Randy Yates wrote: (snip)> I think I see the "time-frequency" uncertainty thing now and > understand at least partially why it doesn't necessarily apply to some > types of frequency measurements.> This may seem really obvious, but if you look at the frequency domain > from the purely mathematical POV, you can only have a *perfect* > sinusoid if that sinusoid extends infinitely in time. If you have only > an "observation" of that sinusoid, which can be modeled by multiplying > the infinite sinusoid by a rectangular window with a width > corresponding to the observation period, then that infinite-thin peak > in the frequency domain spreads out. Why? Cause you don't know what > that sinusoid is "doing" outside the window.Say you multiply by a gaussian with a finite width instead of a rectangular window. If you consider the frequency domain of the rectangular window you will see why. A sine multiplied by a rect has infinite frequency components that don't decay quite fast enough. As I wrote in another post, atomic emission spectra are closer to lorentzian than gaussian, but not so much different.> Now, those facts are perfectly correct WHEN ANALYZING A SIGNAL OF INFINITE > EXTENT. However, we are free to perform an *instantaneous* frequency > measurement by, e.g., measuring the change in phase of the analytic signal > from one sample to the next and dividing by the sample interval. Thus even > thought that "sine" wave may be doing some really funky things outside the > observation interval, we can still measure the INSTANTANEOUS frequency and > that frequency can be measured PERFECT ACCURATELY if there is NO NOISE.Now, for the more realistic case the sine is multiplied be a gaussian. You don't know the exact shape of the gaussian but can sample the signal and maybe even do exact timings of the zero crossing. The zero crossing will be shifted slightly be the gaussian, and the shift will be different at different points. So, even measuring the zero crossings perfectly accurately with no noise you still can't exactly measure the underlying sine frequency. Otherwise consider passing a signal through an analog antialiasing filter where the response is not known exactly. A wider pulse allows less variation and so more accurate measurement of the frequency. (Note that people do optical frequency counting. Sometime in the 1980's the ability to count optical frequencies, I believe after mixing them down to a lower frequency, became possible. This meant that frequency, and so time, could be measured much more accurately than distance. The solution, then, was to define the speed of light to a nice round number (299792458m/s) and define distance in terms of the speed of light and time.) (snip of case with noise) -- glen
minimum cycles for fft, and limits of filling short sample out with zeros
Started by ●September 4, 2005
Reply by ●September 9, 20052005-09-09
Reply by ●September 10, 20052005-09-10
Randy Yates wrote:> glen herrmannsfeldt <gah@ugcs.caltech.edu> writes: > > > Stan Pawlukiewicz wrote: > > > > (snip) > > > >> The problem with this, is that in quantum mechanics the location of > >> the particle is governed by a probability density which is related > >> to the observation. In signal processing, the transform broadens > >> but the location of peak governs the frequency measurement. The > >> frequency content of a truncated signal increases but its not a > >> probability density, i.e. the true frequency isn't a random > >> parameter governed by chance, like a quantum particle. > > > > Say I have a signal that in frequency space has a broad peak, > > maybe not so peak shaped at all. What do I call the frequency > > of that signal? Somewhere within the peak, but where? > > That is an excellent question, Glen. At least it sure got me thinking. > > I think I see the "time-frequency" uncertainty thing now and > understand at least partially why it doesn't necessarily apply to some > types of frequency measurements. > > This may seem really obvious, but if you look at the frequency domain > from the purely mathematical POV, you can only have a *perfect* > sinusoid if that sinusoid extends infinitely in time. If you have only > an "observation" of that sinusoid, which can be modeled by multiplying > the infinite sinusoid by a rectangular window with a width > corresponding to the observation period, then that infinite-thin peak > in the frequency domain spreads out. Why? Cause you don't know what > that sinusoid is "doing" outside the window. > > Now, those facts are perfectly correct WHEN ANALYZING A SIGNAL OF INFINITE > EXTENT. However, we are free to perform an *instantaneous* frequency > measurement by, e.g., measuring the change in phase of the analytic signal > from one sample to the next and dividing by the sample interval. Thus even > thought that "sine" wave may be doing some really funky things outside the > observation interval, we can still measure the INSTANTANEOUS frequency and > that frequency can be measured PERFECT ACCURATELY if there is NO NOISE. > > Now if there IS noise, you can't measure even the INSTANTANEOUS frequency > accurately and must do some averaging or whatever to get the accuracy up, > so introducing noise requires that we measure the signal longer to get an > accurate estimate. > > Does that make sense?Yes, it does. You have just described the basic philosophy behind parametric frequency estimators (MUSIC, ESPRIT,...). While it is true that these methods are not governed by the Heisenberg uncertainty, there are problems with these as well. The main problem is that they are based on the *knowledge* of the signal being comprised by sinusoids, and also that the number of sinusoids is known at system design time. Here, "assume" or "have reason to believe" are not good enough, one has to *know*. Both questions reqire knowledge that can be very hard to ensure in practical situations. So basically, one trades accuracy for robustness. Rune
glen herrmannsfeldt wrote:> Stan Pawlukiewicz wrote: > > (snip) > > > There's a difference between uncertainty and trying to stuff a square > > peg in a round hole. In discussing the uncertainty principle, in this > > forum and in the past, the context has been either measuring the > > frequency of a single sine wave or the ability to measure the > > frequencies of two closely spaced sine waves. Would you agree that > > there is a difference between uncertainty and ambiguity? > > > I will agree that they are different, but maybe not as different > as some people seem to think. > > In real systems you never find a single sine wave, that is, from > t= negative infinity to positive infinity.Agreed, what the time domain is concerned. Most measurements I am aware of, are of finite duration. Even so, there is a vast difference between accurately estiamting the frequency of one sinusoidal, and detecting the presence of two close sinusoidals.> When I first learned all this there was the concept of wave packet, > which tends to be a sine multiplied by a gaussian or some similar > peak shaped function. The peak shaped function then has a width, > and, amazingly enough, so does the fourier transform of the > combined function. > > Atomic emission spectra tend to be closer to lorentzian than > gaussian, but it works out about the same. If you try to measure > the frequency, is the result uncertain or ambiguous?In my lingo, this is a variation of the frequency estimation problem. It seems you have only one sinusoidal (at least that's how I interpret your description) and your problem is to detect the frequency of this sinusoidal as exact as possible. The separation problem is to detect the presence of two separate sinusoidals that are close in frequency, and detect them as two lines as opposed to one. This matlab script demonstrates the problem: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% f1 = 0.14; % Normalized frequencies of sinusoidals f2 = 0.2; N1 = 8; % length of short data sequence N2 = 32; % Length of long data sequence fv1=[0:N1]/N1; % Frequency vector, short data sequence fv2=[0:N2]/N2; % Frequency vector, long data sequence % Generate short data sequence, plot DFT s1= exp(j*2*pi*f1*[0:N1-1])+exp(j*2*pi*f2*[0:N1-1]); S1=fft(s1)/N1; L1=stairs(fv1,abs([S1,S1(1)])); set(L1,'color',[0 0 1]) hold on % Generate long data sequence, plot DFT s2= exp(j*2*pi*f1*[0:N2-1])+exp(j*2*pi*f2*[0:N2-1]); S2=fft(s2)/N2; L2=stairs(fv2,abs([S2,S2(1)])); set(L2,'color',[1 0 0]) % Plot true spectrum lines plot([f1 f1],[0 1],'k',[f2 f2],[0 1],'k') %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% The black lines represent the true spectrum of the process that generate the data. The blue line represents the spectrun as estimated from an observation consisting of 8 samples, while the red line represents the spectrum as estimated from 32 samples. The short data sequence shows a spectrum peak in the general vicinity of the true lines, but the frequency estimate is not accurate and it does not reveal that there are two lines present. The long data sequence shows that there are two lines present, although the frequency estimates for the lines are still not accurate.> As for your question in this context, I would say you can have > ambiguity without uncertainty, but not uncertainty without ambiguity.Only half correct. Ambiguity is one particular type of uncertainty. Inaccuracy is another. Rune
