Hi ... I was working on the C6414 DSP (fixed point) and needed an sqrt approximation - I finally found a really nice solution (but I have trouble understanding it :-) my assumptions: - fixed point representation - no division ... too slow for me - approximation is fine ... sqrt(a^2 + b^2) ~ max(a,b) + .5min(a,b) was not possible in this case ... my solution: The processor has an asm instruction called NORM, it gives me the number of "redundant bits" of the argument ... the result can be expressed as something like _norm(x) = 31 - floor(log2(x)) ... this gives me the exponent of my input x next idea: halven the exponent my shifting ... x >> exp/2 (certainly the mantissa is wrong now) somehow I tried to shift 1 << exp/2 and finally something like sqrt(2) << (exp+1)/2 (that also is wrong by the same amount, different sign!) the average of both values turned out to be off by a constant factor of sqrt(sqrt(2)) for even exponent (and sqrt(sqrt(1/2)) for odd exp) (so this is just one multiplication by a constant factor) the final result looks like a piecewise linear approximation with an relative error of 2-3% at most with just 10 asm instructions. the question: I found most of the constants like sqrt(2) and sqrt(sqrt(2)) by playing around and the idea of "hey - a little above 1.4 looks like sqrt(2)!" ... no systematics involved I'm not familiar with discrete arithmetics - how can you analyze this? why is it working? is this new? couldn't find anything similar anywhere! bye, Michael here is some matlab code displaying the intermediate steps. clear all; close all; mval = 2.^8; % fixed point shift value num = 512; % number of inputs x = (num:-1:0); % input values figure; hold on; opt = sqrt(x./mval).*mval; plot(opt./mval, 'g:'); % optimum result ropt = floor(opt+.5); plot(ropt./mval, 'b:'); % rounded optimum exp = floor(log2(x)) - 6; %% exp = 31 - norm(x) outp = floor(x .* (2 .^ floor(-exp/2))); %% x = x >> exp/2 outp2 = floor(91 .* (2 .^ floor(exp/2))); %% x = sqrt(2) << exp/2 plot(outp./mval.*2, 'r-'); plot(outp2./mval.*2, 'r:'); outp3 = outp + outp2; % average both results, 1/2 is hidden above plot(outp3./mval, 'b-'); % correction of even / odd pixels - mult by constant even = floor(exp/2).*2 ~= exp; outp3(find(even)) = outp3(find(even)) .* 303 ./mval; %% floor(sqrt(sqrt(2)) .* mval) outp3(find(1-even)) = outp3(find(1-even)) .* 214 ./mval; %% floor(sqrt(sqrt(1/2)) .* mval) outp3 = floor(outp3); % abs error display figure; hold on; plot( (outp3-opt)./mval, 'r:'); plot((ropt-opt)./mval, 'b'); % rel error display figure; hold on; plot( (outp3-opt)./opt, 'r:'); plot((ropt-opt)./opt, 'b');
sqrt on C6414 DSP
Started by ●July 1, 2005
Reply by ●July 1, 20052005-07-01
Michael Schoeberl wrote:> Hi ... > > I was working on the C6414 DSP (fixed point) and needed an sqrt > approximation - I finally found a really nice solution (but I have > trouble understanding it :-) > > my assumptions: > - fixed point representation > - no division ... too slow for me > - approximation is fine ... sqrt(a^2 + b^2) ~ max(a,b) + .5min(a,b) > was not possible in this case ... > > > > my solution: > The processor has an asm instruction called NORM, it gives me the number > of "redundant bits" of the argument ... the result can be expressed as > something like _norm(x) = 31 - floor(log2(x)) > ... this gives me the exponent of my input xWhat makes a bit "redundant"?> next idea: halven the exponent my shifting ... x >> exp/2 > (certainly the mantissa is wrong now)What mantissa? Didn't you write "fixed point"? I see the line "exp = floor(log2(x)) - 6;" below. How do you take a fixed-point log? ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>> [NORM function]> What makes a bit "redundant"?okay - this need more details ... the DSP has a one cycle instruction (called NORM) that counts the bits - starting from the left to the first change. I pass a 32 bit integer and get get back the number of leading zeros ... (works for ned number in 2 complement as well so TI calls the bits from the left 'redundant') the output of that instruction is similar to 31 - floor(log2(x))> What mantissa? Didn't you write "fixed point"? I see the line > "exp = floor(log2(x)) - 6;" below. How do you take a fixed-point log?with the help of this special assembly instruction ... bye, Michael
> on the C6414 DSP (fixed point) ... sqrt I got a C6416 and the instruction set reference says the NORM instruction is available on all C6000 DSPs from TI. oh man - it's time for the long weekend! bye, Michael
