Hello, I am trying to simulate a OFDM signal I would to do the following before Generate a signal and see its charachetrics with delay spread. I have generated a signal and then divided it into parallel signal for multipath, but now I have difficulty generating a delay spread. I would appreciate if some one could help me in this regard. Zigbee Jack
OFDM Help
Started by ●September 21, 2005
Reply by ●September 25, 20052005-09-25
Once the transmit vector is created, one would want to pass it througH the channel having the appropriate delay spread characterisitics. Channel can be modelled as a complex FIR filter. The number of taps of the 'flter' depends on the delay spread of the channel. Regards, Krishna
Reply by ●September 26, 20052005-09-26
Generate the OFDM signal using IFFT. I'm not clear what " divided it into parallel signal for multipath" means. Anyways, once you have the signal , you can convolve the signal with the channel FIR filter. By having a look at the Power delay profile of the channel, generate random taps for the FIR filter with the variance given in the power delay profile. Note that the sampling frequency of the channel is same as that of the signal, only then convolution is valid. Else you will have to upsample the signal or the channel and then convolve. You can see the output of the channel to see the desired effects.
