<Venkat.Vijay.Kumar@gmail.com> wrote in message news:1121910110.692753.63950@g43g2000cwa.googlegroups.com...> > > Bhaskar Thiagarajan wrote: > > "Mark" <makolber@yahoo.com> wrote in message > > news:1121866582.325514.102090@z14g2000cwz.googlegroups.com... > > > That is an interesting question, > > > > > > I thought that impulse sampling is desirable because it provides an > > > accurate representation of the signal, but that natural sampling (what > > > the OP describes as sampling with a square wave) also is possible and > > > also provides a representation of the signal except that natural > > > sampling creates sinx/x attenuation to the higher frequencies. I > > > think that in practice one cannot achieve ideal impulse sampling > > > because the aperture cannot be open for an infinitesimal time but must > > > be open for some short but finite time. > > > > > > I thought this is completely analogous to what happens in > > > reconstruction in a DAC. You can use (in theory) impulse > > > reconstruction which creates no sinx/x attenuation. But in practice > > > most designs use natural sampling reconstruction (the samples persist > > > for the entire time duration of the sample) and this creates sin x/ x > > > attenuation which is compensated for elsewhere in the system. > > > > Mark > > You are confusing the DAC process from the ADC process... > > The ADC *samples* a signal to create discrete signals, while the DACcreates> > a continuous signal from a discrete signal. > > The 2 operations are quite a bit different and the zero order hold of aDAC> > is not what i'd call 'natural sampling'. > > > > The OP might also be a little confused with the term 'clock' andsampling> > since a clock tends to be a nice square wave in circuit terms...howeverthe> > model for sampling involves impulses. Despite feeding a square wave as a > > clock to an ADC, the ADC doesn't use square waves in it's actual'sampling'> > of the input analog signal. > > > > Cheers > > Bhaskar > > Hi Bhaskar, > My confusion is what you mentioned in your reply, that is about > the clock and sampling. I agree with the sampling with impulses would > retain the input signal. (Same as Fin and not Fclk+/-Fin) > But how does it work with a clock (which is a square wave). What > do you mean by "feeding a square wave as a clock to an ADC, the ADC > doesn't use square waves in it's actual 'sampling' of the input analog > signal." > > How does the sampling in an ADC work. I am bit confused by your > above statement. Can you eloberate??I'd probably do a poor job of explaining the internal workings of an ADC - google is your friend here and you should be able to find plenty of app notes and articles that explain how ADCs work. I'll try to give you something really simple to start with...but you should understand that real ADCs have a lot more going on inside. Most ADCs have 2 important blocks, the sample and hold block and the quantization block. The sample and hold block basically 'samples' and holds that instantaneous value for the quantization block to convert the analog voltage into a discrete value. For example, in an N bit converter, this block would compare this voltage to one of 2^N levels and output a N bit word based on the comparison. Back to what confuses you...the sample and hold circuit typically works off the edges of the clock that you supply to the chip. Say, it uses the rising edge only, then effectively, the sample and hold block generates 'impulses' off the incoming clock to sample the input signal that the instants when the clock has a rising edge. Jerry referred to 'aperture time' - this is the time (usually very small but not zero) that actual ADCs need to 'sample' the input signal. What this amounts to is that instead of ideal impulses, the actual sampling occurs over a very small delta_t. One can still approximate this to impulses for casual analysis and modeling but this cannot be ignored when looking at the capabilities and performance of real ADCs. Hope I kept it simple enough to illustrate what you need to know. There is a lot more to ADCs and I'd refer to you app notes and papers depending on how deep you'd want to get. Cheers Bhaskar> > Thanks for your reply.. > > > > > > > > > > > > > > So I thought impulse vs natural sampling analogy applies for both the > > > sampling process and the reconstruction process. Another word forthe> > > high frequency attenuation that occurs with natural sampling is > > > aperture attenuation and it can occur during sampling (capturing the > > > signal) or during reconstruction. > > > > > > Is this not true? > > > > > > thanks for the interesting question. > > > > > > Mark > > > >
Basic Signal Processing Question
Started by ●July 20, 2005
Reply by ●July 21, 20052005-07-21
Mark wrote:> I think we need to separate two aspects of what an A/D does...> 1) sample> 2) quantize> An analog signal can be sampled without being quantized. FM stereo > does this.I agree that signals can be sampled without being quantized, but I don't believe that FM stereo does that. It is an AM suppressed carrier modulated signal, both the subcarrier and the baseband must be band limited so they don't overlap, but they aren't sampled. -- glen
