Rob Gaddi <rgaddi@highlandtechnology.invalid> writes:> On 03/24/2017 07:19 PM, Randy Yates wrote: >> Eric <Eric@spamspamorspam.com> writes: >> >>> Just curious about how much Linux is being used for embedded DSP apps. >>> If you're using it, what are your normal development tools? >> >> Eric, >> >> Lately I've been doing non-DSP things like equipment control libraries >> (has anyone heard of BACnet?) lately using linux for both the >> development as well as the final target. >> >> Folks will probably shake their heads, but my normal development tools >> are emacs, gdb, and gnumake. I don't even have a JTAG or IDE, other than >> gdb running inside emacs. Since the target OS is linux and has a network >> interface, I have been able to use gdbserver and gdb to debug on the >> target when necessary. Most of the time, due to the availability of >> compatible hardware on my desktop system, I build and test on my desktop >> linux, then only retarget the embedded linux for the final "does it >> still work" step. > > That's just stupid. Why would you want to use time-tested tools that > have been generally stable for well over a decade when there's a > perennial stream of latest and greatest tools that you can invest time > and energy into learning only to find the project stalled with > hundreds of logged bugs and no workarounds?Rob, Rob, Rob..., I've always loved biting irony. As Bartles and Jaymes used to say, "Thank you for support!" -- Randy Yates, DSP/Embedded Firmware Developer Digital Signal Labs http://www.digitalsignallabs.com
Anyone using Linux?
Started by ●March 14, 2017
Reply by ●March 27, 20172017-03-27
spope33@speedymail.org (Steve Pope) writes:> Rob Gaddi <rgaddi@highlandtechnology.invalid> wrote: > >>On 03/24/2017 07:19 PM, Randy Yates wrote: > >>> Eric <Eric@spamspamorspam.com> writes: >>> Folks will probably shake their heads, but my normal development tools >>> are emacs, gdb, and gnumake. I don't even have a JTAG or IDE, other than >>> gdb running inside emacs. Since the target OS is linux and has a network >>> interface, I have been able to use gdbserver and gdb to debug on the >>> target when necessary. Most of the time, due to the availability of >>> compatible hardware on my desktop system, I build and test on my desktop >>> linux, then only retarget the embedded linux for the final "does it >>> still work" step. > >>That's just stupid. Why would you want to use time-tested tools that >>have been generally stable for well over a decade when there's a >>perennial stream of latest and greatest tools that you can invest time >>and energy into learning only to find the project stalled with hundreds >>of logged bugs and no workarounds? > > Right. > > I've never been drawn towards using an IDE for the C, C++ and Verilog > projects I've worked on. The text based and command line tools > are very capable and reliable. > > Similarly I somewhat dislike (and have lower productivity) using Simulink > instead of or in addition to Matlab, but that's a trickier trade-off. > > SteveIt seems there is a sort of "law of physics" that productivity is proportional to the complexity of/time to learn the tools. -- Randy Yates, DSP/Embedded Firmware Developer Digital Signal Labs http://www.digitalsignallabs.com
