Hello again, Thanks RBJ for the further information relating to the Q of a filter. Currently I am implementing some 2nd Order IIR Lowpass filters from the Orfanidis DSP book. However, these filters dont have a 'Q' control, just a cutoff frequency. Is it possible for every filter to have a 'Q' control parameter? I would like to add a 'Q' control to my lowpass and highpass IIR filters but not too sure the exact way to approach it? My 2nd Order Lowpass transfer function is: % % 1 + 2z^-1 + z^-2 % H(z) = b ----------------------- % 1 - 2az^-1 + a^2z^-2 % Would it be possible to incorporate 'Q' into this design? I compute b and a as follows: % Sampling rate in Hz Fs = 44100; % Cutoff frequency in Hz fCut = 500; % Cutoff frequency in rads per sample wc = 2*pi*fCut/44100; % Apply bilinear transform to angular cutoff omega = tan(wc/2); % Compute filter parameter alpha alpha = omega; % Compute coefficients in terms of alpha a = (1 - alpha) / (1 + alpha); b = alpha / (1 + alpha); This is for the 3dB attenuation at the cutoff case. i.e alpha = tan(wc/2); Again, would it be possible to add some sort of resonance control to this design, so that the filter peaks higher at the cutoff frequency? Thanks very much for any advice. Cheers, David This message was sent using the Comp.DSP web interface on www.DSPRelated.com
IIR Filter Recommendations
Started by ●September 6, 2005
Reply by ●September 11, 20052005-09-11
