Hello All,
would anyone please give me an illustration how to perform 2D czt in matlab? I use the row-column method used in normal fft to perform 2D czt transform on the Gaussian signal.
amp=exp(-pi*(X.^2+Y.^2)/w0^2);
tmp2=czt(amp,M,wx,ax);
amp_f2=czt(tmp2.',N,wy,ay);
The result doesn't make sense since Gaussian should remain as Gaussian after czt.
Originally, I think the signal is required to be shift to assure that zero-frequency is located at [0,0]. Thus, I tried tmp2=czt(ifftshift(amp),M,wx,ax). And the result is weird with many segments of original signal.
Could any expert give me some suggestions how to achieve it? Thanks for your attentions.
Regards,
Jennifer
two dimensional chirp z-transform
Started by ●October 23, 2020
