Ken Smith wrote:> In article <1139427882.792589.126890@f14g2000cwb.googlegroups.com>, > Ron N. <rhnlogic@yahoo.com> wrote: > >Tim Wescott wrote: > >> Implementing a PLL in software uses the same basic theory as > >> implementing a PLL in hardware -- you compare your synthesized signal to > >> a reference, generate a phase difference, then servo the frequency of > >> your synthesized signal to your reference. > > > >Why? Isn't a software PLL just a forward interpolator. Why not just > >estimate (statistical, FFT, phase vocoder or otherwise) the frequency, > >phase, derivatives of phase, etc.; generate a forward interpolation of > >the input reference using that information, and call that the output of > >the PLL NCO? Recalculate periodically (every sample if the compute > >power is available). > > Now fit that FFT into a PIC.The OP specified a 200 MHz DSP. Why add a PIC in addition to the DSP? And if he knows something about the signal, there might be more computationally efficient statistical estimators than some FFT frames. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Re: Software PLL (SPLL)
Started by ●February 9, 2006
