Image 'spatial frequency resolution' seems to be used to mean: - the highest spatial frequency that can be resolved. Experimentally, an image of sinusoidal intensity is displayed and the contrast varied until the viewer can see the bar pattern. This is using 'spatial frequency resolution' to measure our ability to resolve adjacent light and dark features. I am interested in spatial frequency resolution as in, ability to resolve adjacent spatial frequncies (I think this is closer to a normal definition of 'frequency resolution'). For example, if we have an image with two textures, each representing a spatial frequency, then what separation is required between those spatial frequncies so that we can resolve them (in the frequency spectrum)? I think this will be related to the 'size' of the image relative to the detail within it - similar to 1D DSP where the 'total sampling time' determines the frequency resolution. But I can't find any references to this topic. So will be grateful for any comments or pointers. Thanks, Chris ==================== Chris Bore BORES Signal Processing www.bores.com
Image spatial frequency resolution
Started by ●October 4, 2005
Reply by ●October 4, 20052005-10-04
You may be inventing a metric. You can probably calculate what you want knowing a minimum-resolvable contrast curve (frequency vs. contrast), but you'd have to take a whole bunch of variables into account such as the size of the targets you want to distinguish, their relative contrast, the level to which their position and phase is known, the major angle of the variation, etc., etc., etc. Since you can calculate it all if you know the MRC curve then why use some other non-standard metric for rating your camera? Chris Bore wrote:> Image 'spatial frequency resolution' seems to be used to mean: > - the highest spatial frequency that can be resolved. > Experimentally, an image of sinusoidal intensity is displayed and the > contrast varied until the viewer can see the bar pattern. > > This is using 'spatial frequency resolution' to measure our ability to > resolve adjacent light and dark features. > > I am interested in spatial frequency resolution as in, ability to > resolve adjacent spatial frequncies (I think this is closer to a normal > definition of 'frequency resolution'). > > For example, if we have an image with two textures, each representing a > spatial frequency, then what separation is required between those > spatial frequncies so that we can resolve them (in the frequency > spectrum)? > > I think this will be related to the 'size' of the image relative to the > detail within it - similar to 1D DSP where the 'total sampling time' > determines the frequency resolution. > > But I can't find any references to this topic. So will be grateful for > any comments or pointers. > > Thanks, > > Chris > ==================== > Chris Bore > BORES Signal Processing > www.bores.com >-- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Chris Bore wrote:> Image 'spatial frequency resolution' seems to be used to mean: > - the highest spatial frequency that can be resolved. > Experimentally, an image of sinusoidal intensity is displayed and the > contrast varied until the viewer can see the bar pattern. > > This is using 'spatial frequency resolution' to measure our ability to > resolve adjacent light and dark features. > > I am interested in spatial frequency resolution as in, ability to > resolve adjacent spatial frequncies (I think this is closer to a normal > definition of 'frequency resolution'). > > For example, if we have an image with two textures, each representing a > spatial frequency, then what separation is required between those > spatial frequncies so that we can resolve them (in the frequency > spectrum)? > > I think this will be related to the 'size' of the image relative to the > detail within it - similar to 1D DSP where the 'total sampling time' > determines the frequency resolution. > > But I can't find any references to this topic. So will be grateful for > any comments or pointers.Chris, Look into "modulation transfer function" (MTF) It is commonly applied to lenses and the images they produce, and was developed by Otto Schade (I knew him) to rationalize TV analysis. He published mostly in the SMPTE journal, but references abound today. An illustrated tutorial in photographic terms: http://www.normankoren.com/Tutorials/MTF.html. I suspect that it isn't right on the mark for you, but some knowledge of it will deepen your understanding of what you really do want and allow the right questions to be well put. Oh, yes: welcome back! Jerry P.S. I haven't figured out what "Pattern contrast drios ub half at 42 cycles/mm." was intended to be. I asked: we'll see. