Hello, I have a question about the DFT that is used in OFDM and DMT. Emerging standards such as VDSL, DVB and Powerline allow transfrom sizes which can be as large as N = 1024, 2048 or 4096. Associated with this there is the problem of large peak to average ratio, clipping and non-linearities at the power amplifier. But there are methods to reduce these effects (see Tellado and Cioffi). My question is more about the FFT itself. An N-point FFT usually has log2(N) stages of computation. At each stage an extra bit of resolution is needed to fully capture signal dynamic range at the output of that stage. Does this not make it prohibitively expensive to have a large FFT? Example, suppose we have a DMT receiver with a ten bit analog to digital converter. The ADC output is fed to an FFT of N = 4096. Since log2(N)=12, the FFT output will have 22 bits, which is very large. Is it acceptable to do truncation here? I imagine clipping would be no problem at the receiver, because the expected values are the known transmit constellation points. Suppose we consider the transmitter of the above system. Modern bit-loading schemes allow up to 10 bits per each sub-carrier use. So if we have a ten-bit input to the FFT we will have a 22-bit output of an FFT with 4096. This time clipping will definitely cause problems, but as mentioned above there are means to correct this. But do we really need the full 22 bits of resolution? Is truncation acceptable at this stage? Cheers Porterboy
FFT or DFT with large N (for OFDM/DMT)
Started by ●February 3, 2006
