Hello Ron,>> >>But for this stuff you don't need an analog input. > > That may be true. But the last few laptop PC's I looked at > in the store didn't have any simple digital inputs (other than > the keyboard keys). They did have audio inputs though. > Wonder how common that situation is getting to be... > > Don't know if the OP stated whether the capacitive humidity > sensor in question has analog or digital outputs, and at > what levels. >Well, he was saying that he uses a uC. Those have a dozen port pins or more and usually a comparator as well. On a PC you are right, I'd probably do that job via the sound card. It's almost free since most PCs come with these standard. Regards, Joerg http://www.analogconsultants.com
simple sampling algo question
Started by ●March 4, 2006
Reply by ●March 6, 20062006-03-06
Ron N. wrote:> Joerg wrote: > >>>>I'm still confused. If you want to count zero crossings with a computer, >>>>how does an ADC help? >>> >>>It's the only analog input on many computer systems, other than >>>those involving complex protocols such as USB, Firewire, ethernet, >>>etc. e.g. The microphone jack. >>> >> >>But for this stuff you don't need an analog input. > > > That may be true. But the last few laptop PC's I looked at > in the store didn't have any simple digital inputs (other than > the keyboard keys). They did have audio inputs though. > Wonder how common that situation is getting to be... > > Don't know if the OP stated whether the capacitive humidity > sensor in question has analog or digital outputs, and at > what levels.The sensor controls the frequency of an oscillator, a good strong oscillator probably putting out a 3-volt square wave at low impedance. V-to-F converters are an alternative to 3-20 ma current loops. They are intended for industrial environments and don't need coddling. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
