delay that it'd take to >avoid it by interleaving.Yeah, the interleaving certainly does affect delay, but so will any decent coding system. If you want gain, you need the code to traverse a lot of bits (bit diversity), so that's a natural tradeoff, anyway. A Viterbi decoder with no interleaving will likely be as good as you can do, and TCM will allow higher-order modulation without really adding significant delay. TCM does want a relatively tame channel, though, but as long as your channel isn't too crazy it would probably work just fine.
One problem with adding a convolutional code to this 4b/6b modulation is that you now have error-propogation that did not exist before. So you may actually want something like a Reed-Solomon code, such as a (15,k) code over GF(16), with k chosen from 13, 11, 9 ... with some sort of mixed error/erasure decoding strategy that takes some advantage of the avilable soft decisions. If latency requirements permit, block-interleaving this code to depth 2 may be wise. Those soft decisions could be formed by brute-forse ML in this case. Because of your parameters there are probably no Goppa / Hermitian / Algebraic Geometry codes that are of any use. Steve
On Mon, 19 Dec 2016 20:13:46 +0000, eric.jacobsen wrote:> On Mon, 19 Dec 2016 00:12:59 -0600, Tim Wescott > <seemywebsite@myfooter.really> wrote: > >>On Sun, 18 Dec 2016 19:09:41 +0000, Steve Pope wrote: >> >>> Tim Wescott <tim@seemywebsite.com> wrote: >>> >>>>I have no problem with the soft decision making -- it's the question >>>>of whether and how I can map my set of symbols to a set of multi-digit >>>>binary numbers such that a short-distance ambiguity in the original >>>>symbol results in fewer ambiguous (or wrong) bits than would happen if >>>>a symbol were seriously off. >>>> >>>>If a symbol is completely trashed and I'm doing soft-decision making >>>>then the answer's easy: I just have a block of erasures. >>> >>> Why would a symbol be "completely trashed"? Is it a burst-error >>> channel? >>> >>> On an AWGN channel, the I and Q noise components are independent, >>> therefore if the I component is "trashed" there is no reason to >>> predict the Q component is trashed. >>> >>> And also, with AWGN, large-amplitude noise is exponentially less >>> likely than small-amplitude noise. In short, with AWGN you do not >>> worry about the "completely trashed" case as it is so unlikely -- most >>> raw errors are because the noise is just enough to push you over to >>> the next constellation point. >>> >>> But, if it's not an AWGN channel, and you can characterize the >>> channel, then your problem has gotten easier, as AWGN is the worst >>> case. >>> >>> If it's not AWGN, and you cannot characterize it, then you are >>> probably "Sync Outta Lock" as far as designing towards it. >> >>No Q. Sorry, this isn't Star Trek. Or radio. Or even telephony. >> >>AWGN, baseband, symbols can be anything you want as long as they're >>either a fixed magnitude or zero, with a minimum switching time and with >>a constant average DC value. > > Sounds like PSK? Or is it real-valued only so OOK?Real valued only. It's definitely the protocol of choice for the librarian at Unseen University. -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
On Mon, 19 Dec 2016 19:34:39 +0000, Steve Pope wrote:> Tim Wescott <seemywebsite@myfooter.really> wrote: > >>I'm being jumped on to keep delay to a minimum, so a scheme that can >>identify and cope with burst errors without adding delay is a plus. In >>the end the customer may well accept a higher block error rate easier >>than they'll accept the significantly higher delay that it'd take to >>avoid it by interleaving. > > Is it the worst case delay that needs to be kept to a minimum, > or the average delay? And, is there a backchannel?It's for down-hole communication. Worst-case delay is what needs to be kept to a minimum, but the customer feedback that I get after any time has passed is "no delay! no delay at all!!", and then I have to re- explain the basics of coding theory. There's sort of a backchannel, but only by turning off the pumps that power the down-hole machinery, and it's expensive. The basic plan is to try to anticipate how difficult the communications are on the well, and set things up in the equipment before it goes down, however, failing that, they can change parameters to a very limited extent by powering down the pumps for varying amounts of time (at great expense, and much irritation). -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
