Hi all, Suppose the forced input to the system is f(t), the step response of the system is a(t) and the output is y(t). Now we want to find y(t), I am confused: Which of the following is the correct output y(t)? (1) y(t)=convolution(differentiate(a(t)), f(t)) and (2) y(t)=differentiate(convolution(a(t), f(t)) ??? All "differentiate" and "convolve" operations are w.r.t. "t"... Using infinite summation of piecewise response to the input f(t) and then take limit as n->infinity, I can obtain y(t)=differentiate(convolution(a(t), f(t)); But when think about the diff(step-response of the system)=impulse response of the system, I obtained y(t)=convolution(differentiate(a(t)), f(t)); Please zoom in the following picture to see the detailed derivations... http://www.yourupload.com//uploads/losemind/dc46a-Capture9.JPG -------------------------- Note there the convolution is defined as integration(a(t-u)*f(u), u from 0 to t), instead of the integration(a(t-u)*f(u), u from -infinity to +infinity)... I think this makes a big difference... for the above two equations (1) and (2)... If the convolution is defined as integration(a(t-u)*f(u), u from -infinity to +infinity) the above two equations should be the same... Am I right?
How to decide system response using step response?
Started by ●October 3, 2005
Reply by ●October 3, 20052005-10-03
lucy wrote:> Hi all, > > Suppose the forced input to the system is f(t), the step response of > the system is a(t) and the output is y(t). > > Now we want to find y(t), > > I am confused:... I won't answer your question because I think you can answer it yourself. One way to discern the correct method is applying both to a simple case with known result and observing which method gives that result. When you know which is correct, I think you will easily see why it must be so. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●October 7, 20052005-10-07
I still don't understand it... Please tell me if you know which derivation is correct... Thanks a lot!
lucy wrote:> I still don't understand it... > > Please tell me if you know which derivation is correct... > > Thanks a lot!Your functions are all in time. Since y(t_step) --the step response-- is t integral[y(t_impulse)]dt 0 (where t_impulse is the impulse response and the impulse itself occurs at t=0), Obtain the step response by direct integration and then decide whether convolution or multiplication makes sense. Did I meet you half way? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
lucy wrote:> I still don't understand it... > > Please tell me if you know which derivation is correct...Although trying a known example will not tell you if a derivation is correct, it might tell you if a derivation is incorrect. Do you know of any example step responses? Have you tried them using the methods of each derivation? -- rhn
Reply by ●October 8, 20052005-10-08
The problem is that I could not find a good example to test them... My feeling tells that for convolution defined from -inf to +inf, Cov(diff(f(t)), a(t)) =Cov(f(t), diff(a(t))) =diff(Cov(f(t), a(t))) am I right? For convolution defined from 0 to t, the above do not hold, we have to take initial conditions into consideration, diff(Cov(f(t), a(t))) =f(0)*a(t)+Cov(diff(f(t)), a(t)) =f(t)*a(0)+Cov(f(t), diff(a(t))) am I right? I think I am near that point which clarifies everything...
lucy wrote:> The problem is that I could not find a good example to test them...A unit impulse is the simplest test probe for impulse response. By definition.> My feeling tells that for convolution defined from -inf to +inf, > > Cov(diff(f(t)), a(t)) > =Cov(f(t), diff(a(t))) > =diff(Cov(f(t), a(t))) > > am I right? > > For convolution defined from 0 to t, > the above do not hold, > we have to take initial conditions into consideration, > diff(Cov(f(t), a(t))) > =f(0)*a(t)+Cov(diff(f(t)), a(t)) > =f(t)*a(0)+Cov(f(t), diff(a(t))) > > am I right?You can think of the initial conditions at t = 0 being the result of convolution from -infinity to zero, if you like.> I think I am near that point which clarifies everything...I'm really pleased. I hope you are too. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
