Hi all, I'm trying to perform the OFDM modulation of a DVB-T system. So far, I have the complex valued carriers ck, 1705 altogether (for the 2k mode). To perform the 2048 point IFFT, somehow I have to map this 1705 carriers into 2048 values, xq. My question is, how should I perform this mapping? It seems to me that the solution would be symply padding with 2048-1705 zeros at the end of the input vector. However, in some places I have seen that they do the following: 1) They divide (demux) the carriers in 2 groups. Let's say we have K carriers; carriers from 0 to K/2 in one group (output1) and carriers from K/2+1 to K in another(output2). 2) Then they padd output2 with fftlength-K zeros (appending them in the end) 3)Finally they multiplex output2 (padded) with output1. I don't understand why the carriers from k/2+1 to k are the ones to be fed first in the IFFT module, and why the zeros should be in the middle part of the vector which enters the IFFT module. Does anybody know which is the appropriate way to do it? Another thing is: once I've got the output of the IFFT, whose values are complex, how do I convert this values to real. Should I just take the real part and send it to the channel model? Hope someone can help. Thank you very much, Javi This message was sent using the Comp.DSP web interface on www.DSPRelated.com
IFFT in OFDM
Started by ●September 20, 2005
Reply by ●September 23, 20052005-09-23
On Tue, 20 Sep 2005 06:39:27 -0500, "javi" <javiarrospide@yahoo.es> wrote:> >Hi all, > >I'm trying to perform the OFDM modulation of a DVB-T system. So far, I >have the complex valued carriers ck, 1705 altogether (for the 2k mode). To >perform the 2048 point IFFT, somehow I have to map this 1705 carriers into >2048 values, xq. My question is, how should I perform this mapping? > >It seems to me that the solution would be symply padding with 2048-1705 >zeros at the end of the input vector. However, in some places I have seen >that they do the following: > >1) They divide (demux) the carriers in 2 groups. Let's say we have K >carriers; carriers from 0 to K/2 in one group (output1) and carriers from >K/2+1 to K in another(output2). >2) Then they padd output2 with fftlength-K zeros (appending them in the >end) >3)Finally they multiplex output2 (padded) with output1. > >I don't understand why the carriers from k/2+1 to k are the ones to be fed >first in the IFFT module, and why the zeros should be in the middle part of >the vector which enters the IFFT module. > >Does anybody know which is the appropriate way to do it? > >Another thing is: once I've got the output of the IFFT, whose values are >complex, how do I convert this values to real. Should I just take the real >part and send it to the channel model? > >Hope someone can help. > >Thank you very much, > >JaviDepending on the implementation of an FFT/IFFT, the output/input may be "folded", or not, such that DC appears in the middle carrier or at the first carrier. For the most part being able to swap the halves just makes it easier for people to keep track of what they're doing, depending on whether they prefer it one way or other, or simplify index generation depending on what you want to do with the output/input. It sounds like what they're describing is "folding" the input of the IFFT so that DC is the first term, and the terms around the Nyquist frequency are in the middle, so you put the padding zeroes there. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●September 25, 20052005-09-25
I guess, visualizing iFFT operation as a way of creating sinusoidals of various frequencies might help. Typically, the first point in the iFFT corresonds to DC and is not modulated. The rest of the data gets mapped into various frequencies (subcarriers) around the unmodulated carrier. The resulting spectrum will contain useful information on either side of the carrier frequency. If I understand correctly, the output2 will cause a spectrum on the right of the carrier and the output1 will cause a spectrum to the left of the carrier. If the spectrum is not symmetric, the output will have both real and imaginary compenents. Wont you be loosing informaion by taking only the real part ? Krishna
Reply by ●September 26, 20052005-09-26
