Hi all, I'm new to programming the ADSP-BF533 and I would like to know the recommended way to count the nr of cycles used by a function. Here's what I'm doing now: main() { int start, stop, overhead, cycles; start = sysreg_read(reg_CYCLES); stop = sysreg_read(reg_CYCLES); overhead = stop - start; sysreg_write(reg_CYCLES, 0x0); // don't want any overflow start = sysreg_read(reg_CYCLES); filter(); // function I want to profile stop = sysreg_read(reg_CYCLES); cycles = stop - start - overhead; } Will this give an accurate cycle count? Or is there another, better way to do this? Thanks, T.
counting cycles, blackfin
Started by ●August 10, 2005
Reply by ●August 10, 20052005-08-10
I don't know about the BlackFin, but on the ADSP SHARC family, there is a "hidden" register called EMUCLK (emulator clock) that is useful for counting cycles. It is read-only, so you can't zero it out, but as long as your function won't wrap more than once, you can simply compensate for any wrapping (which is unlikely on the SHARC, since it is a 32-bit counter and typically doesn't wrap for hours). But I think your method looks fine. -- Jon Harris SPAM blocker in place: Remove 99 (but leave 7) to reply <t_gatu@hotmail.com> wrote in message news:1123662998.742308.233720@g43g2000cwa.googlegroups.com...> Hi all, I'm new to programming the ADSP-BF533 and I would like to know > the recommended way to count the nr of cycles used by a function. > > Here's what I'm doing now: > > main() > { > int start, stop, overhead, cycles; > > start = sysreg_read(reg_CYCLES); > stop = sysreg_read(reg_CYCLES); > overhead = stop - start; > > sysreg_write(reg_CYCLES, 0x0); // don't want any overflow > start = sysreg_read(reg_CYCLES); > filter(); // function I want to profile > stop = sysreg_read(reg_CYCLES); > cycles = stop - start - overhead; > } > > Will this give an accurate cycle count? Or is there another, better way > to do this? > > Thanks, > T. >
