in article 1130018797.195034@ostenberg.wh.uni-dortmund.de, Martin Eisenberg at martin.eisenberg@udo.edu wrote on 10/22/2005 18:06:> Seek simplicity and mistrust it. > --Alfred Whiteheadin article juednc3tHLeRQMfeRVn-tg@comcast.com, Robert E. Beaudoin at rbeaudoin@comcast.net wrote on 10/22/2005 20:44:> You're welcome! I like the Whitehead quote you used as a sig.i like it, too. it's kinda a counterweight to Occam's Razor. the Einstein quote that Bob Cain puts in his sig, is probably the optimal position between the two extremes. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
A question about continuous derivatives
Started by ●October 21, 2005
Reply by ●October 22, 20052005-10-22
Reply by ●October 23, 20052005-10-23
robert bristow-johnson wrote:> in article 1129968325.560607.57340@z14g2000cwz.googlegroups.com, > abariska@student.ethz.ch at abariska@student.ethz.ch wrote on 10/22/2005 > 04:05: > > > robert bristow-johnson wrote:...> >>> What about windowed sinc? > >> > >> all derivatives are continuous until you get to the place where the window > >> is spliced to silence. then at least *some* derivative at some order has to > >> have a jump discontinuity. > > > > This is not necessarily the case. > > it *is* necessarily the case. > > > Some windows are infinitely often differentiable. > > not at where they get spliced to silence.I don't know if you have read Robert's post, but it describes the general idea of the construction of a window that is non-zero only on a closed interval and continuously differentiable on the whole real numbers. The existence of such windows ("smooth functions with compact support") is quite essential for distribution theory.
Reply by ●October 25, 20052005-10-25
mike@unknown.no.spam.com wrote:> am I right to say that the higher the order of a B-spline, the more > continuous derivatives it has?> And that sinc interpolation has infinite continuous derivatives?My first thought when I saw continuous and derivative in the same sentence was not that the derivative itself was continuous, but that the derivative order was. Consider the derivatives of x**y. First derivative y*x**(y-1) Second derivative y*(y-1)*x**(y-2). Nth derivative (y!/(y-N)!)*x**(y-n). Use the Gamma function instead of factorial, and it can be defined for non-integer N. After a few seconds I realized that this was not the original question, but that was my first thought when I saw it. -- glen
