On 2004-08-07 19:34:32 +0200, Jerry Avins <jya@ieee.org> said:>>> "dfr16RFFT" and "dfr16IFFT". ... "dfr16RIFFT" ... > > I didn't see existing differences. (Believe me: I looked long and hard.) > Later, I found them, but I didn't delete my message in time. Chalk it up > to old age if you like, but in reality, I seem to be somewhat dyslexic. > > JerryHi Jerry, I don't think that your sight or language skills are in question here. In my opinion, whoever is responsible at Motorola for naming the FFT routines thusly should be hanged with his balls on a tree (direct translation of the German saying "Er geh�rt an den Eiern aufgeh�ngt"). It's almost as bad as using underscores in function names... ;-) -- Stephan M. Bernsee http://www.dspdimension.com
FFT and IFFT problems on the Motorola 56F8323
Started by ●August 5, 2004
Reply by ●August 8, 20042004-08-08
Stephan M. Bernsee wrote:> On 2004-08-07 19:34:32 +0200, Jerry Avins <jya@ieee.org> said: > >>>> "dfr16RFFT" and "dfr16IFFT". ... "dfr16RIFFT" ... >> >> >> I didn't see existing differences. (Believe me: I looked long and hard.) >> Later, I found them, but I didn't delete my message in time. Chalk it up >> to old age if you like, but in reality, I seem to be somewhat dyslexic. >> >> Jerry > > > Hi Jerry, > > I don't think that your sight or language skills are in question here. > > In my opinion, whoever is responsible at Motorola for naming the FFT > routines thusly should be hanged with his balls on a tree (direct > translation of the German saying "Er geh�rt an den Eiern aufgeh�ngt"). > > It's almost as bad as using underscores in function names... ;-)It probably seebed like a good odea at the time. There's no use nor agitating over what might have been. "Wenn meine Bubbe Eier hatte ..." (For those at home: "If by grandmother had balls, she would have been my grandfather.") Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
