Hi, I simulated a QPSK Symbol Rrror Recovery mechanism using interpolation menthod. I used a gardner TED which works only for the case where there is a symbol trensition. I would like to know of any algorithm which works for the case even without trnsition. (I didnt find Muller-Muller method very good). What if I want to simulate Symbol recovery using the same interpolation method for 16-QAM. What algorithm would be suitable for TED of the QAM system. Thanks Best Regards Rajenish
Timing Error Detection using Gardner and other methods
Started by ●December 7, 2005
Reply by ●December 7, 20052005-12-07
On Wed, 07 Dec 2005 04:14:28 -0600, "Rajenish_jain" <rajenish.jain@gmail.com> wrote:>Hi, > I simulated a QPSK Symbol Rrror Recovery mechanism using interpolation >menthod. I used a gardner TED which works only for the case where there is >a symbol trensition. I would like to know of any algorithm which works for >the case even without trnsition. (I didnt find Muller-Muller method very >good). > >What if I want to simulate Symbol recovery using the same interpolation >method for 16-QAM. What algorithm would be suitable for TED of the QAM >system.If there's no transition then the signal is essentially DC and there's no way to determine the symbol boundaries. So no detector can provide timing information when there's no transition, and this is one reason it's important to have a scrambler in the system to keep the entropy high enough that the detector always works. Some of the "better" detectors know enough to generate exactly zero when no transition is detected in order to minimize the noise input to the timing loop. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Hi, Eric Jacobsen wrote:>On Wed, 07 Dec 2005 04:14:28 -0600, "Rajenish_jain" ><rajenish.jain@gmail.com> wrote: > > > >>Hi, >> I simulated a QPSK Symbol Rrror Recovery mechanism using interpolation >>menthod. I used a gardner TED which works only for the case where there is >>a symbol trensition. I would like to know of any algorithm which works for >>the case even without trnsition. (I didnt find Muller-Muller method very >>good). >> >>What if I want to simulate Symbol recovery using the same interpolation >>method for 16-QAM. What algorithm would be suitable for TED of the QAM >>system. >> >> > >If there's no transition then the signal is essentially DC and there's >no way to determine the symbol boundaries. So no detector can >provide timing information when there's no transition, and this is one >reason it's important to have a scrambler in the system to keep the >entropy high enough that the detector always works. > >Some of the "better" detectors know enough to generate exactly zero >when no transition is detected in order to minimize the noise input to >the timing loop. > >That answers Rajenish's first paragraph well, but misses his second. Gardner works OK for 16-QAM, or even much higher orders, with a couple of caveats - you need more damping, and training sequences may have issues. Because a scrambler is always used for real world QAM, the transition density is kept high, and the transitions kept fairly random. A Gardner test on any individual transition produces a rather variable result. However, the average of a few results from a scrambled sequence forms a cost function which homes the timing correctly. You need to use more damping in the Gardner test, than you would with QPSK, to provide appropriate averaging. Other than that, the same test will track the symbols OK. The only thing to watch is that you don't make the damping so great that you cannot track the greatest transmitter to receiver symbol clock rate mismatch you might face. Many QAM systems, such as telephone line modems, use an initial training phase where the transmitter alternates between two states. This is the section of the signal where you need to achieve your initial timing lock on the symbols. In many QAM training sequences, especially the more recent ones, the alternating symbols are of equal magnitude, and a Gardner TED works fine. However, in some specs the states are not of equal magnitude. The Gardner TED algorithm tends to lock to such a signal with a fixed phase shift. It may be OK to just ignore this, and let things settle down when the higher entropy sections of the signal start. That really depends on how far out the timing is for the particular training sequence. It might be possible to apply a fixed sized kick to the symbol timing as the end of the alternating signal is detected. It does, however, always need to be considered, to see the design is unconditionally stable. Regards, Steve
