Hi, I am looking for some information on whats new In TI Code composer studio 3.1 expect to me they have merged it for all processors. Any comment will be helpful. Regards, Soumit
CCS 3.1 vs 3.0.1
Started by ●July 13, 2005
Reply by ●July 14, 20052005-07-14
What's New in Code Composer Studio Development Tools v3.1 (Rev. A) : http://www-s.ti.com/sc/psheets/spraa07a/spraa07a.pdf <soumit.mukherjee@gmail.com> wrote in message news:1121282139.177500.78040@z14g2000cwz.googlegroups.com...> Hi, > I am looking for some information on whats new In TI Code composer > studio 3.1 expect to me they have merged it for all processors. > Any comment will be helpful. > Regards, > Soumit >
>Hi, > I am looking for some information on whats new In TI Code composer >studio 3.1 expect to me they have merged it for all processors. > Any comment will be helpful. >Regards, >SoumitConnect/Disconnect, Rewind and revamped tuning dashboard. Did CCS3.0 have Code Wright? --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
bhooshaniyer wrote:> >Hi, > > I am looking for some information on whats new In TI Code composer > >studio 3.1 expect to me they have merged it for all processors. > > Any comment will be helpful. > >Regards, > >Soumit > > Connect/Disconnect, Rewind and revamped tuning dashboard. > Did CCS3.0 have Code Wright? > > --Bhooshan > > >While I like the compiler, I must say that when it comes to target communicatios (using Spec Dig JTAG emulator) is the most crash-prone piece of software that I have ever run on a Windows platform, hands down. I have to kill it with Task Manager and clean up remnant processes many times per day. I expect much higher reliability for software that costs thousands of dollars! John
john wrote:> > While I like the compiler, I must say that when it comes to target > communicatios (using Spec Dig JTAG emulator) is the most crash-prone > piece of software that I have ever run on a Windows platformI found that CCS 3.0 was completely stable and rock steady as long as the program running on the target behaved itself. As soon as the target program started doing erratic things (corrupting a function pointer and trying to execute hyperspace in my case), CCS 3.0 would lock up and crash constantly. Of course, when your code is misbehaving is exactly when you need a solid, stable debugger... Luckily, I've not committed any more schoolboy howlers since I've been using 3.1, so I can't comment on that. Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
Mark Robinson wrote:> john wrote: > > > > While I like the compiler, I must say that when it comes to target > > communicatios (using Spec Dig JTAG emulator) is the most crash-prone > > piece of software that I have ever run on a Windows platform > > I found that CCS 3.0 was completely stable and rock steady as long > as the program running on the target behaved itself. As soon as the > target program started doing erratic things (corrupting a function > pointer and trying to execute hyperspace in my case), CCS 3.0 would > lock up and crash constantly. Of course, when your code is > misbehaving is exactly when you need a solid, stable debugger... > > Luckily, I've not committed any more schoolboy howlers since I've > been using 3.1, so I can't comment on that. > > Cheers >I had to laugh when I saw the phrase "rock solid" mentioned in connection with CCS. In my case it crashes regularly even when not attached to the target, with the emulator's USB port disconnected. When CCS boots it gives an error, with an option to Abort, Retry, or Ignore. I hit Ignore, and CCS comes up with "Emulator Disconnected" in the bottom tray. Projects load and compile, as expected. Then at random times CCS freezes up and has to be killed with Task Manager. Argh! John
Reply by ●July 18, 20052005-07-18
john wrote:> > In my case it crashes regularly even when not attached to the target, > with the emulator's USB port disconnected.You have my sympathy, but I have to say I've never had a moments trouble with it, except when my target code was broken. I have a Spec. Dig. DM642 EVM (600MHz version) and an XDS560. I've installed it on a few different machines with various hardware, etc (the XDS560 doesn't work with a Coreco PC-DIG framegrabber, but otherwise no problems). Maybe I've just been lucky :-) Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
