Hi folks, If I have a 2D image whose values are purely real, and I take the 2D FT, then I expect the 2D FT to have even symmetry. I think this applies to a reflection about one axis - that is, half the resulting 2D FT image is a reflection of the other half. So all the information is in kept if I use just one half of the 2D FT image. But does it apply in some circumstances to each quadrant being a reflection of each other quadrant? So that the information is kept even if I use just one quadrant of the 2D FT image? Thanks, Chris
even/odd symmetry in 2D FT of real-valued image
Started by ●April 11, 2006
Reply by ●April 11, 20062006-04-11
Chris Bore skrev:> Hi folks, > > If I have a 2D image whose values are purely real, and I take the 2D > FT, then I expect the 2D FT to have even symmetry. I think this applies > to a reflection about one axis - that is, half the resulting 2D FT > image is a reflection of the other half. So all the information is in > kept if I use just one half of the 2D FT image. > > But does it apply in some circumstances to each quadrant being a > reflection of each other quadrant? So that the information is kept even > if I use just one quadrant of the 2D FT image?In general -- no. The symmetry properties in the 2D FT are a bit different than one might expect. The symmetry is around origo, not the axes. To see why, think of the 2D FT of an Nx by Ny image as two sequencial 1D FTs, the first one applied in the x direction and the second in the y direction. After the first 1D FTs, the partially transformed image contains complex-valued samples and is conjugate symmetrical around Ny/2, as expected. The second set of FTs, in the y direction, take *complex-valued* data as input. As you know, no general symmetry properties can be expected for FTs on complex-valued data,sou you will need to keep half the tranformed image. Rune
On 2006-04-11 05:25:41 -0300, "Chris Bore" <chris.bore@gmail.com> said:> Hi folks, > > If I have a 2D image whose values are purely real, and I take the 2D > FT, then I expect the 2D FT to have even symmetry. I think this applies > to a reflection about one axis - that is, half the resulting 2D FT > image is a reflection of the other half. So all the information is in > kept if I use just one half of the 2D FT image. > > But does it apply in some circumstances to each quadrant being a > reflection of each other quadrant? So that the information is kept even > if I use just one quadrant of the 2D FT image? > > Thanks, > > ChrisThe word you are looking for is "inversion" as in "a 2-d FT of a real function has inversion symmetry". Inversion in 1-d is the same as reflection. Inversion is a "reflection" through the origin. So you will see the reflection you were expecting along either axis but it is an inversion in the interior. For much more than you ever wanted to know about symmmetry and FTs take a look at the crystallographic literature. They mix FTs with spacial symmetry groups in both 2-d and 3-d.
