I forgot to mention that I have set JP7 on the EzDSP board to 1-2 as said in the Ezdsp technical reference doc to make it "Jump to Flash"
FlashAPIInterface.c
Started by ●September 8, 2005
Reply by ●September 13, 20052005-09-13
Start out by putting a hardware breakpoint at address 0x3F7FF6. Then do Debug -> Reset followed by Debug -> Run. Does it get to the hardware breakpoint? If not, your bootmodes are not set up correctly. If it does get there try doing Debug -> Step Into and see where it goes. Try a few of those and you should be able to see where it goes into the weeds. Brad "Ajay" <ajaydsouza@gmail.com> wrote in message news:1126590361.075254.203790@o13g2000cwo.googlegroups.com...>I forgot to mention that I have set JP7 on the EzDSP board to 1-2 as > said in the Ezdsp technical reference doc to make it "Jump to Flash" >
