Hello, I work actually with an ADSP-21020 dsp processor and try to connect the EZ-ICE Emulator in a PC using Windows XP. I am not able to connect the EZ-ICE Probe to the 21020 processor, as the ISA bus used by the EZ-ICE board is not well configured. Le message d'erreur que j'obtiens avec Wice020.exe Tool : "Initialisation Failed. Error : HW Error : Can't find EZ-ICE - check base address assignment". How can we configure the addresses of the ISA Bus in order to communicate with the EZ-ICE board (the default adress is : 340). Regards, Thomas Rouz� This message was sent using the Comp.DSP web interface on www.DSPRelated.com
21020 EZ-ICE Emulator on Windows XP
Started by ●August 9, 2005
Reply by ●August 9, 20052005-08-09
Not sure what version of the tools you're using (21020s are kinda old, obsolete, and not well supported), but you should be able to set the base address in the configurator (there was always some kind of utiliuty for telling the tools where the emulators were). The IceTest utility usually let you set the base address as well. "thomasRouze" <thomas.rouze@astrium.eads.net> wrote in message news:CLSdnbk53NCOPmXfRVn-sg@giganews.com...> Hello, > I work actually with an ADSP-21020 dsp processor and try to connect the > EZ-ICE Emulator in a PC using Windows XP. > I am not able to connect the EZ-ICE Probe to the 21020 processor, as the > ISA bus used by the EZ-ICE board is not well configured. > Le message d'erreur que j'obtiens avec Wice020.exe Tool : "Initialisation > Failed. Error : HW Error : Can't find EZ-ICE - check base address > assignment". > > How can we configure the addresses of the ISA Bus in order to communicate > with the EZ-ICE board (the default adress is : 340). > > Regards, > Thomas Rouz� > > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
