Hello Everybody, i am a newcomer to dsp as well as this usenet. i was studying cross correlation using matlab, the two signals which i used were a 1 hz sine and a 2 hz sine, the waves were sampled at 10hz, i got 2 correlation peaks one at 8th bin and other at 14th , why there are two peaks?, is it that if we get more than one peak, the correlation result cannot be accepted as the above two signals were totally different? Regards, Satyajeet
cross correlation
Started by ●January 20, 2006
Reply by ●January 20, 20062006-01-20
"satyajeet" <satyajeet_vb@yahoo.com> wrote in message news:CaGdna9b6t0Hm0zenZ2dnUVZ_tudnZ2d@giganews.com...> Hello Everybody, > i am a newcomer to dsp as well as this usenet. > i was studying cross correlation using matlab, the two signals which i > used were a 1 hz sine and a 2 hz sine, the waves were sampled at 10hz, i > got 2 correlation peaks one at 8th bin and other at 14th , why there are > two peaks?, is it that if we get more than one peak, the correlation > result cannot be accepted as the above two signals were totally > different?Hi Satyajeet, It's that sin(x) and sin(2x) , far from being totally different are very very similar, you can check this yourself by plotting several cycles of each in the same graph. They are symmetric and orthogonal to each other over any integer multiple of either period so you can expect your cross correlation reults to drop to near zero for any lag which is an integer multiple of your shortest period ( bins 11, 21 etc. in your example because matlab puts zeroth lag in bin 1 (no bin 0) ). Try sampling at 16 Hz and see if you get proper zeros . For other lags the signals are not orthogonal they are either predominantly in-phase or in antiphase so the covariance vector has both a positive and a negative peak and after squaring you will see two positive peaks. Best of luck - Mike
