Wen inplemening a FIR filter, what considerations are given when choosing between, rectangular, Bertlet, Hanning, Hamming, Blackman, kaiser, etc windows for the coefficients? Basically, aside from the attenuation differences at the first hump in the stop band, and transition band width, what other characteristics (trade offs) are to considered? thanks
Choosing a FIR filter windows type
Started by ●September 15, 2005
Reply by ●September 15, 20052005-09-15
Mook Johnson wrote:> Wen inplemening a FIR filter, what considerations are given when choosing > between, rectangular, Bertlet, Hanning, Hamming, Blackman, kaiser, etc > windows for the coefficients? > > Basically, aside from the attenuation differences at the first hump in the > stop band, and transition band width, what other characteristics (trade > offs) are to considered?"Ringing" in the passband, for one. Other humps in the stop band, for another. (Compare Hamming to von Hann.) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Mook Johnson wrote:> Wen inplemening a FIR filter, what considerations are given when choosing > between, rectangular, Bertlet, Hanning, Hamming, Blackman, kaiser, etc > windows for the coefficients? > > Basically, aside from the attenuation differences at the first hump in the > stop band, and transition band width, what other characteristics (trade > offs) are to considered?Filter lengths. The filters designed using high attenuation windows like the Blackman window, tend to be longer than the low-attenuation windows for the same transition bandwidth. Rune
"Mook Johnson" <mook@mook.net> wrote in message news:cbdWe.12204$S26.519@tornado.texas.rr.com...> Wen inplemening a FIR filter, what considerations are given when choosing > between, rectangular, Bertlet, Hanning, Hamming, Blackman, kaiser, etc windows > for the coefficients?My consideration is to choose the Kaiser and ignore the rest! Since it has an adjustable parameter, you can taylor it to get the response you want. One reason that you would NOT want to do this is if you had to compute the window coefficients in real-time, in which case Kaiser would be the most computationally intensive option. (I have heard there is a computationally cheaper approximation of Kaiser, but haven't tried it myself.) But for pre-computed filters, this is not a problem.> Basically, aside from the attenuation differences at the first hump in the > stop band, and transition band width, what other characteristics (trade offs) > are to considered?The two things you mention are what I usually look at when tuning a Kaiser window.
