Hi, Is there any free or low cost software tools that could calculate FIR filter coefficients for bandpass filter? Thanks!
FIR Filter design tool
Started by ●July 28, 2005
Reply by ●July 28, 20052005-07-28
Yes, Try here: http://personal.atl.bellsouth.net/p/h/physics/Fir.zip I posted the directions a couple of weeks ago. When I'm back at the house, I'll try to encapsulate some directions with the program. Clay
Reply by ●July 29, 20052005-07-29
I like Meteor: http://www.nyx.net/~wliu/filter.html. The interface is klunky, but it does a superb job at optimization. I've used it before with excellent results.
"Brian Neunaber" <neunaber@gmail.com> wrote in message news:1122651140.442066.137580@g49g2000cwa.googlegroups.com...>I like Meteor: http://www.nyx.net/~wliu/filter.html. The interface is > klunky, but it does a superb job at optimization. I've used it before > with excellent results.The original Parks-McClellan Fortran program is simple to use and you don't have to compile it for Windows as there's an executable here: ftp://mission-systems-inc.com/outgoing/Parks_McClellan/ The band edges are defined as fractions of the sample rate - so should not be entered for values greater than 0.5. The main thing it doesn't take as an input is a variable weight function in each band for passband/stopband filters. But a constant weight for each band is usually plenty good so you can trade between ripples in each band. The wider the transistion bands (which are between each pair of band edges) the smaller the ripple for a given length. Example input and output for a bandpass filter: What is the length of the filter? 64 Type?: 1 - Passband/Stopband 2 - Differentiator 3 - Hilbert Transformer 1 How many pass bands and stop bands? 3 List band edges, one per line or comma delimited 0,.2,.25,.3,.35,.5 List filter response for each band, one per line or comma delimited or desired slop if a differentiator 0,1,0 List filter weight for each band, one per line or comma deliminted for a differentiator, a single weight will be used as w/f 1,1,1 1********************************************************************** FINITE IMPULSE RESPONSE (FIR) LINEAR PHASE DIGITAL FILTER DESIGN REMEZ EXCHANGE ALGORITHM BANDPASS FILTER FILTER LENGTH = 64 ***** IMPULSE RESPONSE ***** H( 1) = 0.30537898E-03 = H( 64) H( 2) = 0.49959793E-03 = H( 63) H( 3) = 0.23405663E-03 = H( 62) H( 4) = 0.79011120E-03 = H( 61) H( 5) = -0.22296710E-02 = H( 60) H( 6) = -0.76272665E-03 = H( 59) H( 7) = 0.46930313E-02 = H( 58) H( 8) = -0.48358738E-03 = H( 57) H( 9) = -0.58953944E-02 = H( 56) H( 10) = 0.22085404E-02 = H( 55) H( 11) = 0.35657433E-02 = H( 54) H( 12) = -0.99933892E-03 = H( 53) H( 13) = 0.15462588E-02 = H( 52) H( 14) = -0.62719714E-02 = H( 51) H( 15) = -0.49136356E-02 = H( 50) H( 16) = 0.18144451E-01 = H( 49) H( 17) = 0.17707171E-02 = H( 48) H( 18) = -0.26896507E-01 = H( 47) H( 19) = 0.65720053E-02 = H( 46) H( 20) = 0.23222979E-01 = H( 45) H( 21) = -0.96453326E-02 = H( 44) H( 22) = -0.53003971E-02 = H( 43) H( 23) = -0.69127390E-02 = H( 42) H( 24) = -0.15373212E-01 = H( 41) H( 25) = 0.49446747E-01 = H( 40) H( 26) = 0.18551089E-01 = H( 39) H( 27) = -0.10686837E+00 = H( 38) H( 28) = 0.10605872E-01 = H( 37) H( 29) = 0.15323216E+00 = H( 36) H( 30) = -0.67921862E-01 = H( 35) H( 31) = -0.16304862E+00 = H( 34) H( 32) = 0.12894705E+00 = H( 33) BAND 1 BAND 2 BAND 3 BAND LOWER BAND EDGE 0.000000000 0.250000000 0.349999994 UPPER BAND EDGE 0.200000003 0.300000012 0.500000000 DESIRED VALUE 0.000000000 1.000000000 0.000000000 WEIGHTING 1.000000000 1.000000000 1.000000000 DEVIATION 0.001624721 0.001624721 0.001624721 DEVIATION IN DB -55.784420013 -55.784420013 -55.784420013 EXTREMAL FREQUENCIES 0.0000000 0.0156250 0.0322266 0.0478516 0.0644531 0.0800781 0.0966797 0.1123047 0.1279297 0.1435547 0.1591797 0.1728516 0.1865234 0.1962891 0.2000000 0.2500000 0.2539062 0.2626953 0.2753906 0.2871094 0.2958984 0.3000000 0.3500000 0.3539062 0.3636719 0.3773437 0.3919922 0.4076172 0.4242187 0.4408203 0.4574219 0.4740234 0.4916016 ********************************************************************** Fred
