Hi all, I am new to DCT and now testing my FDCT and IDCT program. I found some of my high frequency DCT part is higher than low frequency DCT part. And I don't know whether it is correct. Where can I find example of 8*8 DCT input and output to test my code,thanks! BTW, my code's DCT input: 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 60 58 55 my code's DCT output: 461 0 -1 0 -1 -1 1 0 0 0 0 0 0 -2 0 0 -1 0 -1 0 -2 -1 2 0 0 0 0 0 0 -2 -1 0 -1 0 -2 0 -3 -3 4 0 1 -2 1 -2 3 -11 -3 1 1 0 2 1 4 3 -5 0 0 0 0 0 0 1 0 0 Any suggestions will be appreciated! All the best, Davy
Simple DCT problem
Started by ●October 8, 2005
Reply by ●October 9, 20052005-10-09
Davy wrote:> Hi all, > > I am new to DCT and now testing my FDCT and IDCT program. > I found some of my high frequency DCT part is higher than low frequency > DCT part. > And I don't know whether it is correct. > > Where can I find example of 8*8 DCT input and output to test my > code,thanks! > > BTW, > my code's DCT input: > 55 60 58 55 60 58 55 60 > 58 55 60 58 55 60 58 55 > 60 58 55 60 58 55 60 58 > 55 60 58 55 60 58 55 60 > 58 55 60 58 55 60 58 55 > 60 58 55 60 58 55 60 58 > 55 60 58 55 60 58 55 60 > 58 55 60 58 55 60 58 55 > my code's DCT output: > 461 0 -1 0 -1 -1 1 0 > 0 0 0 0 0 -2 0 0 > -1 0 -1 0 -2 -1 2 0 > 0 0 0 0 0 -2 -1 0 > -1 0 -2 0 -3 -3 4 0 > 1 -2 1 -2 3 -11 -3 1 > 1 0 2 1 4 3 -5 0 > 0 0 0 0 0 1 0 0 > > Any suggestions will be appreciated!And what does the inverse of the DCT give from the above?> All the best, > DavyTest it initially with simple patterns that you can work out by hand. Walking ones will give you a fairly easy test pattern for DCT that should quickly show if your implementation is OK. 1 0 0 0 0 0 0 0 etc. Regards, Martin Brown
Reply by ●October 10, 20052005-10-10
> > Where can I find example of 8*8 DCT input and output to test my > > code,thanks!Simplest way is to use the inbuilt dct&idct functions of MATLAB to obtain a test vector. Good Luck. Parthasarathy
Reply by ●October 14, 20052005-10-14
to test use the source code proposed by http://skal.planet-d.net/coding/dct.html note : - there is lot's of different implementation of the DCT. - some are very fast but less accurate - if you deal with an mpeg video std implementation only idct is describe and should respect I3E-1394 precision. DCT is the encoding part and it's not normalized !!! - you should find on the web an IEEE-1394 idct tester which test if your implentation respect the standard requirement. good luck Davy wrote:> Hi all, > > I am new to DCT and now testing my FDCT and IDCT program. > I found some of my high frequency DCT part is higher than low frequency > DCT part. > And I don't know whether it is correct. > > Where can I find example of 8*8 DCT input and output to test my > code,thanks! > > BTW, > my code's DCT input: > 55 60 58 55 60 58 55 60 > 58 55 60 58 55 60 58 55 > 60 58 55 60 58 55 60 58 > 55 60 58 55 60 58 55 60 > 58 55 60 58 55 60 58 55 > 60 58 55 60 58 55 60 58 > 55 60 58 55 60 58 55 60 > 58 55 60 58 55 60 58 55 > my code's DCT output: > 461 0 -1 0 -1 -1 1 0 > 0 0 0 0 0 -2 0 0 > -1 0 -1 0 -2 -1 2 0 > 0 0 0 0 0 -2 -1 0 > -1 0 -2 0 -3 -3 4 0 > 1 -2 1 -2 3 -11 -3 1 > 1 0 2 1 4 3 -5 0 > 0 0 0 0 0 1 0 0 > > Any suggestions will be appreciated! > All the best, > Davy >
Reply by ●October 15, 20052005-10-15
