What does PCM mean to you?
Started by Jerry Avins ●October 3, 2005
"Steve Pope" <spope33@speedymail.org> wrote in message
news:dhv5e2$igc$1@blue.rahul.net...
> Jerry Avins <jya@ieee.org> wrote: > >> Steve Pope wrote: > >>> I'm not sure I understand the question. Any analog signal >>> passed into an A/D creates a PCM version of that analog >>> signal, and the A/D can be more than one bit wide. > >>That's just a pulse code. There's no modulation. > > I can understand why that is what you may think, but > my statement above describes what is considered "pulse > code modulation". > > It's just a definition, it's arbitrary, but it's used > consistently in this way.
Yeah, I always thought the "modulation" part was thrown on gratuitously in the textbooks to make it seem like another in the family of PWM, etc.. But to me, PCM always seemed like a different animal entirely.
rhnlogic@yahoo.com wrote:
> Jerry Avins wrote: > >>PCM stands for pulse code modulation. Can there be PCM without >>modulation? Is it still PCM if the modulation carries more than one bit >>per symbol? > > > What a term or abbreviation, such as PCM, might mean is often domain > dependent. Various computer, consumer electronics, and multimedia > "standards" groups have often (re)defined a term when used inside their > particular portion of an industry differently from the usage in other > fields. So what I say below is probably completely irrelevant to > consumer audio labeling. > > I go back to the days when AM, FM, PWM, PAM, PPM and PCM all referred > to various methods of transferring information. PCM signals were > differentiated from P?M in that the data was somehow encoded (via > some table or time sequence usually, but not always, consisting of > "ones" and "zeros"), and thus not directly related to the duration, > amplitude, position or other analog demodulated characteristic of > the signal. > > Unlike another poster, I don't think an A/D was necessary for a > signal to be PCM. The data to be transfered could have started out > completely in the digital domain (from a teletype keyboard for > instance), thus requiring no conversion from analog. > > Since the information to be transfered was "coded" it could pretty > much represent anything (encrypted streams, ASCII or EBCDIC, for > instance. Maybe even morse code?) > > And once the information is stored, it doesn't seem to have anything > to do with "pulses" or "modulation", just coding.
Logic seems to support this minority view. :-) Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
"Jon Harris" <jon99_harris7@hotmail.com> wrote in message
news:3aJ0f.6922$BU1.2844@trnddc06...
> "Steve Pope" <spope33@speedymail.org> wrote in message > news:dhv5e2$igc$1@blue.rahul.net... >> Jerry Avins <jya@ieee.org> wrote: >> >>> Steve Pope wrote: >> >>>> I'm not sure I understand the question. Any analog signal >>>> passed into an A/D creates a PCM version of that analog >>>> signal, and the A/D can be more than one bit wide. >> >>>That's just a pulse code. There's no modulation. >> >> I can understand why that is what you may think, but >> my statement above describes what is considered "pulse >> code modulation". >> >> It's just a definition, it's arbitrary, but it's used >> consistently in this way. > > Yeah, I always thought the "modulation" part was thrown on gratuitously in > the textbooks to make it seem like another in the family of PWM, etc.. > But to me, PCM always seemed like a different animal entirely.
It has essentially become a fancy marketing synonym for "digital".
news:sMydnckE6OIQFN_eRVn-jg@rcn.net...
> Can you cite any credible sources? (Credible is a step down from > authoritative.)
http://www.google.ca/search?hl=en&q=pcm+format
> There was a time when many took "communist" to mean any individual who > disagreed with the speaker's politics, but that didn't make it so.
A tempting diversion, but still dodging the issue -- Y'all should be more civil to Radium. -- Matt
Jerry, this is an interesting topic indeed. It first caught my attention
some years back when someone made an argument in which they implied that
a particular signal was not just digitized, but was PCM, as if it were
some kind of special encoding; and I had to ask myself, is it not just
plain digital data (and what they heck they mean my PCM).
Anyway, I don't know the exact origins, and it's easy to come up with a
half dozens plausible explanations that *could* be right, but I'll just
make a couple of observations:
Modulate means "to change"--so it's pretty easy to make a lot of cases
for change in some manner. If you have digital data in some form (
decimal floating point values in a spreadsheet), and move it to another
form (fixed point values in binary in computer memory), you have a
modulation of some sort.
Also, the sampling process itself is a modulation. One model of sampling
is to take an analog signal (we usually bandlimit it first), and
modulate it by multiplying it by a unit pulse train. This gives us a
modulated pulse train. We then store the height of each pulse by
encoding it as a numerical value (the "code" part?). The result is our
PCM representation of the analog signal. You could say that the data is
our string of pulse codes, from the pulse modulation; the pulse codes
can be converted back to pulses and run through a low pass anti-imaging
filter for analog reconstruction later.
Again, this is something I made up--I don't know if this is the true
origin of the term, but it seems reasonable.
In <ObGdnZw7CNMbQ9_eRVn-ig@rcn.net> Jerry Avins  wrote:
> Steve Pope wrote: >> I'm not sure I understand the question. Any analog signal >> passed into an A/D creates a PCM version of that analog >> signal, and the A/D can be more than one bit wide. > > That's just a pulse code. There's no modulation. > > Jerry
