Hello again and thank you for your answers I will try to describe my scenario 1. I am working with UWB signals, which is real, s(t), and has Fourier transform S(w). 2. I apply one filter H(w), which has gain A(w) and phase Theta(w), w = angular frequency. Then H(w) = A(w)*exp(j*Tetha(w)*to); 3. In digital domain, I decide what I get, lets say the real part, real(ifft(S(w)*H(w))), or the imaginary part (the signal represented by the imaginary part) or the magnitude (abs(A(W))). 4. My question is about the analog domain. From the answers I got, it seems that naturally I get the real part, and can extract the others (imag and abs) by different circuits. But what about the ENERGY of the filtered signal? is it equal to the incoming signal (assuming a passive filter) or there is some energy left somewhere. In digital domain I can get the energy of both, real(S(w)*H(w)) or imag(S(w)*H(w)). However in analog domain it is not that obvious, most of books which I have access to, deal with design, and evaluation of filters, but so far I couldnt find the answer I want, In fact, I NEED THE ENERGY OF THE ANALOG FILTERED SIGNAL. The reason why I ask this question is because of my laboratory experiments on alternatig current, i.e. at the ouput of a resonant circuit you may measure zero volts, however if you measure at the edges of L or C, there is indeed voltage. And also antennas can be modeled as filters where gain and phase functions are provided. again what is my output? the real part? thanks Greg This message was sent using the Comp.DSP web interface on www.DSPRelated.com
s the output of an analog filter real or the magnitude?(2)
Started by ●October 19, 2005
Reply by ●October 19, 20052005-10-19
"Gregwise" <gregoguti@mixmail.com> wrote in message news:5qGdnVj94_PAecjeRVn-2A@giganews.com...> Hello again and thank you for your answersHi Greg - I didn't attempt any sort of answer before as I was confused as to what you were looking for; now I'm even more confused but I'm going to try anyway - hope some of this helps.> I will try to describe my scenario > 1. I am working with UWB signals, which is real, s(t), and has Fourier > transform S(w).Are you assuming that this real signal is provided from a constant impedance source having only a resistive component across the full frequency band that your signal has any significant energy spectral density in?> 2. I apply one filter H(w), which has gain A(w) and phase Theta(w), w = > angular frequency. Then H(w) = A(w)*exp(j*Tetha(w)*to);I don't know what your *to factor is.> 3. In digital domain, I decide what I get, lets say the real part, > real(ifft(S(w)*H(w))), or the imaginary part (the signal represented by > the imaginary part) or the magnitude (abs(A(W))).Why is there no IFFT or S(w) term in your magnitude ?> 4. My question is about the analog domain. From the answers I got, it > seems that naturally I get the real part, and can extract the others (imag > and abs) by different circuits. But what about the ENERGY of the filtered > signal? is it equal to the incoming signal (assuming a passive filter) or > there is some energy left somewhere.Generally the filter will reflect some of the source signal energy back into the source and/or will dissipate some of the energy in resistive losses.> In digital domain I can get the energy of both, real(S(w)*H(w)) or > imag(S(w)*H(w)). However in analog domain it is not that obvious, most of > books which I have access to, deal with design, and evaluation of filters, > but so far I couldnt find the answer I want, In fact, I NEED THE ENERGY OF > THE ANALOG FILTERED SIGNAL.O.K. you maybe need to calculate how much of the energy supplied by the source is available to a load at the other side of your filter.> > The reason why I ask this question is because of my laboratory experiments > on alternatig current, i.e. at the ouput of a resonant circuit you may > measure zero volts, however if you measure at the edges of L or C, there > is indeed voltage. And also antennas can be modeled as filters where gain > and phase functions are provided. again what is my output? the real part?Your output is whatever you define it to be. You are presumably doing all of this to cause some wanted effect somewhere while avoiding some other unwanted effects elsewhere (e.g. have a high probablity that your transmitted pulse is detected by a known receiving system at some remote location in the presence of interference while making sure that you don't trip the operator's pacemaker very often.) , your wanted receiver may be a test probe and detector circuitry in a particular reference configuration - until you have this defined I don't see how you can start to talk about your output. Is it that you want to calulate the energy dissipated in a purely resistive load of constant known impedance at the output of your filter and that the transfer function you have is calculated taking the effects of source and load impedance into account? If so http://en.wikipedia.org/wiki/Parseval's_theorem should help. Otherwise I don't know where you should start.> > thanksBest of Luck Mike
