Search amazon.com for ["digital signal processing" matlab] and see the books that pop out. Ingle, Proakis Mitra Stearns all seem to get high marks. I wouldn't be surprised if you can't find some matlab code for dsp on the web. So, there would be examples. matlab is a language so you need to learn the language separately I should think - at least that would be my approach. Then you can use tricks learned from real code. A good book on matlab might be a good idea because the DSP books probably won't help much in learning how to construct things. But, hey, it's an iterative process and we've all used somebody else's code to avoid learning a whole lot of new stuff at once haven't we? Fred
Hamming window
Started by ●February 19, 2006
Reply by ●March 27, 20062006-03-27
Reply by ●March 28, 20062006-03-28
Hey This is my modified code. My filtered signal looks like a V shape, where the centre is sloped down. I don't think that looks right, why is that?? figure(1) t = (0:2/(88200-1):2); plot(t,y) title('Brain Signal (2 sec)') xlabel('Time(t)') ylabel('Voltage(v)') Y = y.*hamming(length(y)); figure(2) plot(t,Y) title('Hamming window applied to signal') xlabel('Time(t)') ylabel('Voltage(v)') figure(3) X = fft(Y); plot(X) title('FFTed signal') xlabel('logf') ylabel('log|Y|') Z = X.*conj(X); figure(4) plot(Z) title('Hamming window + Conjugate applied') xlabel('logf') ylabel('log|Y|') figure(5) loglog(Z) title('loglog plot') figure(6) semilogx(Z) title('semilogx plot') figure(7) semilogy(Z) title('semilogy plot') A = fftshift(Z); figure(8) semilogy(A) title('Simplified signal in frequency domain') figure(9) f = (-fs/2:1/2:fs/2-1/2)/1000; semilogy(f,A) title('Simplified signal in frequency domain') xlabel('Frequency (KHz)') figure(10) f2 = (0+1/2:1/2:fs/2)/1000; A_p = A(end/2+1:end); semilogy(f2,A_p) title('Positive side of A') xlabel('Frequency (KHz)') figure(11) f3 = (-fs/2:1/2:0-1/2)/1000; A_n = A(1:end/2); semilogy(f3,A_n) title('Negative side of A') xlabel('Frequency (KHz)') figure(12) V = zeros(1,88200); f = (-44100/2:1/2:44100/2-1/2)/1000; S = 500/0.5; P = 44100-S:44100+S; V(1,P) = 1; plot(f,V) title('Filter') xlabel('Frequency (KHz)') F_filt=A(P); f_filt=f(P); figure(13) semilogy(f_filt,F_filt) title('Filtered data') xlabel('Frequency (KHz)') figure(14) I = ifft(fftshift(F_filt)); plot(t(P),abs(I)) title('Filtered signal in time domain') xlabel('Time(t)')
