Hi I have just started reading about wavelets and I found the online tutorial by Polikar very helpfull for understanding the basics of the theory: http://users.rowan.edu/~polikar/WAVELETS/WTpreface.html But there are some issues that I struggle with and I thought maybe you good people of comp.dsp can help me with. In part III of the above tutorial: (http://users.rowan.edu/~polikar/WAVELETS/WTpart3.html) figure 3.7 is the CWT of a chirp signal with frequencies 30,20,10,5 Hz in this order. I don't seem to be ale to interpret the CWT result. In particular how do you interpret the value of CWT at largest translation. What I can see from the plot is that we have all the scales say at translation value 90 ? But this is not true seeing the original signal (fig. 3.6) ! I should have better frequency resolution at lower frequencies according to the theory. Appreciate your help H.
wavelet question
Started by ●September 28, 2005
Reply by ●September 28, 20052005-09-28
Henrietta Denoue wrote:> Hi > > I have just started reading about wavelets and I found > the online tutorial by Polikar very helpfull for understanding > the basics of the theory: > http://users.rowan.edu/~polikar/WAVELETS/WTpreface.html > > But there are some issues that I struggle with and I thought > maybe you good people of comp.dsp can help me with. > > In part III of the above tutorial: > (http://users.rowan.edu/~polikar/WAVELETS/WTpart3.html) > > figure 3.7 is the CWT of a chirp signal with frequencies > 30,20,10,5 Hz in this order. > I don't seem to be ale to interpret the CWT result. In particular > how do you interpret the value of CWT at largest translation. > What I can see from the plot is that we have all the scales > say at translation value 90 ? But this is not true seeing the > original signal (fig. 3.6) ! I should have better frequency resolution > at lower frequencies according to the theory.As far as I can tell, it is a matter of the time-bandwidth product. You have to be aware that there is a limit to what frequency (or scale) resolution can be achieved given an observation time. The relation is roughly df >= 1/T [1] where df is the frequency resolution/accuracy and T is the duration of the observation. Wavelets are sligtly different from other filters in that they meet equation [1] by equality, whereas other analyses might perform worse. Rune
