>sunderam wrote: >> The FT of ima for this signal i would calc >> 1.mean intensity >> 2.std deviation >> Sunderam >> ge would give me a signal. > >Neither intensity nor its standard deviation is measured in the >frequency domain. For that, you want not the FT, but the original >signal. > >What is "ge"? > >Jerry > >How do i get the original signal given an image? I though the FT of image would give me the original signal. ge was the remaining part of ima which should have been image. I m just calculating the contrast. This paragraph is taken from a paper about image quality assesment by using the human visual system. The following paragraph is what i m trying to achive " Suppose x and y are two non� negative image signals, which have been aligned with each other (e.g., spatial patches extracted from each image). If we consider one of the signals to have perfect quality, then the similarity measure can serve as a quantitative measure� ment of the quality of the second signal. The system separates the task of similarity measurement into three comparisons: luminance, contrast and structure. First, the luminance of each signal is compared. Assuming discrete signals, this is estimated as the mean intensity: The luminance comparison function l(x, y) is then a function of � x and � y Second, we remove the mean intensity from the signal. In discrete form, the resulting signal x-� x corresponds to the projection of vector x onto the hyperplane defined by the formula. We use the standard deviation (the square root of variance) as an estimate of the signal contrast. An unbiased estimate in discrete form is given by the formula" Sunderam This message was sent using the Comp.DSP web interface on www.DSPRelated.com
FFTW, Imlib & OpenCV
Started by ●June 18, 2005
Reply by ●June 21, 20052005-06-21
You still have no clue, and you don't bother to take our advice. Why should we bother? Ciao, Peter K.
Hello Peter, You had mentioned that contrast could be calculated using I(x,y,p). I agree to that part.. Can you please tell me why does the author say two nonnegatie signals rather than just talking about I(x,y,p).There must be some premise behind using the term signal. I m still trying to understand and comprehend why use the "signal" if its out of context. Because i had no clue thats why i posted my query here otherwise would not have. Sunderam>You still have no clue, and you don't bother to take our advice. Why >should we bother? > >Ciao, > >Peter K. > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●June 22, 20052005-06-22
sunderam wrote:> Hello Peter, > > You had mentioned that contrast could be calculated using I(x,y,p). I > agree to that part.. > Can you please tell me why does the author say two nonnegatie signals > rather than just talking about I(x,y,p).There must be some premise behind > using the term signal. I m still trying to understand and comprehend why > use the "signal" if its out of context.Negative brightness doesn't exist. Therefore, all legitimate intensity samples are non-negative. All physical weights are non-negative too.> Because i had no clue thats why i posted my query here otherwise would not > have. > Sunderam > > >You still have no clue, and you don't bother to take our advice. Why > >should we bother?Sunderam, These quoted messages would be easier to read if you put your replies either after the material you reply to or intersperced within it, as appropriate. It's clear that you have no clue. The discouraging part is that you have a fixed false idea that no advice -- Peter K's term -- can correct. Here it is again. Read it slowly: Unless you consider the light focused on a sensor, or a document in a scanner, you never work with an image. Instead, you work with a signal that represents it -- encodes it, if you like. A color image is represented by three intensities at each point. (Various sets of three are sufficient.) These intensities suffice to determine contrast, mean intensity and most other measures of the image that interest you. They are a signal, not an image. Since the signal represents an image, it is often erroneously called an image, just as the bits on a CD and the wavy grooves on a vinyl recording are often called music. The 2D FT of the intensities show another aspect of the image, a useful one, but not one that helps with the qualities you want to assess. Get over it! Jerry