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Thanks, Jerry. I'm looking into this in connection with digital camera design - sampling sensors, and associated ways to enhance or 'correct' the image. MTF may be the key, but I can't quite wrap my mind around it yet to be sure. :-) MTF seems aimed at describing the frequency response of the imaging system, but perhaps focussing :-) on the optical/CCD/sensor area aspects of this? I'm interested to understand the effect of selecting only a region of the scene to image. MTF is the frequency response of the imaging system - if you like, its frequency response to an impulse? So in a sampled system (eg CCD array) the MTF will be periodic, with the 'original image' tiling all space - leading to aliasing, as in the 1D case? The MTF then explains aliasing, as well as its intended aim of describing attenuation of (usually higher) spatial frequencies? Now, though, as well as sampling let's introduce the fact that we measure only over a finite region of space. Think of this as sampling the image over all space, then multiplying that with a 'box' with 1's inside and 0's outside. The MTF then becomes convolved with the 'MTF of the box' - spread, because of the truncation of the image outside the box. It may be this is obvious to everyone except me, but... ..the spreading of the MTF will mean that we are unable to resolve two spatial frequencies that are close. This is not the same as the 'resolve two adjacent lines' thing. I think it means that some textures, that are already close in spatial frequency, will become indistinguishable. It may be unimportant, but think of Al Bovis' example of a fingerprint image where aliasing makes the print completely different... ..also, if we follow a crude model of signal truncation causing Gibbs' phenomenon, then the spreading of MTF will depend on the amplitude of the image at the edges and so will vary depending on the scene - artefacts then being scene-dependent which could be more annoying (or more difficult to detect) than scene-independent artefacts. This could lead us to implement windowing (as in window filter design) to reduce the variations. It may seem like worrying over some tiny detil, but since much image correction will be done in the frequency domain (and even if not, the math will have been worked out that way) then I want to understand these issues properly before I discard them as of no importance. Oh, and thanks for welcoming me back. A mad schedule of travel, and focus on CPU architectures and video programming, over the past few years has meant I had little time to devote to fundamental topics. It is nice to make contact again. Chris ======================== Chris Bore BORES Signal Processing www.bores.com
> P.S. I haven't figured out what "Pattern contrast drios ub half at 42 cycles/mm." was intended to be. I asked: we'll see.I think he meant to say: "Pattern contrast drops by half at 42 cycles/mm". This would fit with the image shown, and with his idea that 50% contrast drop is the psychologically point at which we stop bothering to resolve detail. 'drops' becomes 'drios' if you let your fingers drift left one key for the two middle letters. 'by' becomes 'ub' if you type the letters in the reverse order and drift right one key on the 'y'. :-) Chris ================= Chris Bore BORES Signal Processing www.bores.com
Chris Bore wrote:> Thanks, Jerry. > > I'm looking into this in connection with digital camera design - > sampling sensors, and associated ways to enhance or 'correct' the > image. MTF may be the key, but I can't quite wrap my mind around it yet > to be sure. :-) > > > MTF seems aimed at describing the frequency response of the imaging > system, but perhaps focussing :-) on the optical/CCD/sensor area > aspects of this? I'm interested to understand the effect of selecting > only a region of the scene to image. > > MTF is the frequency response of the imaging system - if you like, its > frequency response to an impulse? So in a sampled system (eg CCD array) > the MTF will be periodic, with the 'original image' tiling all space - > leading to aliasing, as in the 1D case? The MTF then explains aliasing, > as well as its intended aim of describing attenuation of (usually > higher) spatial frequencies?Yes. Aliasing isn't normally a problem, though. There are in any event ways to deal with it. As you might expect, one trades away resolution.> Now, though, as well as sampling let's introduce the fact that we > measure only over a finite region of space. Think of this as sampling > the image over all space, then multiplying that with a 'box' with 1's > inside and 0's outside. The MTF then becomes convolved with the 'MTF of > the box' - spread, because of the truncation of the image outside the > box.Good eyes distinguish .003" at an "inspection" viewing distance, but .01" is a more usual measure. the MTF of a box much larger than that -- say 20 times -- has little effect.