Hello guys, My name is Lior. I need your help with a project I am currently working on. I need to catch sound traveling from the modems speaker phone to the sound board (SB). the sound is not traveling with wave-in/out commands but in a certain driver level, cause all of the sound when a conversation is started, is directed to the SB automatically (even when I track the number of current active streams, with my SB monitor program, I don't see any change in the number of streams when the call is beginning, meaning it is all done in a lower level, so I think). As I said, I need to capture that sound so I can decide what to do with it - transfer it somewhere else or let it pass me to the SB. I understand that I need to develop a filter driver, after reading much on KS I still don't know which layer a filter driver I need. Is it a lower level filter driver (below the functional driver) ? or an upper filter driver (above the functional driver) ? Please help. p.s I also need to simulate a mic connected to the SB. Meaning fooling the SB that he gets sound from the mic-in jack when actually I am transmitting to him sound from a socket. Can that be done in the same filter driver ?? Thanks in advance, Lior Knaany.
filter driver ?
Started by ●July 21, 2004
Reply by ●July 21, 20042004-07-21
Just a short comment: you should include information on what system/DSP/CPU you're on - even though we can assume you're talking about windows (SB = SoundBlaster?) we can't know for sure and it won't be likely that you'll ever get an answer if you don't include the information on target processor and OS. -- Stephan M. Bernsee http://www.dspdimension.com
Reply by ●July 21, 20062006-07-21
Filtering KS drivers is not documented and is not supported. See archieves. This topic has been discussed to death in the past. -- Max. "Lior" <lior-kn@coolmail.co.il> wrote in message news:f44b1307.0407210317.5b5982e@posting.google.com...> Hello guys, > > My name is Lior. > I need your help with a project I am currently working on. > I need to catch sound traveling from the modems speaker phone to the > sound board (SB). > the sound is not traveling with wave-in/out commands but in a certain > driver level, cause all of the sound when a conversation is started, > is directed to the SB automatically (even when I track the number of > current active streams, with my SB monitor program, I don't see any > change in the number of streams when the call is beginning, meaning it > is all done in a lower level, so I think). > As I said, I need to capture that sound so I can decide what to do > with it - transfer it somewhere else or let it pass me to the SB. > > I understand that I need to develop a filter driver, after reading > much on KS I still don't know which layer a filter driver I need. Is > it a lower level filter driver (below the functional driver) ? or an > upper filter driver (above the functional driver) ? > > Please help. > > p.s > I also need to simulate a mic connected to the SB. > Meaning fooling the SB that he gets sound from the mic-in jack when > actually I am transmitting to him sound from a socket. > Can that be done in the same filter driver ?? > > Thanks in advance, > Lior Knaany.