Venkat.Vijay.Kumar@gmail.com wrote: ...> My confusion is what you mentioned in your reply, that is about > the clock and sampling. I agree with the sampling with impulses would > retain the input signal. (Same as Fin and not Fclk+/-Fin) > But how does it work with a clock (which is a square wave). What > do you mean by "feeding a square wave as a clock to an ADC, the ADC > doesn't use square waves in it's actual 'sampling' of the input analog > signal." > > How does the sampling in an ADC work. I am bit confused by your > above statement. Can you eloberate??Now you're getting into hardware design. Do you really want to go there? Working parts are not made of equations, but of bits of wire, silicon, foil, solder, and more. Circuits can be made that are insensitive to level, but respond to changes in level Such devices are called "edge triggered" In explaining an ADC, I'll ignore them; just know that they can simplify a design. Our ADC consists of a voltage-controlled switch (you can think of it as a relay), a sample holding capacitor, a comparator (greater-than, less-than) a set of latches, and a DAC. There's also a control circuit, but for now, that's magic.) When the clock is high, the switch connects the analog signal to the capacitor, which follows the signal. When the clock goes low, the capacitor is disconnected from the signal and its voltage stays substantially constant. The MSB of the ADC is turned on by setting the corresponding latch and the comparator is consulted. If the capacitor voltage is less than the DAC voltage, the latch is cleared; otherwise, it is left on. Then the same is done with the next-highest bit, and so on until the LSB is tested. When the process is done, the state of the latches (and sometimes the comparator output) are output as a number that represents the voltage on the capacitor. When the clock goes high again, it clears the latches and reconnects the capacitor to the analog signal. Let's be clear: there is no magic. To make one of these work, you need to actually build the control circuit. Moreover, there are many other ways to build an ADC, some of them with more delay than the successive-approximation type I describes, some of them slower. The output can come serially or all at once. I omitted the control signals that make the information transfers possible and that control timing. We are often warned not to mistake the map for the territory. Similarly, we need to beware of mistaking the equations for the device. Also, don't assume how a circuit works and draw conclusions from the assumptions. If you really want to know, look at a schematic. It defeats all of us when we believe that something must be a certain way because we can't conceive of any other way. "There are more things in heaven and earth, Horatio, than are dreamt of ..." There's _always_ another way. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Mark wrote:> I think we need to separate two aspects of what an A/D does... > > 1) sample > > 2) quantize > > > An analog signal can be sampled without being quantized. FM stereo > does this.So does a S/H> Sampling can be impulse sampling or natural sampling (full duration) or > anything in between. True impulse sampling is impossible because a > true impulse is infinitesimal in duration.What duration? a full cycle of the sampled signal? How is that useful?> Quantization converts the sample to a number. Since the sample is > not infinitesimal in time, the quantization process has to average or > otherwise take a non-infinitesimal duration analog signal and convert > it to a single number.What happens to a "natural sample", whatever it is? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
The L and R are time division multiplexed by sampling each at 38 kHz. The L and R samples are interleaved and FM modulated onto the main RF carrier. This is spectrally equivalent to what you described. This is two different descriptions of the same thing, one description looking at the frequency domain, and one description looking at the time domain. Actually there are two different design approaches to an FM MPX encoder, the TDM approach and the L-R matrix approach, both create the same output signal and are fully compatable. Mark
>What duration? a full cycle of the sampled signal? How is that useful?No a full cycle of the samplING signal which is at least 2x the samplED signal. Mark
Mark wrote:> The L and R are time division multiplexed by sampling each at 38 kHz. > The L and R samples are interleaved and FM modulated onto the main RF > carrier. This is spectrally equivalent to what you described. This is > two different descriptions of the same thing, one description looking > at the frequency domain, and one description looking at the time > domain. Actually there are two different design approaches to an FM > MPX encoder, the TDM approach and the L-R matrix approach, both create > the same output signal and are fully compatable.There is no sampling. 38 KHz is the frequency of the subcarrier that carries the difference signal. The sum signal is transmitted as in a mono signal, so that a mono signal is received as such and a mono receiver receives L+R. That's what's meant by compatibility. After the difference signal is recovered from by demodulating the subcarrier (with the aid of the 19 KHz pilot tone), the two signals are matrixed to create L and R. If the pilot tone is too weak, there is no matrixing. Which standard have you been reading? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Mark wrote:>>What duration? a full cycle of the sampled signal? How is that useful? > > > No a full cycle of the samplING signal which is at least 2x the samplED > signal.When it's over and done with, what is the analog value of the analog sample on the hold capacitor? Another question: what's natural about it? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 22, 20052005-07-22
I did not invent the term "Natural sampling" see: http://doctord.dyndns.org:8000/courses/tutorials/Sampling.htm http://uregina.ca/~douglatr/ENEL%20813/enel_813.htm http://www.electronics.dit.ie/staff/ptobin/chapt06a.pdf You can Google ("natural samping" + impulse) for more examples Mark
Mark wrote:> I did not invent the term "Natural sampling" > > see: > > http://doctord.dyndns.org:8000/courses/tutorials/Sampling.htm > > http://uregina.ca/~douglatr/ENEL%20813/enel_813.htm > > http://www.electronics.dit.ie/staff/ptobin/chapt06a.pdfI did not suggest that you did. I asked for an explanation; thanks for the links. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
