Dear FFTW experts, I get very strange results when I try to use in-place 2D r2c transforms. Somehow, results are different for in-place and out-of-place transforms of the same array, although an inverse transform always takes me back to my original array (after scaling). For 1D there is no difference. Please, tell me, what I'm doing wrong?! My script is as follows (I know I allocate more space than is needed): int main() { fftw_complex *out; double *in; fftw_plan p; int i, j; int n[]={5, 5}; in = (double*)malloc(sizeof(double)*(n[0]*n[1]+10)); out = (fftw_complex*)fftw_malloc(sizeof(fftw_complex) * (n[0]*n[1])); p = fftw_plan_dft_r2c(2, n, in, (fftw_complex*)in,FFTW_MEASURE ); //p = fftw_plan_dft_r2c(2, n, in, out,FFTW_MEASURE ); in[0] = 12; in[1] = 14; in[2] = 11; in[3] = 15; in[4] = 15 ; in[5] = 17; in[6] = 32; in[7] = 28; in[8] = 17; in[9] = 14; in[10] = 17; in[11] = 23; in[12] = 14; in[13] = 29; in[14] = 21; in[15] = 10; in[16] = 21; in[17] = 21; in[18] = 10; in[19] = 16; in[20] = 11; in[21] = 16 ; in[22] = 12; in[23] = 20; in[24] = 16; fftw_execute(p); printf("in[0]=%f, out[0][0]=%f\n", in[0], out[0][0]); free(in); fftw_free(out); fftw_destroy_plan(p); }
FFTW: a problem with in-place 2D r2c transform
Started by ●March 13, 2006
Reply by ●March 14, 20062006-03-14
The array format for r2c transforms is described in detail at: http://www.fftw.org/doc/Multi_002dDimensional-DFTs-of-Real-Data.html In particular, note that 1) the output is n[0] * (n[1]/2 + 1) in size, not n[0]*n[1] 2) the input is n[0] * n[1] in size for out-of-place and n[0] * 2 * (n[1]/2+1) in size for in-place, where the latter reflects padding to make room for the complex output. This is all described in the manual. Cordially, Steven G. Johnson
stevenj@alum.mit.edu wrote:> The array format for r2c transforms is described in detail at: > > > http://www.fftw.org/doc/Multi_002dDimensional-DFTs-of-Real-Data.html > > In particular, note that > > 1) the output is n[0] * (n[1]/2 + 1) in size, not n[0]*n[1] > > 2) the input is n[0] * n[1] in size for out-of-place and n[0] * 2 * > (n[1]/2+1) in size for in-place, where the latter reflects padding to > make room for the complex output. > > This is all described in the manual. > > Cordially,Steven, You are a gem of patience and good will! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●March 15, 20062006-03-15
Thanks a lot for your kind reply, Steven. I feel very flattered to be answered by the author himself, and even more confused to continue asking my dumb questions, but: 1) I read this part of the manual. I didn't realize that allocating more than is needed was a mistake. 2) I've changed the array sizes to the exact values in your reply. I still get zero-frequency of 351 for in-place, and 432 for out-of-place. What am I doing wrong?? Thanks again>The array format for r2c transforms is described in detail at: > > >http://www.fftw.org/doc/Multi_002dDimensional-DFTs-of-Real-Data.html > >In particular, note that > >1) the output is n[0] * (n[1]/2 + 1) in size, not n[0]*n[1] > >2) the input is n[0] * n[1] in size for out-of-place and n[0] * 2 * >(n[1]/2+1) in size for in-place, where the latter reflects padding to >make room for the complex output. > >This is all described in the manual. > >Cordially, >Steven G. Johnson > >
Probably you are writing or reading the input and/or output incorrectly. Allocating more space than necessary in itself is harmless. However, how you *access* the array elements depends on the array size. If you have an NxM array in row-major order, then the (i,j) element is accessed as M*i+j. Steven
Reply by ●March 16, 20062006-03-16
Thanks again for your patience, Steven, and for your great program :) I understand now what I had wrong - the padding should be at the end of each line, not at the end of the whole array! So the same input array can not be used for both in-place and out-of-place transforms, even if it's big enough. Sorry for bothering you with something so stupid. ->Probably you are writing or reading the input and/or output >incorrectly. > >Allocating more space than necessary in itself is harmless. However, >how you *access* the array elements depends on the array size. If you >have an NxM array in row-major order, then the (i,j) element is >accessed as M*i+j. > >Steven > >
young wrote:> Thanks again for your patience, Steven, and for your great program :) > I understand now what I had wrong - the padding should be at the end of > each line, not at the end of the whole array! So the same input array can > not be used for both in-place and out-of-place transforms, even if it's > big enough.Actually, the same input array can be used for both in-place and out-of-place, but you have to use the advanced API - the advanced API allows you to specify an arbitrary amount of "padding" in your array.