Gregwise wrote:> Hello again and thank you for your answers > I will try to describe my scenario > 1. I am working with UWB signals, which is real, s(t), and has Fourier > transform S(w). > 2. I apply one filter H(w), which has gain A(w) and phase Theta(w), w = > angular frequency. Then H(w) = A(w)*exp(j*Tetha(w)*to); > 3. In digital domain, I decide what I get, lets say the real part, > real(ifft(S(w)*H(w))), or the imaginary part (the signal represented by > the imaginary part) or the magnitude (abs(A(W))).If the filter is realizable in the time domain without giving it explicitly complex coefficients then ifft(S(w)*H(w)) will always be real. Do you mean to say that you only know how to do filtering using Fourier transforms?> 4. My question is about the analog domain. From the answers I got, it > seems that naturally I get the real part, and can extract the others (imag > and abs) by different circuits. But what about the ENERGY of the filtered > signal? is it equal to the incoming signal (assuming a passive filter) or > there is some energy left somewhere.Energy conservation rules must apply. Real-world passive filters either bounce energy back out the port it's coming in, pass it through to some other port, or dissipate it as heat.> In digital domain I can get the energy of both, real(S(w)*H(w)) or > imag(S(w)*H(w)).This is not the case that you cited in (3) above. There you were taking the inverse transform, here you are doing things entirely in the frequency domain. In general ifft(real(S(w)*H(w))) != real(ifft(S(w)*H(w))).> However in analog domain it is not that obvious, most of > books which I have access to, deal with design, and evaluation of filters, > but so far I couldnt find the answer I want, In fact, I NEED THE ENERGY OF > THE ANALOG FILTERED SIGNAL.Well, I've already told you how to do that. And don't SHOUT, particularly to folks who are trying to help. It makes them want to ignore you.> > The reason why I ask this question is because of my laboratory experiments > on alternatig current, i.e. at the ouput of a resonant circuit you may > measure zero volts, however if you measure at the edges of L or C, there > is indeed voltage.At the output of a real-world resonant circuit with real-world components you will never attain complete nulling of the signal, although you may be able to pound it down small enough that your measuring instruments won't detect it. You will, indeed, see high circulating energy in the interior of an LC circuit that is operating at it's resonant frequency. They'll show up as high voltages in a series LC and high currents in a parallel LC. But the effective impedance will be such that in an ideal circuit there won't be any energy being dissipated.> And also antennas can be modeled as filters where gain > and phase functions are provided. again what is my output? the real part? >In the real world it's always the real part. I think you have the mistaken notion that the frequency domain is something real. Pull your head out of your assumptions and look around you. Everything that you experience, everything that affects your software and your circuits happens in the time domain. The Fourier transform and the frequency domain that goes with it is just a mathematical tool that helps you solve problems in linear system analysis. Since nothing in this universe is linear the frequency domain is not the primary reality, it is merely a highly useful reflection. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Gregwise wrote:> Hello again and thank you for your answers > I will try to describe my scenario > 1. I am working with UWB signals, which is real, s(t), and has Fourier > transform S(w). > 2. I apply one filter H(w), which has gain A(w) and phase Theta(w), w = > angular frequency. Then H(w) = A(w)*exp(j*Tetha(w)*to); > 3. In digital domain, I decide what I get, lets say the real part, > real(ifft(S(w)*H(w))), or the imaginary part (the signal represented by > the imaginary part) or the magnitude (abs(A(W))). > 4. My question is about the analog domain. From the answers I got, it > seems that naturally I get the real part, ...No. You get the magnitude -- sqrt(Re^2 + Im^2) -- and the phase. In short, you get the filtered signal. Be aware: both Re and Im are real. It takes two wires (aside from ground) to represent a complex signal. Note "represent". The signal on each wire is real. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