> It may be this is obvious to everyone except me, but... > > ..the spreading of the MTF will mean that we are unable to resolve two > spatial frequencies that are close. This is not the same as the > 'resolve two adjacent lines' thing. I think it means that some > textures, that are already close in spatial frequency, will become > indistinguishable. It may be unimportant, but think of Al Bovis' > example of a fingerprint image where aliasing makes the print > completely different...Undersampling is bad in polling and fingerprinting. We know how to do both right.> ..also, if we follow a crude model of signal truncation causing Gibbs' > phenomenon, then the spreading of MTF will depend on the amplitude of > the image at the edges and so will vary depending on the scene - > artefacts then being scene-dependent which could be more annoying (or > more difficult to detect) than scene-independent artefacts. This could > lead us to implement windowing (as in window filter design) to reduce > the variations.All the popular explanations aside, there is a very simple definition of MTF: the Fourier transform of the line-spread function. Not only a practical way to measure, it provides the answer to many questions.> It may seem like worrying over some tiny detil, but since much image > correction will be done in the frequency domain (and even if not, the > math will have been worked out that way) then I want to understand > these issues properly before I discard them as of no importance. > > Oh, and thanks for welcoming me back. A mad schedule of travel, and > focus on CPU architectures and video programming, over the past few > years has meant I had little time to devote to fundamental topics. It > is nice to make contact again.In a digital camera, diffraction (small lens openings) and diffusion (a plate just in front of the sensor array) are practical anti-alias filters. Cameras with high MTFs at the Nyquist limit can aliasing, but care must be taken to demonstrate it. (Sometimes, bad luck replaces care.) Koren's tutorial is well worth reading despite its emphasis on film. Everything I've written here and more has its parallel there. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
I was wondering about the function of lens and diffuser as antialias filters. For instance, if a lens were used that had a sharper focus than one CCD sensor, then aliasing would be more of a problem - which I think is demonstrated in several examples I have seen. Yes, the tutorial is very good, even though it doesn't deal much with sampling. Another very good reference is Al Bovik's book 'image and video processing' which also has some really useful examples. Chris
"Chris Bore" <chris.bore@gmail.com> wrote in message news:1128448706.080451.153880@o13g2000cwo.googlegroups.com...> >> P.S. I haven't figured out what "Pattern contrast drios ub half at 42 >> cycles/mm." was intended to be. I asked: we'll see. > > I think he meant to say: "Pattern contrast drops by half at > 42 cycles/mm". > > This would fit with the image shown, and with his idea that 50% > contrast drop is the psychologically point at which we stop bothering > to resolve detail. 'drops' becomes 'drios' if you let your fingers > drift left one key for the two middle letters. 'by' becomes 'ub' if you > type the letters in the reverse order and drift right one key on the > 'y'. :-) > > Chris > ================= > Chris Bore > BORES Signal Processing > www.bores.comChris, Have you pondered the uses of a "zone plate"? http://www.worldserver.com/turk/opensource/ http://www.optexint.com/pdf/tc66.pdf http://www.imatest.com/docs/tour_testcharts.html http://www.cinedrome.ch/hometheater/testpatterns/zoneplate.html Relative to the comment about resolving lines in 1-D, why isn't it the same thing? Why isn't the 2-D equivalent of a sinc still not the resolution limiting function? Fred
Reply by ●October 5, 20052005-10-05
