Hi folks, sorry if I'll be asking a dumb question :). I'd like to build a 6dB/oct crossover (with variable number of bands and crossover points). First order butterworth LP and HP filters seem to be working fine and provide nearly flat magnitude response IF the crossover point isn't high enough, hence close to the nyquist, then it starts forming something that looks like a high-shelf of +6dB. I assume this is caused by the filter shape not being accurate enough close to nyquist, correct? (seems that oversampling avoids the problem a bit) I'm asking since this is a bit of a surprise to me, since higher order crossovers I have implemented don't seem to "care" about sampling rate and are always perfectly flat, so I'm not sure if I didn't mess something up. If my assumption is correct, is there a way to mitigate the problem? It's not such a big deal, but still... Thanks a lot as always! jungledmnc --------------------------------------- Posted through http://www.DSPRelated.com
6dB/oct butterworth crossover doesn't have flat response
Started by ●August 17, 2017
Reply by ●August 17, 20172017-08-17
>Hi folks, > >sorry if I'll be asking a dumb question :). I'd like to build a 6dB/oct >crossover (with variable number of bands and crossover points). First >order butterworth LP and HP filters seem to be working fine and provide >nearly flat magnitude response IF the crossover point isn't high enough, >hence close to the nyquist, then it starts forming something that looks >like a high-shelf of +6dB. > >I assume this is caused by the filter shape not being accurate enough >close to nyquist, correct? (seems that oversampling avoids the problem a >bit) > > ... >If my assumption is correct, is there a way to mitigate the problem?It's>not such a big deal, but still... > >Thanks a lot as always! >jungledmnc >--------------------------------------- >Posted through http://www.DSPRelated.comI quickly made a tweaked 1st order LPF (MZT) implementation you could try. It's not perfect but at least improved magnitude response. Here are the Octave code and couple comparison plots: % OCTAVE PACKAGES ----------------------------------- pkg load signal % --------------------------------------------------- fs=44100; fc=3000; Q=0.7071; % Analog -------------------------------------------- w0 = 2*pi*fc; Analogb = 1; Analoga = [1 w0]; % BLT ----------------------------------------------- w0 = 2*pi*fc/fs; BLTb0 = sin(w0); BLTb1 = sin(w0); BLTa0 = cos(w0) + sin(w0) + 1; BLTa1 = sin(w0) - cos(w0) - 1; BLTa = [BLTa0 BLTa1]; BLTb = [BLTb0 BLTb1]; % MZT ----------------------------------------------- p1 = exp(-1.0/(fs*(1/(2 * pi * fc)))); % pole z1 = 0.0; % zero MZTb0 = 1.0; MZTb1 = -z1 MZTa0 = 1.0; MZTa1 = -p1; MZTa = [MZTa0 MZTa1]; MZTb = [MZTb0 MZTb1]; % MZT (tweaked) ------------------------------------- p1 = exp(-1.0/(fs*(1/(2 * pi * fc)))); % pole z1 = atan(-7.5*pi/180); % zero MZTob0 = 1.0; MZTob1 = -z1 MZToa0 = 1.0; MZToa1 = -p1; MZToa = [MZToa0 MZToa1]; MZTob = [MZTob0 MZTob1]; % IIM ----------------------------------------------- w0=2*pi*(fc/fs); Q=1/Q; aa = [Q/w0 1] p = roots(aa) % analog poles IIMa0=1; IIMa1=-exp(p(1)); IIMb0 = 1.0; IIMb1 = 0; IIMa = [IIMa0 IIMa1]; IIMb = [IIMb0 IIMb1]; % plot ---------------------------------------------- Analog = tf(Analogb, Analoga); Analog = Analog/dcgain(Analog); BLT=tf(BLTb, BLTa, 1/fs); BLT=BLT/dcgain(BLT); MZT=tf(MZTb, MZTa, 1/fs); MZT=MZT/dcgain(MZT); MZTo=tf(MZTob, MZToa, 1/fs); MZTo=MZTo/dcgain(MZTo); IIM=tf(IIMb, IIMa, 1/fs); IIM=IIM/dcgain(IIM); wmin = 2 * pi * 20; % 20Hz wmax = 2 * pi * ((fs/2.0) - (fs/2 - 20000)); bode(Analog, 'r', BLT, 'c', MZT, 'b', MZTo, '--', IIM, 'k', {wmin, wmax}); legend('Analog', 'BLT', 'MZT', 'MZT optimized', 'IIM'); Comparison between tweaked MZT and few other fc=300Hz https://s11.postimg.org/im2wdswhv/1storder_LPFcomparison300.png fc=3000Hz https://s11.postimg.org/i6rmksakj/1storder_LPFcomparison.png fc=10000Hz https://s11.postimg.org/umocej3wj/1storder_LPFcomparison10k.png --------------------------------------- Posted through http://www.DSPRelated.com
