elementary question on channel equalization
Started by Bill Thomas November 4, 2005
Dear All,
I'm new to DSP and channel equalization topic and kindly ask you about some
fundamental questions:
-If I want to send a binary data on an AWGN channel with ISI, how do I know
at the
receiver side, what was the sent information? Because it's easy to
confuse -1 and 1..
-why it is good to send a training sequence at the beginning?
-What is theoretical BER and why we can't achive this?
-If I have SNR=30dB then what's the relationship between the signal and
noise energy?
I'd be very happy if somebody could answer me, these are so fundamental
issues that
I couldn't find them in the digital communication related books I have!
Tom
On Sat, 5 Nov 2005 02:20:50 +0100, "Bill Thomas"
<anytime@anywhere.com> wrote:
>Dear All, > >I'm new to DSP and channel equalization topic and kindly ask you about some >fundamental questions: > >-If I want to send a binary data on an AWGN channel with ISI, how do I know >at the >receiver side, what was the sent information? Because it's easy to >confuse -1 and 1..
Assuming this isn't homework... What sort of modulation are you assuming (assuming you are assuming a modulation)? For antipodal modulations like BPSK 1 and -1 are as different as you can make them in order to minimize decision errors. I'm not sure why you think one would confuse 1 with -1.
Since you're asking about equalizers, the general idea is that you want the equalizer trained and converged to a good solution before the data arrives. If you're training the equalizer during the data, the information bits that go by during the training will be less reliable than bits demodulated after the equalizer has converged. For this reason in many systems a preamble is used to provide time for signal synchronization, channel estimation and equalizer training before the data arrives.
There is more than one flavor of theoretical BER, so I'm not quite sure how to answer this. e.g., there is the so-called "matched filter bound" which is the theoretical performance that can be achieved without coding of any kind. That one can be achieved within a pretty slim margin without too much trouble. If you're talking about the Shannon limit, or capacity, or some theoretical maximum performance like that, then it, too, can be approached pretty closely with current technology. Practical capacity-approaching codes have only existed for about ten years or so, but they do exist.
>-If I have SNR=30dB then what's the relationship between the signal and >noise energy?
SNR is a power ratio, but it isn't hard to convert it to an energy ratio like Eb/No. These sorts of relationships are not difficult to find in most comm texts.
>I'd be very happy if somebody could answer me, these are so fundamental >issues that >I couldn't find them in the digital communication related books I have!
Most of these topic are covered in decent modern texts, but you may just be having trouble finding them if you're unfamiliar with the terminology, etc. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
