FFT convolution's complex multiplication problem
Started by Michel Rouzic ●August 12, 2005
I've made an overlap-add/FFT convolution function, the problem with it
is that it mostly outputs samples which value is infinite. I isolated
the problem in the function and it appears to be at the level of my
context : i have cut the long input signal into nblocks and put each
part into an array block[], i of course zeropadded each block, then
FFTed each block, and here i'm attempting to perform a complex
multiplication with the FFTed zeropadded short input signal :
for (i=0; i<nblocks; i++)
		for (j=0; j<blocksize; j++)
			a=block[i][j];
			b=block[i][j-blocksize-1];
			c=smin[j];
			d=smin[j-blocksize-1];
			if (i<blocksize/2)
				block[i][j]=a*c - b*d;
			else
				block[i][j]=b*c + a*d;
this is where i performed the complex multiplication, then i IFFT each
block and put them back together into a signal.
everything is ok when i take off the multiplication part, thus i know
that it's really that part that causes my infinite value results.
i use FFTW's real-to-real interface to perform FFTs.
anyone knows whats wrong with my complex multiplication?
in article 1123869584.368669.306040@g43g2000cwa.googlegroups.com, Michel
Rouzic at Michel0528@yahoo.fr wrote on 08/12/2005 13:59:
> I've made an overlap-add/FFT convolution function, the problem with it > is that it mostly outputs samples which value is infinite. I isolated > the problem in the function and it appears to be at the level of my > complex multiplication > > context : i have cut the long input signal into nblocks and put each > part into an array block[], i of course zeropadded each block, then > FFTed each block, and here i'm attempting to perform a complex > multiplication with the FFTed zeropadded short input signal : > > for (i=0; i<nblocks; i++) > for (j=0; j<blocksize; j++) > { > a=block[i][j]; > b=block[i][j-blocksize-1]; > c=smin[j]; > d=smin[j-blocksize-1]; > > if (i<blocksize/2) > block[i][j]=a*c - b*d; > else > block[i][j]=b*c + a*d; > }
i presume that "a" and "c" have your real parts and "b" and "d" are the imag parts. is "smin[]" your transfer function? is it a DFT of a finite impulse response that is at least as short as your zero padding? (that's really important in overlap-add.) what about what you're storing at block[i][j-blocksize-1]?
> this is where i performed the complex multiplication, then i IFFT each > block and put them back together into a signal. > > everything is ok when i take off the multiplication part, thus i know > that it's really that part that causes my infinite value results.
do you know for sure if your transfer function has only decent, finite values in it? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson wrote:
> i presume that "a" and "c" have your real parts and "b" and "d" are the imag > parts.
that's right.
transfer function? i dont know what you mean by that, but it's the short input signal, quite often its the filter kernel
> is it a DFT of a finite impulse > response that is at least as short as your zero padding? (that's really > important in overlap-add.)
not sure i understood this one, but there is as much or less non-zero samples (in both smin[] or block[i][]) than zero samples, and then that's DFTed.
i'm storing the imaginary part of the DFTed block.
> do you know for sure if your transfer function has only decent, finite > values in it?
if your askin for what my smin[] is made of, it's created in the main() function by : double *kernel; kernelsize=3; kernel=malloc (sizeof(double) * kernelsize); kernel[0]=0; kernel[1]=1; kernel[2]=0; and then zeropadded/realloc'ed inside the fftconvolution function to the calculated length of 8 (thus being the FFT of (0,1,0,0,0,0,0,0))
Perhaps you're inadvertantly indexing a memory location outside the array. In this loop j starts at 0, so doesn't [j-blocksize-1] result in a value less than 0? This would cause a problem in the above lines:
and
Regards, Bob
in article 1123971289.474099.169600@g44g2000cwa.googlegroups.com, Michel
Rouzic at Michel0528@yahoo.fr wrote on 08/13/2005 18:14:
> > robert bristow-johnson wrote: >> i presume that "a" and "c" have your real parts and "b" and "d" are the imag >> parts. > > that's right. > >> is "smin[]" your transfer function? > > transfer function? i dont know what you mean by that, but it's the > short input signal,
i hope you mean the DFT or FFT of the short finite impulse response (the impulse response is the filter kernel).
tomaato vs. tomahto potaato potahto
>> is it a DFT of a finite impulse >> response that is at least as short as your zero padding? (that's really >> important in overlap-add.) > > not sure i understood this one, but there is as much or less non-zero > samples (in both smin[] or block[i][]) than zero samples, and then > that's DFTed.
it's the impulse response (that would be used directly for an FIR filter if you weren't doing "fast convolution") whose length that must not exceed the zero-padding done in each frame (by more than one sample at least).