Thank you! Now, I'm not an Octave/Matlab user, but I'd deal with it. But for now I found an interesting thing - it is actually enough to perform a gain on the high band. That makes me thing that maybe I indeed have something wrong, on the other hand the gain depends on the sampling frequency, so I'm a bit puzzled. Anyways with a well chosen gain I can get nearly flat magnitude response. I'd just like to figure out a formula for the gain and know actually how is that possible :). --------------------------------------- Posted through http://www.DSPRelated.com
Thank you again! The improved MZT version actually helps a lot! --------------------------------------- Posted through http://www.DSPRelated.com
Reply by ●August 18, 20172017-08-18
>Thank you again! The improved MZT version actually helps a lot! >--------------------------------------- >Posted through http://www.DSPRelated.comThanks. My tweaking method was not complete (in this case fc was not within calculation of the z1) but only showed what you can to do to tweak MZT (and IIM) based filters. If you want better results for magnitude response correction and you just need coefficients for your project then here's Octave/Matlab code for MZTi https://www.kvraudio.com/forum/viewtopic.php?p=5072902#p5072902 --------------------------------------- Posted through http://www.DSPRelated.com
>>Thank you again! The improved MZT version actually helps a lot! >>--------------------------------------- >>Posted through http://www.DSPRelated.com > >Thanks. My tweaking method was not complete (in this case fc was not >within calculation of the z1) but only showed what you can to do totweak>MZT (and IIM) based filters. > >If you want better results for magnitude response correction and youjust>need coefficients for your project then here's Octave/Matlab code forMZTi> > >https://www.kvraudio.com/forum/viewtopic.php?pP72902#p5072902 >--------------------------------------- >Posted through http://www.DSPRelated.comHmm... I forgot that MZTi implementation behind the link is for 2nd order LP filter ... --------------------------------------- Posted through http://www.DSPRelated.com
I was actually quite surprised you set the z1 to constant, but anyways the idea is there, that's the main thing ;). --------------------------------------- Posted through http://www.DSPRelated.com
Reply by ●August 19, 20172017-08-19
>I was actually quite surprised you set the z1 to constant, but >anywaysthe idea is there, that's the main thing ;). It worked good enough as a constant there so didn't go for finding the best fit formula .... BTW, if you want coefficients to give even more accurate magnitude responses for 6dB/oct LPF ... I'd recommend MIM (Magnitude Invariance Method) method. I plotted 1st - 4th order filters against analog prototype filter ... : Responses: https://s11.postimg.org/llgdiq2v7/mimplots.png Errors: https://s11.postimg.org/ybklvtatf/MIMerrors.png --------------------------------------- Posted through http://www.DSPRelated.com
>Responses: >https://s11.postimg.org/llgdiq2v7/mimplots.png > >Errors: >https://s11.postimg.org/ybklvtatf/MIMerrors.pngSomething wrong with the images ... here are new ones: http://postimg.org/image/y1twb98s9/ http://postimg.org/image/sc92d7d89/ --------------------------------------- Posted through http://www.DSPRelated.com