I get it thanks for all the help sunderam> > >sunderam wrote: >> Hello Peter, >> >> You had mentioned that contrast could be calculated using I(x,y,p). I >> agree to that part.. >> Can you please tell me why does the author say two nonnegatie signals >> rather than just talking about I(x,y,p).There must be some premisebehind>> using the term signal. I m still trying to understand and comprehendwhy>> use the "signal" if its out of context. > >Negative brightness doesn't exist. Therefore, all legitimate intensity >samples are non-negative. All physical weights are non-negative too. > >> Because i had no clue thats why i posted my query here otherwise wouldnot>> have. >> Sunderam >> >> >You still have no clue, and you don't bother to take our advice. Why >> >should we bother? > >Sunderam, > >These quoted messages would be easier to read if you put your replies >either after the material you reply to or intersperced within it, as >appropriate. > >It's clear that you have no clue. The discouraging part is that you >have a fixed false idea that no advice -- Peter K's term -- can >correct. Here it is again. Read it slowly: > >Unless you consider the light focused on a sensor, or a document in a >scanner, you never work with an image. Instead, you work with a signal >that represents it -- encodes it, if you like. A color image is >represented by three intensities at each point. (Various sets of three >are sufficient.) > >These intensities suffice to determine contrast, mean intensity and >most other measures of the image that interest you. They are a signal, >not an image. Since the signal represents an image, it is often >erroneously called an image, just as the bits on a CD and the wavy >grooves on a vinyl recording are often called music. > >The 2D FT of the intensities show another aspect of the image, a useful >one, but not one that helps with the qualities you want to assess. Get >over it! > >Jerry > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Can you please give me a pointer where i could find the documentation about the contrast calculation you mentioned. I can get my facts straight that way Sunderam>] Then my question, is there a method to represent >] an image in terms of signal in frequency domain.? > >Why do you want to? > >If you're trying to work out the contrast of an image, and you have the >image pixel values, then you don't need to do much at all. > >If you have an image, then the pixel values are usually represented as: > >I(x,y,p) = 0 to 255 > >where "x" is the x position, >"y" is the y position, and >"p" is the plane (e.g. red, green, blue, alpha). > >It is this I(x,y,p) that you need to calculate the contrast. > >] And how can i find contrast for image of >] any format, not restricted to jpeg formats only. > >Why do you think that a contrast calculation depends on the image >format? > >All image storage formats need, eventually, to reconstitute the signal >into the I(x,y,p) information. > >You appear to be very confused. Please keep asking questions so we can >sort out your confusion. > >Start with the basics: you don't appear to comprehend image formats >yet. Get that right before moving on to anything else more >complicated... you need to crawl before you can run. > >Ciao, > >Peter K. > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
sunderam wrote:> Hello Peter, > > You had mentioned that contrast could be calculated using I(x,y,p). I > agree to that part.. > Can you please tell me why does the author say two nonnegatie signals > rather than just talking about I(x,y,p).There must be some premise behind > using the term signal. I m still trying to understand and comprehend why > use the "signal" if its out of context.Um, I think you're making a mountain out of a molehill. I(x,y,p) IS the "signal" you're looking for.> Because i had no clue thats why i posted my query here otherwise would not > have.Ciao, Peter K.
Can you please give me a pointer where i could find the documentation about the contrast calculation you mentioned. I can get my facts straight that way Thanks Sunderam>sunderam wrote: >> Hello Peter, >> >> You had mentioned that contrast could be calculated using I(x,y,p). I >> agree to that part.. >> Can you please tell me why does the author say two nonnegatie signals >> rather than just talking about I(x,y,p).There must be some premisebehind>> using the term signal. I m still trying to understand and comprehendwhy>> use the "signal" if its out of context. > >Um, I think you're making a mountain out of a molehill. I(x,y,p) IS >the "signal" you're looking for. > >> Because i had no clue thats why i posted my query here otherwise wouldnot>> have. > >Ciao, > >Peter K. > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●June 30, 20052005-06-30
"sunderam" <jpothara@uccs.edu> writes:>How do i get the original signal given an image? I though the FT of image >would give me the original signal.In image processing, the image *is* the signal. You don't need to (and in general cannot) get the original light flux in the scene.>" Suppose x and y are two non� negative image signals, which have been >aligned with each other (e.g., spatial patches extracted from each image). >If we consider one of the signals to have perfect quality, then >the similarity measure can serve as a quantitative measure� >ment of the quality of the second signal.Just replace "image signals" with "images" and "signal" with "image". Then it should make sense to you. Dave
