My understanding is that you phase shift one signal by 90 degrees with a hilbert tranformer than sample - is that right? With a carrier based system you need only use sin and cos and then sample giving I and Q. The advantage appears to be that you can sample at B (bandwidth) rather than 2BHz. Can we extend this and phase shift by pi/4 and sample with 4 ADCs? In general we would get a sampling freq of (2/n).B where n is the number of samplers. Would this work or does it only work for the quadrature case. Also where is the proof of quadraure sampling? I understand the standard theory, it begins by multiplication of f(t) the signal by an impulse train which you then take a FT of and do convolution in the freq domain. With the quadrature case do we take f(t) and jf(t) and do the same thing? The otehr thing is, if you need a Hilbert transform before you sample then the signal would need to be in digital form before you sample unless you can do it analogue. Thanks Tom
Quadrature Sampling Question
Started by ●April 21, 2006
Reply by ●April 21, 20062006-04-21
Entropy wrote:> My understanding is that you phase shift one signal by 90 degrees with a > hilbert tranformer than sample - is that right? With a carrier based system > you need only use sin and cos and then sample giving I and Q. > > The advantage appears to be that you can sample at B (bandwidth) rather than > 2BHz. > > Can we extend this and phase shift by pi/4 and sample with 4 ADCs? In > general we would get a sampling freq of > > (2/n).B where n is the number of samplers. Would this work or does it only > work for the quadrature case. > > Also where is the proof of quadraure sampling? I understand the standard > theory, it begins by multiplication of f(t) the signal by an impulse train > which you then take a FT of and do convolution in the freq domain. With the > quadrature case do we take f(t) and jf(t) and do the same thing? > > The otehr thing is, if you need a Hilbert transform before you sample then > the signal would need to be in digital form before you sample unless you can > do it analogue.You need two samples per cycle of the highest frequency with all the schemes you cite. They all work in theory. The more converters in your system, the harder it is to match their offsets, non-linearities, and gains. The more sampling channels, the harder it is to keep them all properly phased. There is usually a reason for common practice, but don't let that stop you from looking for better ways. Every so often, you will find one. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
