>> Could you be more specific about the "duality"? I may be missing some >part >> of information here. > >You can interpolate between FFT bins or you can interpolate betweensamples.>The mathematics are the same, only the domain changes.Aaaha, got it, got a little confused.>> As for linear-phase - if we assume there won't be any filtering (the >> oversampling itself isn't filtering as it doesn't change the spectrum >> content), then if we find the actual true peaks, then this should bethe>> real maximum for any oversampling rate imho and no overshoots canhappen.> >If you don't filter then your inserted samples are all zero-valued. That >interpolation will be the same as if you didn't upsample at all.Ok, yes, but we assume a steep linear-phase filter close to nyquist, where there won't be much anyways. But you are right, it could probably overshoot indeed, maybe it's not worth exploring after all... --------------------------------------- Posted through http://www.DSPRelated.com
Finding maximum of sinc in 0..1
Started by ●September 5, 2017
Reply by ●September 6, 20172017-09-06
> Has anyone attempted to do it analytically (hence hopefully efficiently)?I don't think an analytic approach is going to be very successful. Even if you're facing just a single nonzero sample, trying to compute the extrema of sinc(t) leads to the equation tan(t)=t, which AFAIK can only be solved numerically.> I started messing with it and the derivatives (for the classic f' == 0) > are just way too ugly. Numeric approach could work, but the accuracy would > be lower again and it could take way too much CPU power.On the numerical front you could try doing something like a golden section search (https://en.wikipedia.org/wiki/Golden-section_search). I'm not sure if the extra accuracy you could get this way would be worth the CPU expense though. -Ethan
