What is the best modulation scheme?
Started by Unknown October 26, 2005
"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message
news:esu4m1pv81dunalatgulhoms0spjf17h5n@4ax.com...
> > The symbol rate is typically equal to the 3dB bandwidth of the signal > for QAM. So in 1MHz bandwidth you can have a 1MHz symbol rate, but > you need some extra on either side for the skirts, and how much more > is needed depends on the type of filtering that is being employed. > > As Mark mentioned, it's not too hard to get a 5.36MHz symbol rate in a > 6Mhz channel with the rest of it used as guardband for the skirts and > margin for adjacent channel interference. > > You have to do exactly the same thing for OFDM. You can't just pile > the subcarriers up to the edges of the band, because spectral regrowth > from the amplifier (and other impairments) still mean that you need > some guard band, and it winds up being about the same as for a single > carrier system. > > Not only that, but in OFDM you have to slow the symbol rate further > than you might think in order to accomodate the cyclic prefix or > cyclic extension. The CP/CE provide lots of goodness for multipath > handling, but are dead weight as far as information transmission is > concerned. For this reason sometimes when somebody waves the "OFDM is > more spectrally efficient" card, I wave the "no it's not, it's LESS > spectrally efficient" card just to make the comparison. In most > cases when it gets down to the real engineering there is little or no > difference in spectral efficiency between OFDM and single carrier > systems in my experience. > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.org
Hi Eric, Thanks for the answer, I realized I was wrong after I had a look at the pre-adsl modem protocols (e.g. v.34)... Anyway, I agree with you 100%.
Hi Eric,
Thank you for some of the opinions about the OFDM trade-offs study.
Well, the bill will be too costly to a poor student :-)
Regards,
Lindah
> Lindah, > > To me it comes down to equalizer complexity. For OFDM systems the > equalizer is easily bounded, for a QAM system, especially at a very > high symbol rate, the equalizer complexity can quickly get out of hand > if the channel delay spread is very long at all. > > It's not difficult to make a first-order tradeoff analysis. For the > OFDM system add a cyclic prefix to the symbols that's _at minimum_ the > length of the longest expected channel delay spread, and see how much > it'll hurt to maybe use 1.5x or 2x that length to accomodate filter > effects and other stuff that gets in the way. Tradeoff subcarrier > spacing against the coherence bandwidth and the symbol rates that you > can process (keeping the CP to 1/3 or less, I like a lot less, of the > symbol is good for efficiency) and see what the system starts to look > like. This gives an idea of how big/fast/ugly the FFT, channel > estimator, etc., are going to be. > > Figure out the data rates that you can expect with such a system, and > then see what it takes to do the same with a single-carrier. > Whatever the symbol rate turns out to be, the EQ then needs to be > around the number of taps as T goes into the delay spread. It gets > ugly in a hurry for high-symbol-rate systems. This is why so many > wideband systems these days are OFDM if the channel delay spread is > very long. > > You've probably already done some or all of this, so ignore me as > suitable. But to me that's pretty much the basis of the real > tradeoffs between OFDM and single carrier. OFDM does, however, let > you do all kinds of other cool things like adaptive bit loading, power > loading, OFDMA, etc., that just isn't practical with single carrier > systems. > > Hope that helps a bit or two. Where should I send the bill? ;) > > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.org
On 1 Nov 2005 05:38:48 -0800, lindah74uk@yahoo.co.uk wrote:
>Hi Eric, > >Thank you for some of the opinions about the OFDM trade-offs study. >Well, the bill will be too costly to a poor student :-) > >Regards, >Lindah
:) No problem on the bill. I'll just start an account for you... ;) Just kidding, you're most welcome to the advice. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