"Chris Bore" <chris.bore@gmail.com> wrote in message news:1128433077.819819.301030@g47g2000cwa.googlegroups.com...> Image 'spatial frequency resolution' seems to be used to mean: > - the highest spatial frequency that can be resolved. > Experimentally, an image of sinusoidal intensity is displayed and the > contrast varied until the viewer can see the bar pattern. > > This is using 'spatial frequency resolution' to measure our ability to > resolve adjacent light and dark features. > > I am interested in spatial frequency resolution as in, ability to > resolve adjacent spatial frequncies (I think this is closer to a normal > definition of 'frequency resolution'). > > For example, if we have an image with two textures, each representing a > spatial frequency, then what separation is required between those > spatial frequncies so that we can resolve them (in the frequency > spectrum)? > > I think this will be related to the 'size' of the image relative to the > detail within it - similar to 1D DSP where the 'total sampling time' > determines the frequency resolution. > > But I can't find any references to this topic. So will be grateful for > any comments or pointers. >Hello Chris, I haven't seen you post here in a while - welcome back. It seems like what you are asking about actually spans several photographic topics. The 1st deals with raw resolution. In the case with 35mm camera systems it is not unusual to have lenses resolve anywhere in the range of 75 to 120 line pairs per mm. Leica had one that actually resolved over 200 lp/mm! The film 's area (35mm format) is 24 by 36 mm. However extensive sampling of slides taken by professional photographers show their resolution tops out at 73 lp/mm. And most were under 60 lp/mm. And these are the quality images. The practical limitation mostly stems from camera handling - mirror slap and shutter shake and a little from dye bleed (diffusion) in the film. Many of today's digital SLRs use either an APS sized sensors - about 16 by 24 mm and there are a few models having "full frame" sensors with 24 by 36 mm areas. Some of the lower ranked models with say 6MP basically hit the Nyquist limit around 40 or so lp/mm. The densest sensor is currently in the Nikon D2X which crams 12.4MP into a 16 by 24 mm sensor. This tops out at over 60lp/mm. Some amateurs have been disappointed with the D2X, since its high resolution reveals any weaknesses in the lenses and camera handling techniques. The anti-alias filter is sometimes described as a blurry piece of glass. Actually these are made of exotic materials and on the newer DSLRs not only perform the anti-alias function but also IR and UV rejection. My D100 sees IR from my studio strobes so when they are used in combination with sunlight I end up with mixed color lighting. However with a D2X, the strobe's color match to the sun. The sensor, as you are probably aware, uses a Bayer color filter array - except for Foveon sensors. This has the property of sampling the green channel at nearly twice the rate of the red and blue channels. So in the case where a camera manufacturer has used a weak anti-alias filter, the problem of color more' arises. Kodak's DCS-14N is a 14MP full frame camera with no anti-alias filter. Its replacements - the Pro SLR 14/n and Pro SLR 14/c needless to say did. Also unlike film, digital sensors really prefer that the light strike them at a nearly normal angle. So today's sensors have micro lenses. When light strikes the sensor from strongly oblique angles (wide angle lenses especially on full frame cameras) suffer from light falloff and exaggerated chromatic aberration. Currently I don't know of a single standard by which to measure today's optical systems. And yes photography is moving towards the system concept and away from the idea of the sensors and lenses working independently. Lateral chromatic aberration and vignetting are easily handled in post processing now. Plus both Canon and Nikon offer lenses with reduced image coverage for cameras with APS sized sensors. Also these newer wideangle lense are being designed with nearly telecentric optics to ward off problems. With film, wide angle lenses were simple retrofocus (opposite of telephoto) designs. When you talk about comparing textures of two similar fabrics, one of the things that comes to mind is the idea of local contrast as espoused in Ansel Adams zone method. Typically fabric detail is low contrast which means it probably spans 1/2 to 1/3 of an F stop in brightness. So your optical system will have to be specked to a spatial frequency at a given low contrast. I hope I've given some food for thought. Clay
Chris Bore wrote:> I was wondering about the function of lens and diffuser as antialias > filters. > > For instance, if a lens were used that had a sharper focus than one CCD > sensor, then aliasing would be more of a problem - which I think is > demonstrated in several examples I have seen. > > Yes, the tutorial is very good, even though it doesn't deal much with > sampling.It deals with digital photography and scanning, and discusses aliasing and moires in those contexts.> Another very good reference is Al Bovik's book 'image and video > processing' which also has some really useful examples.Thanks for the reference. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