Michael Schoeberl wrote:> >> [NORM function] > >> What makes a bit "redundant"? > > > okay - this need more details ... > > the DSP has a one cycle instruction (called NORM) that counts > the bits - starting from the left to the first change. > > I pass a 32 bit integer and get get back the number of > leading zeros ... (works for ned number in 2 complement as well so TI > calls the bits from the left 'redundant') > > > the output of that instruction is similar to > 31 - floor(log2(x))That's an interesting instruction. What does it do with negative numbers?>> What mantissa? Didn't you write "fixed point"? I see the line >> "exp = floor(log2(x)) - 6;" below. How do you take a fixed-point log? > > > with the help of this special assembly instruction ...Thanks. I understand it all but the mantissa part. What is a fixed-point mantissa? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> Michael Schoeberl wrote: > >> >> [NORM function] >> >>> What makes a bit "redundant"? >> >> >> >> okay - this need more details ... >> >> the DSP has a one cycle instruction (called NORM) that counts >> the bits - starting from the left to the first change. >> >> I pass a 32 bit integer and get get back the number of >> leading zeros ... (works for ned number in 2 complement as well so TI >> calls the bits from the left 'redundant') >> >> >> the output of that instruction is similar to >> 31 - floor(log2(x)) > > > That's an interesting instruction. What does it do with negative numbers? > >>> What mantissa? Didn't you write "fixed point"? I see the line >>> "exp = floor(log2(x)) - 6;" below. How do you take a fixed-point log? >> >> >> >> with the help of this special assembly instruction ... > > > Thanks. I understand it all but the mantissa part. What is a fixed-point > mantissa? >If TI uses the same nomenclature as Analog Devices, the mantissa is what's left after you shift the number up by the bits counted by the NORM instruction. Analog Devices has designed their normalization instruction (which may or may not be NORM; I can't remember) so that it can be vectorized -- this lets you do block floating point calculations which makes oodles of sense in a vector processing environment. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott wrote:> Jerry Avins wrote: > >> Michael Schoeberl wrote: >> >>> >> [NORM function] >>> >>>> What makes a bit "redundant"? >>> >>> >>> >>> >>> okay - this need more details ... >>> >>> the DSP has a one cycle instruction (called NORM) that counts >>> the bits - starting from the left to the first change. >>> >>> I pass a 32 bit integer and get get back the number of >>> leading zeros ... (works for ned number in 2 complement as well so TI >>> calls the bits from the left 'redundant') >>> >>> >>> the output of that instruction is similar to >>> 31 - floor(log2(x)) >> >> >> >> That's an interesting instruction. What does it do with negative numbers? >> >>>> What mantissa? Didn't you write "fixed point"? I see the line >>>> "exp = floor(log2(x)) - 6;" below. How do you take a fixed-point log? >>> >>> >>> >>> >>> with the help of this special assembly instruction ... >> >> >> >> Thanks. I understand it all but the mantissa part. What is a >> fixed-point mantissa? >> > If TI uses the same nomenclature as Analog Devices, the mantissa is > what's left after you shift the number up by the bits counted by the > NORM instruction. Analog Devices has designed their normalization > instruction (which may or may not be NORM; I can't remember) so that it > can be vectorized -- this lets you do block floating point calculations > which makes oodles of sense in a vector processing environment.Thanks. Now I can take a closer look at the code. To code an accurate square root, compute 1/sqrt(x) iteratively; that can be done with shifts and multiplies. When done, multiply by x. For sqrt(x^2+y^2), there's a quicker way than summing the squares and rooting. I first read it in Jon Bentley's Programming Pearls column and it was discussed here a couple of years ago. Again go for the reciprocal on machines with fast multiply and slow divide. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> Tim Wescott wrote: > >> Jerry Avins wrote: >> >>> Michael Schoeberl wrote: >>> >>>> >> [NORM function] >>>> >>>>> What makes a bit "redundant"? >>>> >>>> >>>> >>>> >>>> >>>> okay - this need more details ... >>>> >>>> the DSP has a one cycle instruction (called NORM) that counts >>>> the bits - starting from the left to the first change. >>>> >>>> I pass a 32 bit integer and get get back the number of >>>> leading zeros ... (works for ned number in 2 complement as well so >>>> TI calls the bits from the left 'redundant') >>>> >>>> >>>> the output of that instruction is similar to >>>> 31 - floor(log2(x)) >>> >>> >>> >>> >>> That's an interesting instruction. What does it do with negative >>> numbers? >>> >>>>> What mantissa? Didn't you write "fixed point"? I see the line >>>>> "exp = floor(log2(x)) - 6;" below. How do you take a fixed-point log? >>>> >>>> >>>> >>>> >>>> >>>> with the help of this special assembly instruction ... >>> >>> >>> >>> >>> Thanks. I understand it all but the mantissa part. What is a >>> fixed-point mantissa? >>> >> If TI uses the same nomenclature as Analog Devices, the mantissa is >> what's left after you shift the number up by the bits counted by the >> NORM instruction. Analog Devices has designed their normalization >> instruction (which may or may not be NORM; I can't remember) so that >> it can be vectorized -- this lets you do block floating point >> calculations which makes oodles of sense in a vector processing >> environment. > > > Thanks. Now I can take a closer look at the code. > > To code an accurate square root, compute 1/sqrt(x) iteratively; that can > be done with shifts and multiplies. When done, multiply by x. For > sqrt(x^2+y^2), there's a quicker way than summing the squares and > rooting. I first read it in Jon Bentley's Programming Pearls column and > it was discussed here a couple of years ago. Again go for the reciprocal > on machines with fast multiply and slow divide. > > JerryEven faster on a DSP is to use a 3 to 6 element Taylor's series. I'd take the "mantissa", scaled to be between 1/4 <= x_m < 1. Then I'd execute y = a_0 + a_1 * x_m + a_2 * x_m^2 ... On the ADI 21xx processors you can do this as fast as a MAC, on a TI processor it takes a few more cycles but it can still be vectorized and it goes by quite quickly. If you do the normalization first then a denormalization you probably only need three or four terms -- but these are DSP's and therefore counterintuitive -- it may be quicker to use 6 or 7 or 8 terms and not mess around with shifts and such. Note that you can truncate the series one or two elements early if you don't use an exact Taylor's expansion. Rather, you should find your coefficients by doing a multivariate least-squares fit on the vector 1, x, x^2, etc. Note also that I can take absolutely no credit for this basic idea: it's in the documentation for the ADI 210x -- page 57 of "Digital Signal Processing Applications using the ADSP-2100 Family" lists this basic algorithm for square root approximations. They use the same basic algorithm for cosine, arctan, etc. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
>> the DSP has a one cycle instruction (called NORM) that counts >> the bits - starting from the left to the first change. >> >> I pass a 32 bit integer and get get back the number of >> leading zeros ... (works for ned number in 2 complement as well so TI >> calls the bits from the left 'redundant') >> >> the output of that instruction is similar to >> 31 - floor(log2(x))> That's an interesting instruction. What does it do with negative numbers?It also counts - starting from the left to the first changing bit. As a negative number (in 2's complement) would be filled up with ones it would then just count the ones and give you something like 31 - floor(log2(-x)) (not exactly - there is a +1 or -1 missing - from the 2's complement conversion but I can't remember the details) >>>> next idea: halven the exponent my shifting ... x >> exp/2 >>>> (certainly the mantissa is wrong now)> > Thanks. I understand it all but the mantissa part. What is a fixed-point > mantissa?I take my input and determine the log2 of it. I called this value the "exponent" (as it *would* be similar to the exponent if I converted my number to a floting representation - if I *would* convert it which I don't) I just shift my input x by exponent/2 to the right. I do nothing more - but for understanding it I can *think* of it as a floating point with half the exponent now. This floating point value would be close to my desired sqrt - except for the mantissa beeing wrong. What I got is still just a 32 bit value which is somehow near the value of the desired sqrt(x) - but wrong by the amount of a wrong mantissa my float *would* have ... sorry for being that unclear - I've been thinking about this for some days now and it's actually working on the DSP as well (so I'm quite familiar with my thoughts by now ;-) bye, Michael
Michael Schoeberl wrote:>>> the DSP has a one cycle instruction (called NORM) that counts >>> the bits - starting from the left to the first change. >>> >>> I pass a 32 bit integer and get get back the number of >>> leading zeros ... (works for ned number in 2 complement as well so TI >>> calls the bits from the left 'redundant') >>> >>> the output of that instruction is similar to >>> 31 - floor(log2(x)) > > >> That's an interesting instruction. What does it do with negative numbers? > > > It also counts - starting from the left to the first changing bit. > > As a negative number (in 2's complement) would be filled up with ones it > would then just count the ones and give you something like > 31 - floor(log2(-x)) > > (not exactly - there is a +1 or -1 missing - from the 2's complement > conversion but I can't remember the details) > > > > >>>> next idea: halven the exponent my shifting ... x >> exp/2 > >>>> (certainly the mantissa is wrong now) > >> >> Thanks. I understand it all but the mantissa part. What is a >> fixed-point mantissa? > > > I take my input and determine the log2 of it. I called this value the > "exponent" (as it *would* be similar to the exponent if I converted my > number to a floting representation - if I *would* convert it which I don't) > > > I just shift my input x by exponent/2 to the right. > > > I do nothing more - but for understanding it I can *think* of it as a > floating point with half the exponent now. This floating point value > would be close to my desired sqrt - except for the mantissa beeing wrong. > > What I got is still just a 32 bit value which is somehow near the value > of the desired sqrt(x) - but wrong by the amount of a wrong mantissa my > float *would* have ... > > > > > sorry for being that unclear - I've been thinking about this for some > days now and it's actually working on the DSP as well (so I'm quite > familiar with my thoughts by now ;-)Thanks. I understand now. It's very clever. I would explain it a bit differently, but that's just a mater of viewpoint. The code would be the same. Would you like to write it up as a "Trick" for dspguru.com? http://www.dspguru.com/comp.dsp/tricks/call.htm Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