Rune Allnor wrote: (snip)> Agreed, what the time domain is concerned. Most measurements > I am aware of, are of finite duration. Even so, there is a vast > difference between accurately estiamting the frequency of one > sinusoidal, and detecting the presence of two close sinusoidals.Not just one or two, but an infinite number of them. Consider sin(w t)exp(-A t**2) for some constant A. This is a sum of an infinite number of sines near w, assuming reasonable values for A. If you try to find w by measuring a small number of sample points there will be uncertainty depending on where in the gaussian you are. As for two sines, consider the low pressure sodium emission spectrum with two narrow lines closely spaced. You can detect that there are two lines. Now consider sodium at higher temperature and pressure. The lines are broadened due to doppler shift and collisions, and there is also reabsorption by other atoms. -- glen
"Rune Allnor" <allnor@tele.ntnu.no> writes:> Randy Yates wrote: > [...] >> Does that make sense? > > Yes, it does. You have just described the basic philosophy behind > parametric frequency estimators (MUSIC, ESPRIT,...).Thanks, Rune. I've heard about these but never had a clear understanding. I've never really understood the uncertainty concept as applied to DSP (i.e., the non-physics version), but now I'm embarassed that it's so simple. -- % Randy Yates % "She's sweet on Wagner-I think she'd die for Beethoven. %% Fuquay-Varina, NC % She love the way Puccini lays down a tune, and %%% 919-577-9882 % Verdi's always creepin' from her room." %%%% <yates@ieee.org> % "Rockaria", *A New World Record*, ELO http://home.earthlink.net/~yatescr
Reply by ●September 11, 20052005-09-11
Randy Yates wrote:> "Rune Allnor" <allnor@tele.ntnu.no> writes: > > Randy Yates wrote: > > [...] > >> Does that make sense? > > > > Yes, it does. You have just described the basic philosophy behind > > parametric frequency estimators (MUSIC, ESPRIT,...). > > Thanks, Rune. I've heard about these but never had a clear understanding.You have the basic idea very clearly. The rest is a matter of getting the idea to work with more than one sinusoidal, with an unknown number of sinusoidals (but you need to *know* an absolute upper limit on the number of sinusoidals), and in the presence of noise.> I've never really understood the uncertainty concept as applied to DSP (i.e., the > non-physics version), but now I'm embarassed that it's so simple.In my experience, that kind of embarrasment is a hallmark of insight. It takes time to ponder those kinds of things, and one usually needs a reason for pondering. And a provocation to think the consequences through. For my own part, I made the matlab script I posted in a response to Glen Herrmannsfeldt after I had encountered a Head of Division at an international R&D institution, who claimed the parametric high resolution techniques I implemented for my PhD thesis were obsolete: "All you have to do is to zero-pad your data and everything is revealed." This guy was head of the division where most DSP related stuff was done, and would have had 20 or 30 years of "experience" in DSP. Rune
glen herrmannsfeldt wrote:> Rune Allnor wrote: > (snip) > > > Agreed, what the time domain is concerned. Most measurements > > I am aware of, are of finite duration. Even so, there is a vast > > difference between accurately estiamting the frequency of one > > sinusoidal, and detecting the presence of two close sinusoidals. > > Not just one or two, but an infinite number of them. > > Consider sin(w t)exp(-A t**2) for some constant A. > This is a sum of an infinite number of sines near w, > assuming reasonable values for A. > > If you try to find w by measuring a small number of > sample points there will be uncertainty depending on > where in the gaussian you are. > > > As for two sines, consider the low pressure sodium > emission spectrum with two narrow lines closely spaced. > You can detect that there are two lines. > > Now consider sodium at higher temperature and pressure. > The lines are broadened due to doppler shift and collisions, > and there is also reabsorption by other atoms.Now I am confused. Are you capable of studying each line in its own right? Or do you just see a fuzzy wnergy distribution with respect to frequency? If you are not able to study single absorption/emission lines, then I would say you are dealing with a power spectrum density estimation problem. If you can see single lines and want to find their frequency as exact as possible, then you are dealing with a frequency estimation problem. If you want to see if one line has split in two when you modify the material, you are dealing with a line resolution problem. Rune
