I've notieced that in order to decode a page of in-band data, the linux kernel code first computes the out-of-band ECC bytes on the given in-band data (calc_ecc). It is also passed the received oob data recv_ecc. If (byte-by-byte) the calc_ecc does not match the recv_data, then the page is decoded. Why not compute the decoded ECC and compute the locator vector/polynomial right off? Are these operations much more expensive than encoding and comparing? --Randyh
BCH Encoding/Decoding
Started by ●November 24, 2020
Reply by ●November 28, 20202020-11-28
Randy Yates <yates@digitalsignallabs.com> wrote:>I've notieced that in order to decode a page of in-band data, the linux >kernel code first computes the out-of-band ECC bytes on the given >in-band data (calc_ecc). It is also passed the received oob data >recv_ecc. > >If (byte-by-byte) the calc_ecc does not match the recv_data, then >the page is decoded. > >Why not compute the decoded ECC and compute the locator >vector/polynomial right off? Are these operations much >more expensive than encoding and comparing?TL;dr it comes down to evaulating a lower-degree polynomial, thus requires less computation. Assume it is a systematic (n,k) BCH code, it is most efficient to re-encode the message part of the codeword, and then XOR the resulting (n-k) check symbols with the (n-k) received check symbols. Then the syndrome (power sum symmetric function) can be computed by evaluating using these (n-k) polynomial coefficients instead of all n coefficients. The quick exit if there is no mismatch is an optimization.
