Rick Lyons wrote:>On Wed, 3 Aug 2005 12:19:12 -0400, "Clay S. Turner" ><Physics@Bellsouth.net> wrote: > > (snipped) > > >>So with mild oversampling, modest filter lengths are all that are needed. >> >>IHTH, >> >>Clay >> >> > >Hi Clay, > > I agree with you completely. > >If moderate oversampling is used, Paul might "get away with" >using a "central-difference" differentiator defined by: > >y1(n) = [x(n) - x(n-2)]/2 > >which, happily, has a group delay that's an integer >number of samples. > >I just discovered an interesting digital differentiator >that has a wider freq range of "linear magnitude operation" >than the central-difference differentiator. >That new(?) differentiator is defined by: > >y2(n) = -x(n)/16 + x(n-2) -x(n-4) + x(n-6_/16). > >What does "x(n-6_/16" mean? Is it supposed to be: y2(n) = -x(n)/16 + x(n-2) - x(n-4) + x(n-6)/16 which has a nice symmetric feel to it?>This "wider-band" y2(n) differentiator has two additional >nice properties. > >(1) It's non-unity coefficients are powers of two, so binary >shifts can be used instead of coefficient multiplication. >(2) It's group delay is an integer number of samples >making it useful for your proposed FM demod scheme. > >I'm thinkin' of including that "y2(n) differentiator" as a >"DSP Trick" in the 3rd edition of my book. > >Steve
FM Demod question
Started by ●August 2, 2005
Reply by ●August 8, 20052005-08-08
Rick Lyons wrote: ...> I'm thinkin' of including that "y2(n) differentiator" as a > "DSP Trick" in the 3rd edition of my book.Hi, Rick. How about sending it Grant Griffin in the mean time? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●August 11, 20052005-08-11
On Mon, 08 Aug 2005 11:02:48 +0800, Steve Underwood <steveu@dis.org> wrote: (snipped)>> >> >What does "x(n-6_/16" mean? Is it supposed to be: > >y2(n) = -x(n)/16 + x(n-2) - x(n-4) + x(n-6)/16 > >which has a nice symmetric feel to it?>SteveHi Steve, Shoot! I screwed up. You are correct, it's "x(n-6)/16". Thanks, [-Rick-]
On Sun, 07 Aug 2005 23:06:24 -0400, Jerry Avins <jya@ieee.org> wrote:>Rick Lyons wrote: > > ... > >> I'm thinkin' of including that "y2(n) differentiator" as a >> "DSP Trick" in the 3rd edition of my book. > >Hi, Rick. > >How about sending it Grant Griffin in the mean time? > >JerryAh yes, I'll look into that. Thanks. See Ya', [-Rick-]