Reply by ●September 12, 20052005-09-12
Rune Allnor wrote:> glen herrmannsfeldt wrote:(snip)>>Now consider sodium at higher temperature and pressure. >>The lines are broadened due to doppler shift and collisions, >>and there is also reabsorption by other atoms.> Now I am confused. Are you capable of studying each line in > its own right? Or do you just see a fuzzy wnergy distribution > with respect to frequency?Well, the question had to do with being able to measure frequency exactly when there is no noise. I was trying to find real world examples that, even without noise, one would not be able to measure exactly. You can study each line in its own right if you can build a filter to separate them. That filter is then part of the system. It can be considered noiseless, but otherwise should have properties that real filters have.> If you are not able to study single absorption/emission lines, > then I would say you are dealing with a power spectrum density > estimation problem.So, in the noiseless case can you do an exact power spectral density measurement?> If you can see single lines and want to find their frequency > as exact as possible, then you are dealing with a frequency > estimation problem.The claim was exact. I am looking for reasons why it won't be exact.> If you want to see if one line has split in two when you > modify the material, you are dealing with a line resolution > problem.Well, sodium already has two lines without any modifying. -- glen
glen herrmannsfeldt wrote:> Stan Pawlukiewicz wrote: > > (snip) > >> There's a difference between uncertainty and trying to stuff a square >> peg in a round hole. In discussing the uncertainty principle, in this >> forum and in the past, the context has been either measuring the >> frequency of a single sine wave or the ability to measure the >> frequencies of two closely spaced sine waves. Would you agree that >> there is a difference between uncertainty and ambiguity? > > > > I will agree that they are different, but maybe not as different > as some people seem to think.Then what's the Heisenberg ambiguity principle;) Schroderinger's Drag Queen?> > In real systems you never find a single sine wave, that is, from > t= negative infinity to positive infinity.Agreed, in real life, stuff is more complicated.> > When I first learned all this there was the concept of wave packet, > which tends to be a sine multiplied by a gaussian or some similar > peak shaped function. The peak shaped function then has a width, > and, amazingly enough, so does the fourier transform of the > combined function. > > Atomic emission spectra tend to be closer to lorentzian than > gaussian, but it works out about the same. If you try to measure > the frequency, is the result uncertain or ambiguous? > > As for your question in this context, I would say you can have > ambiguity without uncertainty, but not uncertainty without ambiguity. > > -- glen >
Stan Pawlukiewicz wrote:> glen herrmannsfeldt wrote:>> Stan Pawlukiewicz wrote:>> (snip)(snip)> Then what's the Heisenberg ambiguity principle;)Whether the cat died or not.> Schroderinger's Drag Queen?>> In real systems you never find a single sine wave, that is, from >> t= negative infinity to positive infinity.> Agreed, in real life, stuff is more complicated.And this problem makes it hard to get right. The discussion was of a noiseless source, but do we also require a noiseless detector? For a heterodyne detector, a noiseless mixer and local oscillator? How do we get the right amount of real life into the problem, even with a noiseless source. In considering zero crossing of an optical signal, how do we know where zero is? Optical signals are always AC coupled, and so require a baseline restore. Any errors in the baseline restore shift the reference for zero crossing. -- glen
