The Video Coding and Architectures research group is part of the Signal Processing Systems department of the Eindhoven University of Technology, The Netherlands. The research spans areas of video analysis, image/video segmentation, object-oriented and 3D video compression that underpin systems-oriented research on video coding and architectures. This work pursues state-of-the-art video functionality at high cost-efficiency (e.g. for real-time aspects and/or mobile applications), through a combination of novel algorithms and architectures. Project title: Predictable Matching of Demands on Networked Architectures (PreMaDoNa) This project is aiming at studying the mapping of advanced multimedia algorithms on multiprocessor platforms. Advanced multimedia means here studying modern video coding or corresponding processing such as content analysis as a source for high-profile video signal processing. These algorithms are usually heterogeneous from nature, requiring both special signal processing techniques and memory-based processing. Object-oriented coding, 3D video and content analysis are example topics where the signal processing is at least one order of magnitude more complex than existing standard algorithms. An optimal mapping of such algorithms is thus a challenging task, which sometimes requires redesign of the algorithms itself to obtain a high efficiency. The research will focus on selecting advanced example algorithms that constitute an interesting application and mapping those on a detailed multiprocessor model. Later, the research may proceed in architecting special FPGA or co-processor subsystems to come to more efficient system design. The management and scalability of the application(s) will also play a role. This research is conducted in close cooperation with Philips Research and other groups of the Eindhoven University. Additional information is available at www.es.ele.tue.nl/premadona/ Contact information If you are interested please contact by email Prof.dr. Peter H.N De With and PDEng. Milan Pastrnak Contact information is available at http://vca.ele.tue.nl/people/deWith.html and http://vca.ele.tue.nl/people/Pastrnak.html
PhD position in mapping of multimedia algorithms on multiprocessor platform, Eindhoven The Netherlands
Started by ●April 12, 2006