>> what about what you're storing at block[i][j-blocksize-1]? > > i'm storing the imaginary part of the DFTed block.
your code snippet doesn't show it.
>> do you know for sure if your transfer function has only decent, finite >> values in it? > > if your askin for what my smin[] is made of, it's created in the main() > function by : > > double *kernel; > kernelsize=3; > kernel=malloc (sizeof(double) * kernelsize); > kernel[0]=0; > kernel[1]=1; > kernel[2]=0;
looks finite to me.
> and then zeropadded/realloc'ed inside the fftconvolution function to > the calculated length of 8 (thus being the FFT of (0,1,0,0,0,0,0,0))
a good test kernal. you should get your input copied to the output, one sample delayed. in article 1123976350.825104.161260@g14g2000cwa.googlegroups.com, BobM at BobM.DSP@gmail.com wrote on 08/13/2005 19:39:
> Perhaps you're inadvertantly indexing a memory location outside the > array. In this loop j starts at 0, so doesn't [j-blocksize-1] result in > a value less than 0? This would cause a problem in the above lines:
boy, i really agree with BobM. your indexing scheme seems very "convoluted". (and it's this convolution you DON'T want.) -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
oh yeah you're right, i knew it had to be a stupid error. it's
blocksize-j-1, not j-blocksize-1. never got a segfault with that tho..
maybe it's cuz i was dealing with small arrays
BobM wrote:
> Michel Rouzic wrote: > > for (j=0; j<blocksize; j++) > > { > > a=block[i][j]; > > b=block[i][j-blocksize-1]; > > c=smin[j]; > > d=smin[j-blocksize-1]; > > Perhaps you're inadvertantly indexing a memory location outside the > array. In this loop j starts at 0, so doesn't [j-blocksize-1] result in > a value less than 0? This would cause a problem in the above lines: > > > b=block[i][j-blocksize-1]; > and > > d=smin[j-blocksize-1]; > > Regards, > Bob
> i hope you mean the DFT or FFT of the short finite impulse response (the > impulse response is the filter kernel).
you know, it's a convolution, doesnt matter whats the FIR kernel or whats the input signal, to me it's just two input signals, one shorter, one larger, and gotta be treated as such.
> > i'm storing the imaginary part of the DFTed block. > > your code snippet doesn't show it.
i wasnt gonna show the whole function, i did hat before and nobody replied to my message, so i cut the code to the essential
> in article 1123976350.825104.161260@g14g2000cwa.googlegroups.com, BobM at > BobM.DSP@gmail.com wrote on 08/13/2005 19:39: > > > Perhaps you're inadvertantly indexing a memory location outside the > > array. In this loop j starts at 0, so doesn't [j-blocksize-1] result in > > a value less than 0? This would cause a problem in the above lines: > > boy, i really agree with BobM. your indexing scheme seems very > "convoluted". (and it's this convolution you DON'T want.)
yeah it was a stupid error, now i fixed it and it seems to work fine. the suprising thing is that it didnt give me any segfault
no nevermind, it's giving me weird results (like convolution of a shifted delta function with another shifted delta function gives me 8 non-zero samples). at least, it's not giving me infinite values anymore..
in article 1123987189.813993.322130@g44g2000cwa.googlegroups.com, Michel
Rouzic at Michel0528@yahoo.fr wrote on 08/13/2005 22:39:
>> i hope you mean the DFT or FFT of the short finite impulse response (the >> impulse response is the filter kernel). > > you know, it's a convolution, doesnt matter whats the FIR kernel or > whats the input signal, to me it's just two input signals, one shorter, > one larger, and gotta be treated as such.
just make sure that the integer lengths of the two input signals add to a number no more than 1 sample longer than the size of the FFT buffer. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
I also found out another mistake. once j gets bigger than blocksize/2, b and d are out of bouds too, my mistake is making j go to blocksize instead of blocksize/2. I think it should be alright like that : for (i=0; i<nblocks; i++) for (j=0; j<blocksize/2; j++) { a=block[i][j]; b=block[i][blocksize-j-1]; c=smin[j]; d=smin[blocksize-j-1]; block[i][j]=a*c - b*d; block[i][blocksize-j-1]=b*c + a*d; } but it's still giving me weird results, so there must be something wrong still, do you see it?
