Hi, When I try to design an equiripple FIR with matlab, the script and parameters at the end of this message results in a satisfying filter. (0 dB at DC) However, when I decrease Fpass to 120, the passband has a (flat) DC attenuation +/- 33dB. It seems that the passband suffers increasing attenuation when Fpass is decreased below some threshold. Has anyone an explanation for this? thanks in advance, Fs = 7200; % Sampling Frequency Fpass = 480; % Passband Frequency Fstop = 3000; % Stopband Frequency Dpass = 0.06; % Passband Ripple Dstop = 1e-007; % Stopband Attenuation dens = 20; % Density Factor % Calculate the order from the parameters using FIRPMORD. [N, Fo, Ao, W] = firpmord([Fpass, Fstop]/(Fs/2), [1 0], [Dpass, Dstop]); % Calculate the coefficients using the FIRPM function. b = firpm(N, Fo, Ao, W, {dens}); Hd = dfilt.dffir(b);
matlab firpm
Started by ●June 14, 2005
Reply by ●June 14, 20052005-06-14
in article 1118766437.563081.50000@g47g2000cwa.googlegroups.com, homerbebe@yahoo.com at homerbebe@yahoo.com wrote on 06/14/2005 12:27:> b = firpm(N, Fo, Ao, W, {dens});did they change the name of remez() to firpm()? good for MathWorks! now if only they'll allow us array indices that are less than 1. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●June 15, 20052005-06-15
<homerbebe@yahoo.com> wrote in message news:1118766437.563081.50000@g47g2000cwa.googlegroups.com...> Hi, > > When I try to design an equiripple FIR with matlab, the script and > parameters at the end of this message results in a satisfying filter. > (0 dB at DC) > However, when I decrease Fpass to 120, the passband has a (flat) DC > attenuation +/- 33dB.I have no explanation for why the passband would vary over 66dB (+/-33dB) if the passband is set from zero to 120Hz. But, I didn't follow the method very well. If the filter is of length 7200/120=60 then 120Hz is about as good as it's going to do. To do better than 120Hz passband width, a filter longer than 60 is necessary. Does this maybe hint at what's going on? I can't tell.... fred
