Hi all, does anyone know about any freely available library in C++ to obtain mp3 data stream? I am working for a project on audio classification and mp3 data is stream is required. I am working on windows platform. Regards Yoshita nanda This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Extract mp3 audio data
Started by ●June 15, 2005
Reply by ●June 16, 20052005-06-16
Hi, If the mp3 data is in a file then it's quite simple.. <snip> int c; FILE* file = fopen ("mp3file.mp3", "rb"); while (!feof(file)) { c = fgetc(file); /* do something with c here */ } </snip> Look in the recent thread on image encryption and follow the URL I posted. I believe that it contains a bunch of information that will help you. A
Whoops, my bad. I didn't realise I'd clicked out of sci.image.processing I should have said "...look in sci.image-processing for a recent image encryption thread and follow the link I posted..." There are a few things that will give you MP3 streams, but you don't give us much to go on. Try Google. That always helps. You should find MAD and Lame as a bare minimum. What are you trying to achieve? Do you have files on disk or do you need to get the data from a soundcard first? Why would you want mp3 to classify a data stream? Wouldn't the raw data be more useful? A
