Hi All, I am a novice to the business of Fixed Point. I have read various papers on implementation of Fixed Point and understood many concepts but have a basic doubt in mind. Actually I am trying to convert an existing filter code available in floating point to fixed point. The program accepts floating point values from a data file and outputs a data file after filtering. I am wondering how to convert this input data to fixed point. As the data file may change it has to be converted inside the program only. So to convert, do I have to multiply the number directly by powers of 2 depending on the Integer Word Length (as we can not use shifting left or right with floating point, the multiplication is the only option) or is there any other way which will not include multiplication at all. Similarly while generating output how can I convert back to floating point without dividing the number by power of 2. I have this question because if actual multiplication is done then it will be done in floating point only. Then I wont be able to generate a code which will fully work on Fixed Point. Sorry for such a big mail, Kindly Reply, Thanks and Regards, bd. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Conversion to Fixed Point
Started by ●September 22, 2005
Reply by ●September 27, 20052005-09-27
http://home.earthlink.net/~yatescr/fp.pdf http://home.earthlink.net/~yatescr/fir.pdf Hope you will get all your answers -sm
